Released: Openhab2 Amazon Echo Control Binding (controlling alexa from openhab2)
development
binding
alexa
Tags: #<Tag:0x00007fe0663163b8> #<Tag:0x00007fe066315fa8> #<Tag:0x00007fe066315be8>
(Markus S.) #631
Hi.
Have to re-login every 5-7days? Is this normal? Use openhab 2.3 and download the RC3 Version from market place. The logs shows an error by connecting but the account always go offline only after a restart of openhab.
Greetings,
Markus
(SiHui) #632
Why? The proper version for 2.3 stable is the version installed through PaperUI Addon, not the market place.
(Ben) #633
Uninstalled everything, cleaned tmp and cache and installed again via Paper UI. Added thing, getting no Session ID received. Will let it sit but I must admit I am not expecting it to solve magically, but I’ll give it a try mate :slight_smile:
(Markus S.) #634
Hi Sihui.
Yes, this version i had before. And after two times of re-login i saw in the post’s:
Wenn Sie die Seite http (s) öffnen: // youropenhab: port / amazonechocontrol (z. B. http: // localhost: 8080 / amazonechocontrol 3 ) können Sie überprüfen, ob die RC3 korrekt installiert ist. es sollte so aussehen:
RC3.
So i used this version. Because i can’t see RC3. But both gives the same result.
Already deleted the cache and temp folder. All things deleted, restart and new Installation.
Greetings,
Markus
(Joe Bishop) #635
Hey guys, this is a great Binding, I’m really enjoying getting a LOT more out of my Echo Dots than I ever thought possible, thanks to this!! TextToSpeech is freaking awesome, I’m enjoying plugging that in to some of my alert rules, fun!
I’m struggling with the “Routine” part. the guide indicates Type in what you normally say to Alexa without the preceding "Alexa," which I am interpreting to mean I can pass a string to Alexa in the same manner I would speak that phrase, and Alexa should respond “as if” I had verbally said that string. Just as an example, this is what I’ve tried (with no success):
.items file:
String DotRoutine {channel="amazonechocontrol:echo:myaccount:itemguidhere:startRoutine"}
.rules file:
  DotRoutine.sendCommand('what time is it?')
But, to no avail. I figured when the rule triggered, Alexa would blurt out “The time is 2:3ppm”. but no joy.
Am I missing something in my item or rule, or is this function simply not intended to do what I’m attempting?
thanks all!
(Sebastian) #636
Hey,
Routine is an Alexa feature so you do this in the Alexa app. There you can define a command Alexa should listen to and manually specify how alexa reacts on this command.
my use-case:
I have a routing calles “which windows are open” that triggers a proxy item (switch) within openhab. This switch triggers a rule, which then calculates windows, and uses TTS to have Alexa spit the reply.
The startRoutine channel is a bit different: Say you have manually created a routing called “start my day” and added Alexa items like reading the news, turning on lights, etc.
This routine can then be started like:
DotRoutine.sendCommand('start my day')
Hope this helps. Additions & corrections welcome.
Best Seb
(Ben) #637
So I let everything sit since yesterday as suggested - no luck. Still no session ID received and srever error.
(SiHui) #638
A while ago I had success using another browser … clearing the browsers cache should do the same.
(Ben) #639
Already tried that, even from multiple devices. As the error message states a 500 this clearly points towards Jetty itself but I have no clue how to further debug :frowning:
(Scott Rushworth) #640
After a reboot yesterday, I’m back to getting the error too.
(Joe Bishop) #641
Ahhhh… I see. I was hoping there was a way to silently send Alexa a command and have it respond as If I had actually said that. Just as an example, if I could send the string “what time is it” and when that executed, it would just verbally say “the time is…” but no luck there. Is there any way to do something like this today with the current Binding state?
(sujit) #642
This error is solved by
sudo systemctl stop openhab2.service
rm -rf /var/lib/openhab2/cache/*
rm -rf /var/lib/openhab2/tmp/*
sudo systemctl start openhab2.service
then http://:8080/amazonechocontrol/account1 - Re-login
Now it is working no error since last 24 hrs
But now when I select Amazon Music Playlist Id to Play play list defined in my amazon music library it gives following error
[nal.common.AbstractInvocationHandler] - An error occurred while calling method ‘ThingHandler.handleCommand()’ on ‘org.openhab.binding.amazonechocontrol.handler.EchoHandler@cc934d’: POST url ‘https://alexa.amazon.in/api/cloudplayer/queue-and-play?deviceSerialNumber=&deviceType=&mediaOwnerCustomerId=&shuffle=false’ failed: Bad Request
Not sure how to correct this ?
(Falk S.) #643
Strange: TTS stopped working:
I bought one of Alexa’s “sisters”, an Onkyo P3 speaker. This one replaced an Echo 1st gen.
While e.g. Remind-function works, TTS does not work any more with this specific device. It works with others (echos) though. The log shows normal activity as it does with the echos when a TTS command is sent. I checked configuration in Paper UI, .things file and rules.
The only difference I see for this device compared to my other echos is the length of the serial number. It has 32 characters instead of 16 for the echos.
Any known problems with “sister devices”?
(Running OH 2.3 with the official Amazon Echo Control 2.3 binding)
(Ercan Dogan) #644
Hello there,
I am impressed of this binding. It is really awesome. Downside is the communication between openhab server to alexa server. It slows down the commands. Does anybody know the reason why it is not supported by amazon for direct communication to the echo device?
