But should it control the TTS or Alexas answers?
Even when changing the value in my sitemap the volume of TTS doesn´t change.
The TextToSpeechVolume channel changes the TTS volume. It does not change Alexa’s voice replies.
I am using this channel in my rules and can confirm it works OK on the Nov 2018 binding release and also on yesterday’s Beta07 preview. Other releases may fail. I am using a USA Amazon account.
BTW, if you are a OH2 user then the rule’s TextToSpeechVolume action will appear as a ItemCommandEvent in OH2’s Log Viewer.
- Thomas
That´s what i need
I´m using the latest Beta preview and an Amazon Germany account.
The TTSVolume item changes to 100 but the TTS output is still on the level of the normal volume item.
kind regards
Michael
In my installation I have several Echo Dot type A3S5BH2HU6VAYF and one Echo Show Type A1NL4BVLQ4L3N3 (type ID as reported in Amazon Control Account). The Echo dots’ ring light illuminates for a moment when the TTS volume command is received and the Echo Show displays the graphic volume control image with the TTS volume level.
If you are unable to achieve success then perhaps Amazon Germany has not implemented the TTS volume function or requires a different API usage.
- Thomas
TTS vol is working for me using .de with an Echo and Echo Dot. I only set TTS vol at startup with a rule and it doesnt change after that.
Thank you
no it works like a charm.
BR
Is there a question / answer option?
I have a routine, status report, which toggles a switch. Using tts in a rule I build a response and push it to the alexa which just triggered the switch toggle.
While this works the disconnect is awkward.
I was wondering if I missed a feature somewhere where you can ask a question and push an answer?
Is there a way to use the REST api to send an announcement to one’s echo devices? I have the following url returning data to the screen (and via the REST API documentation screen), but I do not see any way to use an http address to perform an announcement.
http://10.17.2.40:8085/rest/channel-types/amazonechocontrol:announcement?"This is a test"
Is it possible to ask Alexa if a Window is open (so triggered) or a light is on ? (sonoff) ?
pls delete
Yes, you can ask Alexa if a window is opened. See this post from @5iver way back in this thread. Or the brute force approach of a proxy item that indicates in temperature the state of any item in the standard Alexa V2 skill. See this post.
This is what I was looking for but more of a question / answer. This method, like mine, pushes the response. I’d like to keep the blue ring flashing while she thinks. Nothing like this possible?
Yes, something like this is possible, but it depends on how far you stretch the word “like”. See the second link. You can convert anything you want to temperature, and then ask Alexa for what you want and she will stay blue and answer with the value in temperature. If that’s not close enough, you can implement the V3 skill on your own server and I believe you can ask directly. See this.
Wohoooo that sounds great - never tired the Echo Control Binding - how can i configure the binding and the answers of any questions ? Is this already implemented or must be configured extra ?
This I have seen and will install it like that - the question was regarding the speak and response script - is that included in this install routin ? Many Thanks
My script is in Jython, which uses the new rule engine, so there are additional steps needed. However, thie logic of the script could be written using a DSL rule.
hello michi
as written it worked like a charm for a while now, but since a few days, i have the same problem again. I f I change to the next song via openhab, everything works fine, if I just say next, nothing happens.
Are there still some issues?
BR
Hi Michi,
Time to time, TTS command fails. I get the following message in the log. Any idea of what happens? Anything I should try to help you in troubleshooting this?
18:33:09.085 [ERROR] [rnal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.amazonechocontrol.internal.handler.EchoHandler@260c596c': POST url 'https://alexa.amazon.fr/api/behaviors/preview' failed: Bad Request
org.openhab.binding.amazonechocontrol.internal.HttpException: POST url 'https://alexa.amazon.fr/api/behaviors/preview' failed: Bad Request
at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequest(Connection.java:593) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.executeSequenceNode(Connection.java:1140) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.executeSequenceCommand(Connection.java:1125) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.executeSequenceCommandWithVolume(Connection.java:1116) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.textToSpeech(Connection.java:1089) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.EchoHandler.startTextToSpeech(EchoHandler.java:738) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.handler.EchoHandler.handleCommand(EchoHandler.java:586) ~[?:?]
at sun.reflect.GeneratedMethodAccessor166.invoke(Unknown Source) ~[?:?]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) ~[?:?]
at java.lang.reflect.Method.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.AbstractInvocationHandler.invokeDirect(AbstractInvocationHandler.java:153) [102:org.eclipse.smarthome.core:0.10.0.oh240]
at org.eclipse.smarthome.core.internal.common.InvocationHandlerSync.invoke(InvocationHandlerSync.java:59) [102:org.eclipse.smarthome.core:0.10.0.oh240]
at com.sun.proxy.$Proxy149.handleCommand(Unknown Source) [191:org.openhab.binding.amazonechocontrol:2.5.0.Beta_05]
at org.eclipse.smarthome.core.thing.internal.profiles.ProfileCallbackImpl.handleCommand(ProfileCallbackImpl.java:75) [109:org.eclipse.smarthome.core.thing:0.10.0.oh240]
at org.eclipse.smarthome.core.thing.internal.profiles.SystemDefaultProfile.onCommandFromItem(SystemDefaultProfile.java:49) [109:org.eclipse.smarthome.core.thing:0.10.0.oh240]
at sun.reflect.GeneratedMethodAccessor165.invoke(Unknown Source) ~[?:?]
at org.eclipse.smarthome.core.internal.common.Invocation.call(Invocation.java:53) [102:org.eclipse.smarthome.core:0.10.0.oh240]
at java.util.concurrent.FutureTask.run(Unknown Source) [?:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [?:?]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [?:?]
at java.lang.Thread.run(Unknown Source) [?:?]
Thank you
Yann
Hello all,
I am facing some strange behaviors with my amazon echo dot.
I have set a rule that should enable the TuneIn Station id every morning by the following command extract
Echo_Living_Room_RadioStationId.sendCommand('sXXXX')
and stops it with
Echo_Living_Room_RadioStationId.sendCommand('')
The issue is that the rule works flawless if the Echo was previously manually started with a Voice Command like “Alexa start Radio”.
But if the command comes over the openHab it just says in the logs something like:
RadioStationId stationId changed from '' to 'sxxxxx'
--- from PAUSE to PLAY
--- from 'sxxxxx' to ''
--- from PLAY to PAUSE
But the radio never starts playing. In this case I also need to activate alexa’s radio manually and afterwards the commands from openHAB work till the next morning.
Has anyone faced the same issue?
Many Thanks
Regards
