@Saracen
That is awesome, thanks for pointing out the presence of the link.
I have difficulty seeing the links from normal text.
Regards
Paul
@Saracen
Regards
Paul
Hey Michael,
Is it possible to create an item for the binding that does the Alexa notifications (yellow blinking light)? This would allow us to trigger delivery notifications (item coming, item delivered, etc.).
Keep up the great work! One of the most important bindings in my collection.
Best, Jay
Hi Guys, does anyone have continued issues with using a group with your TTS channels inside to send alerts? Its very flakey and never works consistently. I dont think this is really a binding issue but perhaps some kind of rate limit on Alexa requests. Is there a way around this or even a method to pay for more requests to the Alexa?
Are you sending alot of requests to Amazon? I get this error too.
Have you tried adding org.eclipse.smarthome.threadpool:RuleEngine=20 at the end of /etc/openhab2/services/runtime.cfg to see if that helps? I can not, at the moment, remember exactly what this does but it may be worth a try.
Ill give it a go! Thanks
Beta 7 released
This is a bugfix release with no new features.
Download Beta 7 from the top most posting
Roadmap
openHAB 2.5:
openHAB 2.6:
openHAB 2.7:
Hi Jay,
The notifications have an documented API for Alexa Skills. But I assume, that a Skill could only be one of the different type of skills and the current existing openHAB skill is a smarthome skill. So I assume, a new skill would be necessary for this. But Iāam not really sure, maybe you can ask the developer of the openHAB skill.
I do not see currently any possibility to this from the binding. But of course, this could change if amazon add this feature to routines.
Best,
Michael
Hi @michi
Group announcements are now working much better. They are more in sync
Echo Dot, Echo Show, Echo all in a group >>> I make short attention tone and then the announcement to the group >>> all 3 are now in sync and there are no errors in the log but ā¦
I did have an initial error while I was updating some other rules I was working on but its not repeated since.
2019-04-18 10:18:56.149 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.amazonechocontrol.internal.handler.EchoHandler@11a90a': POST url 'https://alexa.amazon.de/api/behaviors/preview' failed: Bad Request
org.openhab.binding.amazonechocontrol.internal.HttpException: POST url 'https://alexa.amazon.de/api/behaviors/preview' failed: Bad Request
Thanks, Mark.
Hi @michi,
I just installed the latest beta, but when I try to login, I get the following error:
Problem accessing /amazonechocontrol/bfd9850d/ap/signin. Reason:
Server Error
org.openhab.binding.amazonechocontrol.internal.HttpException: POST url āhttps://www.amazon.com/ap/signinā failed: Found at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequest(Connection.java:628) at org.openhab.binding.amazonechocontrol.internal.AccountServlet.handleProxyRequest(AccountServlet.java:628) at org.openhab.binding.amazonechocontrol.internal.AccountServlet.doVerb(AccountServlet.java:225) at org.openhab.binding.amazonechocontrol.internal.AccountServlet.doPost(AccountServlet.java:133) at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
Do you have any idea what I am doing wrong?
Thanks a lot!
Christoph
@michi
Hi Michael - Am continuing to have issues with the binding - Ive followed your instructions that I must use a beta version - Iāve now tried version 6 & 7 and Iām no further forward in being able to use the binding. - prior to the change in the binding I had little issue - when i could add the .com.au suffix (under OH2.3 - In paper ui)
HTTP ERROR 500
Problem accessing /amazonechocontrol/854bfe87/ap/signin/131-8618649-0793801. Reason:
Server Error
Caused by:
org.openhab.binding.amazonechocontrol.internal.HttpException: POST url āhttps://www.amazon.com/ap/signin/131-8618649-0793801ā failed: Found
at javax.servlet.http.HttpServlet.service(HttpServlet.java:790)
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:865)
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:535)
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:146)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:132)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:257)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:1595)
at org.eclipse.jetty.server.handler.ScopedHandler.nextHandle(ScopedHandler.java:255)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1317)
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:293)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:203)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:473)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:1564)
at org.eclipse.jetty.server.handler.ScopedHandler.nextScope(ScopedHandler.java:201)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1219)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:144)
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80)
at org.eclipse.jetty.server.Server.handle(Server.java:531)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:352)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:260)
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:281)
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:102)
at org.eclipse.jetty.io.ChannelEndPoint$2.run(ChannelEndPoint.java:118)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:333)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:310)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:168)
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:126)
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:366)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:762)
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:680)
at java.lang.Thread.run(Thread.java:748)
I am using OH2.4 Release Build
Matt
That does not work for me:
āspeak and breakā are both just said by alexa.
How did you make it run? @Saracen?
Did you copy and paste the text from the post or re-type it?
