Yeah no Problem, I can test that on an Echo Show and on an Echo Spot (I want to use it anyways, so testing it is basically configuring the setup I need anyways )
Guys,
I donât know why, but when I try to use SSML I hear also all tags
eg:
Echo_Living_Room_TTS.sendCommand('<speak>Bentornato a casa, Andrea</speak>')
I hear âspeak bentornato a casa, Andreaspeakâ
Any suggestion? What Iâm missing?
thanks
Andrea
I expect that you missed to install the beta version from the top most posting if this thread. The current release does nit support SSML.
the beta version is not merged with the latest version of OH?
edit: uops ⊠right âŠ
What I need to do exactly? copy the beta (3) in /usr/share/openhab2/addons and thatâs it? or I need to install the previous version installed via PaperUI?
openhabian here
thanks
Andrea
Hi There,
I am just trying to use the command âstartRoutineâ. I have created a rule but actualy I have no idea how to identify the Routine to be started. What identifier to use?. I have arount 7 or 8 routines created in my echo plus what name, command text or whatever need to write in the rule?. An example woudl be highly appreciated.
Channel âastro:sun:local:set#endâ triggered END
âEcho_Living_Room_StartRoutineâ.sendCommand(âŠ???)
Thanks in advance!
Mariano
It looks like there is a bug in the documentation, but the example (scroll down in the docs) shows this as a String item. Iâve submitted a change for this.
Just send the name of the routine as a string, without the command word, to activate the routine.
then, I must write the text vocie I use to activate the Routine (in theexample below case is in german):
âEcho_Living_Room_StartRoutineâ.sendCommand(âLichts anâ)
And the item shoud be:
String Echo_Living_Room_StartRoutine âStart Routineâ {channel=âamazonechocontrol:echo:account1:echo1:startRoutineâ}
Iâve never used it⊠but that LGTM! Temporarily add add a System started
trigger to test (will trigger when rule file is saved).
Thank you! Your are right, this is a documentation bug!
Thanks a lot Scott! Working fine, no with System Started (probably because me) but with a Window sensor (as testing mode).
rule âSwitch on ligths when darkâ
Item WS_Livingroom_Window3 changed to âOPENâ
/Channel âastro:sun:local:set#endâ triggered END/
âEcho_Living_Room_StartRoutineâ.sendCommand(âlampe anâ)
Youâre welcome⊠glad it worked for you! I see some strange syntax though⊠Triggers should be separated with âorââŠ
or
or
System started
astro trigger just was hidden with " /* " for testing purposes. Now I have removed the Window sensor and let the astro set#end as unique trigger.
Waiting for tonight.
Thanks!
Mariano
Having lot of fun playing with the SSML support in your last release and flags
By the way, I intended to use the lastVoiceCommand channel to determine which Echo device to use when sending a reply through TTS.
But when 2 Echo devices catch what I say, both lastVoiceCommand are updated so I cannot determine where to speak in reply (and speaking on both Echo is messy as it cannot be synchronized).
Alexa features âEcho Spatial Perceptionâ to ensures that only the closest Echo will reply. Is there a way to catch this information in a channel and use it to reply with the correct device?
I wonder if that could be used for an audio version of FIND?
That would be very cool. Using doppler to locate a person
Hello!
Iâm using it and it works great! But I have some problem: I press âPlayâ in my OH panel and âKiis Fmâ starts on my Echo Dot. Than I change the station by voice âAlexa, play Smooth Jazzâ and another station is playing. But in my panel I still see the previous station (imageUrl, title, subtitle1, providerDisplayName). If I change the volume in my OH panel - the volume change but information still outdated. The information updated immediately when I press âPauseâ in my OH panel.
How to update it automatically?
My OH version: 2.4
My Amazon Echo Control Binding version: 2.5 (3)
Sounds like an update problem of the UI.
Do you have the same behavior in BasicUI?
How did you integrate the value of the title in your HABPanel?
I check only basicUI now, but may be the problem not in the UI: I see log and nothing happen when I change the station by voice. Only when I push âPlayâ or âPauseâ button.
My items:
// Player control
Player Echo_Player âPlayerâ {channel=âamazonechocontrol:echo:3251211b:echo1:playerâ}
Dimmer Echo_Volume âVolume [%.0f %%]â {channel=âamazonechocontrol:echo:3251211b:echo1:volumeâ}
// Player Information
String Echo_ImageUrl ââ {channel=âamazonechocontrol:echo:3251211b:echo1:imageUrlâ}
String Echo_Title âTitle [%s]â {channel=âamazonechocontrol:echo:3251211b:echo1:titleâ}
String Echo_Subtitle1 âSubtitle 1 [%s]â {channel=âamazonechocontrol:echo:3251211b:echo1:subtitle1â}
String Echo_Subtitle2 âSubtitle 2 [%s]â {channel=âamazonechocontrol:echo:3251211b:echo1:subtitle2â}
String Echo_ProviderDisplayName âProvider [%s]â {channel=âamazonechocontrol:echo:3251211b:echo1:providerDisplayNameâ}
My sitemap:
Frame label=âAlexaâ {
Default item=Echo_Player
Slider item=Echo_Volume
Image item=Echo_ImageUrl
Text item=Echo_Title
Text item=Echo_Subtitle1
Text item=Echo_Subtitle2
Text item=Echo_ProviderDisplayName
My things:
Bridge amazonechocontrol:account:3251211b âAmazon Accountâ @ âAccountsâ
Thing echo echo1 âAlexaâ @ âMy Roomâ [serialNumber=âxxxâ]
Thing wha wha_main âMultiroom Musicâ @ âMusic Groupsâ [serialNumber=âxxxâ]
Iâm newbie in OpenHub so may be I do something wrong. May be I have to add some parameter to things, like interval=10 or something like this?
As I can see it, my code is out of date. There is no need to enter this anymore.
Yes, I tried it before with âpollingIntervalInSeconds=10â, but no luck
I found the reason: when I start iHeartRadio (by the voice) the station is not updated automatically (you need to click on the pause for the information to be updated), but when I use TuneIn - everything works greatâŠ
