No, the beta is not included in the snapshot-build.
Did you mean the TTS channel? What text have you provided? Can you test the āstartCommandā channel with the String āWeatherā, because this use the same technical base.
The āstartCommandā channel only supports the listed commands in the documentation (e.g. āWheaterā). No free text can be provided.
The only way to switch smarthome devices is using Alexa routines. These can be called from the binding with the āstartRoutineā.
Your monitoring script has been working great but after updating the binding to 2.4 Beta 1; Iām getting this error now for the script. The script still works thoughā¦ Any updates to this script to handle this exception? {snip}
Iām not using the latest echo control binding so I havenāt encountered that problem with the Amazon Online Status email rule. So for now I donāt have a revised rule to resolve the new issue. Perhaps you or another user can debug the rule and post a fix.
- Thomas
Yes, the TTS is what I use . . . hereās example of one of my scripts. Still works . . .
rule āJays Homeā
Item JsAndriodUnifi changed from OFF to ON
var Number hour = now.getHourOfDay
if (hour >= 8 && hour <= 21 && Home_Away.state == ON && InternetConnection.state == ON) {
// Echo talks
if (Echo_Basement_Volume.state!=UNDEF && Echo_Basement_Volume.state!=NULL) {
Echo_Basement_Volume.sendCommand('70')
Thread::sleep(2000) // 2 second wait
Echo_Basement_TTS.sendCommand(" Excuse me folks, I detect Jay's phone, so he must be home now.")
if (Echo_Loft_Volume.state!=UNDEF && Echo_Loft_Volume.state!=NULL) {
Echo_Loft_Volume.sendCommand('70')
Echo_Loft_TTS.sendCommand(" Excuse me folks, I detect Jay's phone, so he must be home now.")
if (Echo_Living_Room_Volume.state!=UNDEF && Echo_Living_Room_Volume.state!=NULL) {
Echo_Living_Room_Volume.sendCommand('50')
Echo_Living_Room_TTS.sendCommand(" Excuse me folks, I detect Jay's phone, so he must be home now.")
if (Echo_Garage_Volume.state!=UNDEF && Echo_Garage_Volume.state!=NULL) {
Echo_Garage_Volume.sendCommand('70')
Echo_Garage_TTS.sendCommand(" Welcome Home Jay, we've missed you.")
hour = null
Best, Jay
Ok thank you. I was able to get it to work using routines as you suggested. Thanks
Hi Mr. Wiseman,
I donāt have an idea for this problem. But maybe you will test my new beta version.
Regards,
Michael
Hi Michael,
Running your latest beta 2 on OH2.3 Synology; Iām getting this error with a clean reboot (clean cache and tmp directories). I did it twice just in case it was a one off . . .
at org.eclipse.osgi.container.Module.start(Module.java:444) [?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) [?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [9:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [9:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startAllBundles(DirectoryWatcher.java:1221) [9:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:515) [9:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [9:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [9:org.apache.felix.fileinstall:3.6.4]
2018-08-25 17:32:14.931 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/volume1/homes/openhab/addons/org.openhab.binding.amazonechocontrol_2.4.0.201808260018.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.amazonechocontrol [193]
Unresolved requirement: Import-Package: org.eclipse.jdt.annotation; resolution:=āoptionalā
Unresolved requirement: Import-Package: org.eclipse.jetty.websocket.api.annotations; version=ā9.3.22ā
Best, Jay
New Beta Version 2.4. (2)
I have created a new beta version with new features.
There is now a Web-Socket connection to the amazon server, so there is no polling anymore (The option for the polling interval is not yet removed, but the setting is ignored).
Please test if the channels are updated anyway correctly.
The second new feature is the new channel ālastVoiceCommandā. This can be used to write your own handle for a voice command. Just create an Alexa routine with do nothing for the command. Then create a rule triggered by the lastVoiceCommand channel and to your own handling.
You can download the new binding from the top most posting
There is currently no better solution for the login problems which have some users. I hope I can provide a better way in any of the future version.
Regards,
Michael
Please download it again, maybe I found the problem. I have changed the link.
Hi.
Has someone found a solution to check how long the TTS command will be played.
If i start a second one behind, i have to use timer. But this is no nice solution.
Greetings,
Markus
lastVoiceCommand
ā¦
lastVoiceCommand
ā¦
This is going to take this whole Alexa interaction thing on a whole new level, iām on it!
Iām not sure I understand the benefits of this over simply triggering an openHAB action after a Routine voice command.
Could someone give an example of a scenario where this could be used?
*any voice command
E.g. you can switch different items with the same voice command depending of the room (echo device)
wow this sounds greatā¦ going to play with this a bitā¦ thanks for this featureā¦
and i want to ask if another thing is possible to implementā¦
on the echo devices we have the hardware button for mute the echo (red led ring is active)
Is there any way to active this over the binding?
My activation word is āComputerā and if I watch some movies, docus ā¦ it often happens that Alexa is anoying meā¦ so for maximum lazinessā¦ i dont want to leave the couch to mute the deviceā¦
@michi do you think this is possible? Dont know if amazon is allowing the use of this button on software sideā¦
iām not sure yet if i seriously want to go that way, see voicecommands.js
it just sucks that alexa is always responding with ācanāt do this, canāt do thatā even though my openhab script successfully parsed the command. Maybe iāll just mute Alexa for everything but TTS, because honestly, all the built in features are kind of lame anyways. Maybe i can cover most of it with a routine, or iāll add a voice command to turn on/off āTTS Onlyā
okayā¦ thanksā¦
so i will try a solution with adding Alexa to a (zwave) wallplugā¦ to shut her downā¦ maybe with a rule with timer in it to bring her up after a couple of minutesā¦
Hi Michael,
Same thing . . . Hereās the file I used for the 2nd download this morning --> org.openhab.binding.amazonechocontrol_2.4.0.201808260052.jar
2018-08-26 08:31:15.139 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/volume1/homes/openhab/addons/org.openhab.binding.amazonechocontrol_2.4.0.201808260052.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.amazonechocontrol [187]
Unresolved requirement: Import-Package: org.eclipse.jetty.websocket.client
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:520) [9:org.apache.felix.fileinstall:3.6.4]
2018-08-26 08:31:15.188 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/volume1/homes/openhab/addons/org.openhab.binding.amazonechocontrol_2.4.0.201808260052.jar
Best, Jay