Try copy-and-pasting it verbatim in case you are using the wrong characters for the quote marks.
echo_TTS.sendCommand('<speak>Wait for the <break/> Pause</speak>')
Does the api expose whoās talking? If so, could this be exposed as a channel?
My alexa knows my voice and knows me as Crispin. Everyone else is unknown.
C
This is no API and no itās currently not possible.
The binding only works with things that work on the Alexa website.
Currently thereās no feature to use the voice recognition.
Iām also waiting for this
Booo
Hereās adding it to my list
Hi @michi,
Since Beta7, command sent to TTS channel no longer interrupts on-going speech as quickly as in previous versions. This is quite problematic for me because I run a prioritized notification queue which allows a notification to be interrupted by a more important one (I handle a priority level) and restarted after the most urgent notification was completed. With latest Beta7, it behaves quite erratically.
See below my test: when I send sequentially 3 TTS commands, I would expect the first 2 to be interrupted and only hear the 3rd one. In the example below, I only hear the 2nd notification and 1st and 3rd seem to get lost.
22:38:22.082 [INFO ] [me.model.script.rules.sys.ItemCommand] - [EC_TTS] EC_mN2_Sdb_TTS received command Premiāre notification
22:38:22.085 [INFO ] [me.model.script.rules.sys.ItemCommand] - [EC_TTS] EC_mN2_Sdb_TTS received command Seconde notification
22:38:22.099 [INFO ] [me.model.script.rules.sys.ItemCommand] - [EC_TTS] EC_mN2_Sdb_TTS received command Troisiāme notification
22:38:22.476 [DEBUG] [amazonechocontrol.internal.Connection] - Call to https://alexa.amazon.fr/api/behaviors/preview succeeded
22:38:22.478 [DEBUG] [amazonechocontrol.internal.Connection] - Make request to https://alexa.amazon.fr/api/behaviors/preview
22:38:22.479 [DEBUG] [amazonechocontrol.internal.Connection] - POST: {"behaviorId":"PREVIEW","sequenceJson":"{\"@type\":\"com.amazon.alexa.behaviors.model.Sequence\",\"startNode\":{\"@type\":\"com.amazon.alexa.behaviors.model.OpaquePayloadOperationNode\",\"type\":\"Alexa.Speak\",\"operationPayload\":{\"deviceType\":\"A7WXQPH584YP\",\"deviceSerialNumber\":\"GXXXXXXXXXXXXXXX\",\"locale\":\"\",\"customerId\":\"AAAAAAAAAAAAAA\",\"textToSpeak\":\"Seconde notification\"}}}","status":"ENABLED"}
22:38:22.890 [DEBUG] [amazonechocontrol.internal.Connection] - Call to https://alexa.amazon.fr/api/behaviors/preview succeeded
22:38:22.892 [DEBUG] [amazonechocontrol.internal.Connection] - Make request to https://alexa.amazon.fr/api/behaviors/preview
22:38:22.893 [DEBUG] [amazonechocontrol.internal.Connection] - POST: {"behaviorId":"PREVIEW","sequenceJson":"{\"@type\":\"com.amazon.alexa.behaviors.model.Sequence\",\"startNode\":{\"@type\":\"com.amazon.alexa.behaviors.model.OpaquePayloadOperationNode\",\"type\":\"Alexa.Speak\",\"operationPayload\":{\"deviceType\":\"A7WXQPH584YP\",\"deviceSerialNumber\":\"GXXXXXXXXXXXXXXX\",\"locale\":\"\",\"customerId\":\"AAAAAAAAAAAAAA\",\"textToSpeak\":\"Troisiāme notification\"}}}","status":"ENABLED"}
22:38:23.282 [DEBUG] [amazonechocontrol.internal.Connection] - Call to https://alexa.amazon.fr/api/behaviors/preview succeeded
22:38:23.348 [DEBUG] [ocontrol.internal.WebSocketConnection] - Message received: {"payload":"{\"destinationUserId\":\"AAAAAAAAAAAAAA\",\"key\":{\"entryId\":\"1555965505806#A7WXQPH584YP#GXXXXXXXXXXXXXXX\",\"registeredUserId\":\"AAAAAAAAAAAAAA\"},\"timestamp\":1555965506252}","command":"PUSH_ACTIVITY"}
22:38:23.350 [DEBUG] [amazonechocontrol.internal.Connection] - Make request to https://alexa.amazon.fr/api/activities?startTime=1555965506252&size=10&offset=1