Further to that I have a programming problem. I have the air quality value in my town. I check the value every hour and want to send a TTS command to alexa. Two values, number ‘quality index’ and string ‘air quality description’.
items:
Number AQI_No_Inside “Air Quality” (Living Room) {channel=“airquality:aqi:local:aqiLevel”}
String AQI_Description “Air Description” (Living Room) {channel=“airquality:aqi:local:aqiDescription”}
… ECHO items
Rule:
How should the command look like? It does not accept the string for example:
Echo_Living_Room_TTS.sendCommand(AQI_Description)
How does the command look like to let Alexa tell me the value of AQI_No_Inside_
Thanks in advance.
Regards
(Andrew Pawelski) #645
AQI_No_Inside.state.toString
(Ben) #646
Still no luck for me. Still server error.
(Alejandro) #647
Same thing is happening to me. Since this morning I’m getting this message every minute
2018-06-18 14:15:27.430 [INFO ] [mazonechocontrol.internal.Connection] - Login failed: Login fails. Check your credentials and try to login with your webbrowser to http(s)://<youropenhab:yourport>/amazonechocontrol/bc5a158d
Important Message! To better protect your account, please re-enter your password and then enter the characters as they are shown in the image below.
If I go to http(s)://youropenhab:yourport/amazonechocontrol/bc5a158d and click on the link, I get the amazon page asking for my password and a Captcha. If I fill the password and the captcha, it goes back to OH but it says “wrong password”.
Any clue??
(Ben) #648
I think it’s not the same thing as I don’t even see the login mask of Amazon but getting Server Error right away.
(Alejandro) #649
I’ve been digging a littlebit more and its even more extrange. The connection is flapping form online-offline.online.
I’ve changed account numbers and serials with some xxx. Don’t know if it’s relevant information, but just in case… (By the way, I have two echos connected to OH)
2018-06-17 04:09:27.401 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echo:bc5xxxxx:90F007186XXXXXX' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-06-17 04:09:28.330 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echo:bc5xxxxx:G090LF0964xxxxxxx' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-06-17 04:09:30.015 [hingStatusInfoChangedEvent] - 'amazonechocontrol:account:bc5xxxxx' changed from OFFLINE (CONFIGURATION_ERROR): Login fails. Check your credentials and try to login with your webbrowser to http(s)://<youropenhab:yourport>/amazonechocontrol/bc5xxxxx
Important Message! To better protect your account, please re-enter your password and then enter the characters as they are shown in the image below. to ONLINE
2018-06-17 04:09:30.017 [hingStatusInfoChangedEvent] - 'amazonechocontrol:flashbriefingprofile:bc5xxxxx:1' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-06-17 04:09:37.915 [me.event.ThingUpdatedEvent] - Thing 'zwave:device:3fd2e501:node7' has been updated.
2018-06-17 04:10:06.317 [hingStatusInfoChangedEvent] - 'amazonechocontrol:account:bc5xxxxx' changed from ONLINE to OFFLINE (CONFIGURATION_ERROR): Login fails. Check your credentials and try to login with your webbrowser to http(s)://<youropenhab:yourport>/amazonechocontrol/bc5xxxxx
2018-06-17 04:10:06.320 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echo:bc5xxxxx:90F007186XXXXXX' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-06-17 04:10:06.324 [hingStatusInfoChangedEvent] - 'amazonechocontrol:flashbriefingprofile:bc5xxxxx:1' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-06-17 04:10:06.327 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echo:bc5xxxxx:G090LF0964xxxxxxx' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-06-17 04:10:35.802 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echo:bc5xxxxx:90F007186XXXXXX' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-06-17 04:10:36.539 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echo:bc5xxxxx:G090LF0964xxxxxxx' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-06-17 04:10:38.480 [hingStatusInfoChangedEvent] - 'amazonechocontrol:account:bc5xxxxx' changed from OFFLINE (CONFIGURATION_ERROR): Login fails. Check your credentials and try to login with your webbrowser to http(s)://<youropenhab:yourport>/amazonechocontrol/bc5xxxxx
2018-06-17 04:10:38.485 [hingStatusInfoChangedEvent] - 'amazonechocontrol:flashbriefingprofile:bc5xxxxx:1' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-06-17 04:11:10.026 [hingStatusInfoChangedEvent] - 'amazonechocontrol:account:bc5xxxxx' changed from ONLINE to OFFLINE (CONFIGURATION_ERROR): Login fails. Check your credentials and try to login with your webbrowser to http(s)://<youropenhab:yourport>/amazonechocontrol/bc5xxxxx
2018-06-17 04:11:10.058 [hingStatusInfoChangedEvent] - 'amazonechocontrol:flashbriefingprofile:bc5xxxxx:1' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-06-17 04:11:10.062 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echo:bc5xxxxx:G090LF0964xxxxxxx' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-06-17 04:11:10.066 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echo:bc5xxxxx:90F007186XXXXXX' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-06-17 04:11:11.608 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echo:bc5xxxxx:90F007186XXXXXX' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-06-17 04:11:12.356 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echo:bc5xxxxx:G090LF0964xxxxxxx' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-06-17 04:11:14.153 [hingStatusInfoChangedEvent] - 'amazonechocontrol:account:bc5xxxxx' changed from OFFLINE (CONFIGURATION_ERROR): Login fails. Check your credentials and try to login with your webbrowser to http(s)://<youropenhab:yourport>/amazonechocontrol/bc5xxxxx
2018-06-17 04:11:14.158 [hingStatusInfoChangedEvent] - 'amazonechocontrol:flashbriefingprofile:bc5xxxxx:1' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-06-17 04:12:13.578 [hingStatusInfoChangedEvent] - 'amazonechocontrol:account:bc5xxxxx' changed from ONLINE to OFFLINE (CONFIGURATION_ERROR): Login fails. Check your credentials and try to login with your webbrowser to http(s
(Rick) #650
is this working in Australia / New Zealand?
I have the binding installed and the amazon account thing online but our echo and our dot are both showing as online, any ideas?
