Did you have one of the bluetooth channels defined in the wha (Multiroom-Music) Thing type? Because this is not supported, but I do not check this in the binding if you create them in the items file.
No, I just had a few of the channels setup, such as control, volume, and the amazon play list one.
PLEASE HELP
Maybe it helps to get an official way to control echo devices if a lot of people like my idea in the amazon development forum: https://forums.developer.amazon.com/content/idea/107878/sdk-for-controlling-echo-devices.html
Please give me a like there!
Do you know if itâs technically possible to use 2FA with the mechanism youâre using to control the Echo? I donât want to try and get up to speed with how this works to find out itâs not possible.
No, I have never tried it
Hi all and thanks @michi for this good work. Just a question: Iâm using the sendcommand to the reminder in order to have spoken output and it is working quite well. Is it possibile to avoid the Alexaâs prefix such as âthis is a reminderâ or âIâm reminding youâŠâ at the start of the messages?
f
Sorry, no, this is done by the echo software.
Thanks. I liked your proposal for an SDK in the Amazon forum
I had login problems, too. I removed thing and recreated it after about 16 hours, then it was fine.
Thanks for the binding!
Done
Ahhhh thatâs a shame⊠I was just about to get this up and running as it sounds like the perfect solutionâŠ
I have everything set up and got reminders working using a simple Echo_Remind.sendCommand(âHello This is a testâ) but iâve noticed that ever since then every time I restart openhab my echo repeats the reminder. If I do a smarthome:status Echo_Remind it returns nothing so I think the item is empty and maybe the reminder is stuck in the binding somehow. Has anyone else run int that? Iâm using the version at the top of the OP (Beta 9)
Just setup device time zone at Alexa app.
Just brilliant, I do appreciate your efforts very much. Used amazon.de and your instructions worked like a charm.
Quick question and it might be a stretch, is it possible to be able to control the items that are certified to work with alexa. For instance there are some inexpensive wifi plugs and it would be fantastic if there was a way to control them via this binding without having to do anything else. Thanks.
Hi Fastcar550,
currently not, but I have already a private beta test with a other user running. Maybe itâs possible to control lamps and dimmers (write only, I will not get feedback from the devices) which are controlled with an Alexa Skill (regardless if the are certified or not). But unfortunately I have no such device and I test with the openHAB Alexa Skill (which is already working, but makes in reality no sense) and currently the test from my beta-tester fails. Please be patient.
Regards,
Michael
Thanks, I am standing by.
Looks like its not possible sending a reminder text to a multiroom group. Sending the text to one single echo works perfectly.
Yes this is true, multiroom groups does not support reminder and alarms (See the channel description). This limitation is by the amazon software, not by the binding. But you can create a virtual string item for the group in openHAB and a rule which sends the reminder to all alexas.
Regards, Michael