22:38:23.579 [DEBUG] [amazonechocontrol.internal.Connection] - Call to https://alexa.amazon.fr/api/activities?startTime=1555965506252&size=10&offset=1 succeeded
22:38:23.583 [DEBUG] [ocontrol.internal.WebSocketConnection] - Message handled: {"payload":"{\"destinationUserId\":\"AAAAAAAAAAAAAA\",\"key\":{\"entryId\":\"1555965505806#A7WXQPH584YP#GXXXXXXXXXXXXXXX\",\"registeredUserId\":\"AAAAAAAAAAAAAA\"},\"timestamp\":1555965506252}","command":"PUSH_ACTIVITY"}
22:38:23.648 [DEBUG] [ocontrol.internal.WebSocketConnection] - Message received: {"payload":"{\"destinationUserId\":\"AAAAAAAAAAAAAA\",\"key\":{\"entryId\":\"1555965506160#A7WXQPH584YP#GXXXXXXXXXXXXXXX\",\"registeredUserId\":\"AAAAAAAAAAAAAA\"},\"timestamp\":1555965506554}","command":"PUSH_ACTIVITY"}
22:38:23.650 [DEBUG] [amazonechocontrol.internal.Connection] - Make request to https://alexa.amazon.fr/api/activities?startTime=1555965506554&size=10&offset=1
22:38:24.286 [DEBUG] [ocontrol.internal.handler.EchoHandler] - Handle updateState amazonechocontrol:echo:f71ef12f:GXXXXXXXXXXXXXXX
22:38:24.288 [DEBUG] [amazonechocontrol.internal.Connection] - Make request to https://alexa.amazon.fr/api/np/player?deviceSerialNumber=GXXXXXXXXXXXXXXX&deviceType=A7WXQPH584YP&screenWidth=1440
22:38:29.937 [DEBUG] [ntrol.internal.handler.AccountHandler] - check login amazonechocontrol:account:f71ef12f
22:38:30.406 [DEBUG] [amazonechocontrol.internal.Connection] - Call to https://alexa.amazon.fr/api/activities?startTime=1555965506554&size=10&offset=1 succeeded
22:38:30.410 [DEBUG] [ocontrol.internal.WebSocketConnection] - Message handled: {"payload":"{\"destinationUserId\":\"AAAAAAAAAAAAAA\",\"key\":{\"entryId\":\"1555965506160#A7WXQPH584YP#GXXXXXXXXXXXXXXX\",\"registeredUserId\":\"AAAAAAAAAAAAAA\"},\"timestamp\":1555965506554}","command":"PUSH_ACTIVITY"}
22:38:30.411 [DEBUG] [ocontrol.internal.WebSocketConnection] - Message received: {"payload":"{\"destinationUserId\":\"AAAAAAAAAAAAAA\",\"key\":{\"entryId\":\"1555965506550#A7WXQPH584YP#GXXXXXXXXXXXXXXX\",\"registeredUserId\":\"AAAAAAAAAAAAAA\"},\"timestamp\":1555965506753}","command":"PUSH_ACTIVITY"}
22:38:30.413 [DEBUG] [amazonechocontrol.internal.Connection] - Make request to https://alexa.amazon.fr/api/activities?startTime=1555965506753&size=10&offset=1
22:38:30.570 [DEBUG] [amazonechocontrol.internal.Connection] - Call to https://alexa.amazon.fr/api/activities?startTime=1555965506753&size=10&offset=1 succeeded
22:38:30.573 [DEBUG] [ocontrol.internal.WebSocketConnection] - Message handled: {"payload":"{\"destinationUserId\":\"AAAAAAAAAAAAAA\",\"key\":{\"entryId\":\"1555965506550#A7WXQPH584YP#GXXXXXXXXXXXXXXX\",\"registeredUserId\":\"AAAAAAAAAAAAAA\"},\"timestamp\":1555965506753}","command":"PUSH_ACTIVITY"}
22:38:44.507 [DEBUG] [ntrol.internal.handler.AccountHandler] - checkData amazonechocontrol:account:f71ef12f finished
Can you have a look and give a feedback on this?
Thank you
Wawa
Hi @michi using your 2.7 binding and when I go to authorise the account, I get this
Anyone seen this? Tryed to delete the Account thing and reset it up. Everything was working fine before that
rg.openhab.binding.amazonechocontrol.internal.HttpException: POST url 'https://www.amazon.com/ap/signin/140-6969213-6284412' failed: Moved Temporarily
Powered by Jetty:// 9.4.11.v20180605
Same issue here as well. @Christoph_Zeh
Seems a common issue
Hope theres a resolution, I love this binding but its broken it all
Any way we can send a command to simulate the alarm function āAlexa, snoozeā I want to use a cheap Xiaomi button to trigger this command so I donāt have to yell at Alexa in the morning sleep in
