Have you defined the thing in a file or in the paperUI? If you have defined it in paperUI, you have to delete and recreate them to get new channels. Otherwise maybe the beta version is not loaded or you use the an old jar file.
Please check if it works with Beta 2.4 (3)
Please check Beta 2.4 (3)
So is there any way in OpenHAB2 to control devices linked to an Echo Plus as a hub?
I use openhab almost only for this binding ( and maybe plex soon). I send all the node info to node-red to be able to control or be notified directly on my homeseer HS3 system ( on linux debian).
So, I âârm -rf openhab2ââ folder entirely, and started fresh on the 2.4 snaopshot #1349.
Installed your ver3 .jar files , and all is working perfectly!! Thanks
Now i just have to find a way to filter the word ââAlexaââ.
Let me explain the two way you can do it.
Saying on a fast manner ââ alexa turn off tvââ then the string in the last command will be : alexa turn off tv
Saying Alexa first, then wait 1 sec, then say ââ turn off tvââ then the string in the last command will be : turn of tv.
So depending off if i wait or not, i got to different string because alexa surely write two line when we wait.
Is there a way to filter the wold alexa on your side? I mean remove it if it apear, and keep the rest of the command ?
I tired to find a way to do that with node-red but no luck.
And creating two rule with two differents trigger on my hs3 system doe not work. The mqtt pluging just take one of the two at the same time. ( but that part is not important to you).
thank you,
matt
Thanks, the installation worked!
(Openhabian with openhab2_2.4.0~20180904183712-1)
However, after a few times, the âlastCommandâ channel does not update anymore. I can still see the PUSH_ACTIVITY coming in after a voice command, but the channel does not changeâŠ
(The Thing has been added via Paper UI, the Item has been defined in the config)
After a restart of openhab, the channel is working again for a few times.
Is there anyone looking at taking variable data from an echo? For example, be able to say âSet the volume to Xâ and then be able to use X in a rule?
I have a project for work that requires data input. If I can get the information from a spoken voice command into a rule I can then route that data where I need it.
Any input would be appreciated!
Same here
I removed all items and things, then deleted the addons/org.openhab.binding.amazonechocontrol_2.3.0.201801271315.jar file. Then added the binding in the paper UI that came with OH2.3. But now I donât see few channels than before. The reminder and bluetooth connection switch channels are gone. And I donât see any of the new channels. Confused.
You have to click on the option View more in the paperUI
Thanks for testing and reporting, I wil check this in my code
I will drop the keyword in my next relase, thanks for testing!
I dont think that this is possible because alexa will give you a answer that she do not know the command.
Anyway you would be able to handle the request with a rule to the lastCommand channel
Not yet
That did the trick!
In some of my rules I save the volume , set a new volume , make TTS announcement and then return volume to original state
Not sure if thatâs helpful but here is the code anyway
rule 'Windy mode On'
Item Windy_Switch changed from OFF to ON
if (Echo_Player.state == PLAY) {
val EchoVolumeState = storeStates(Echo_Volume)
logInfo("Alexa" , 'Player state '+ Echo_Player.state + ' volume '+ Echo_Volume.state)
sendMail('xxxxx', 'Openhab: Roof sensor detected high winds', 'Roof sensor detected high winds')
sendNotification('xxxxxx','Roof sensor detected high winds')
Echo_Player.sendCommand(PAUSE)
Thread::sleep(2000)
//play announcement
StatusAnnouncement.postUpdate('High winds have been detected')
//reset to original state
restoreStates(EchoVolumeState)
Thread::sleep(2000)
Echo_Player.sendCommand(PLAY)
else {
Echo_Volume.sendCommand(40)
Thread::sleep(2000)
sendMail('xxxxxx', 'Openhab: Roof sensor detected high winds', 'Roof sensor detected high winds')
sendNotification('xxxxx','Roof sensor detected high winds')
//play announcement
When I search for things my tablets donât show up anymore. I do see them in the amazonechocontrol page after I configure the account thing.
[update]
I added the tablets using the âAdd Manuallyâ, selecting Amazon Echo as the device type and the things work as expected.
Hello michi,
tanks for these great integration work. My system works perfectly.
I have one question:
Is it possible to have a channel of the amazon alexa reporting the ping / status Online/Offline like the network binding do with the other devices ?
Thanks for reply.
I setup this command in a rule
OfficeBot_StartARoutine.sendCommand(âAsk roomba to start cleaningâ)
I get this in the openhab.log
2018-09-08 18:27:48.573 [WARN ] [mazonechocontrol.internal.Connection] - Routine Ask roomba to start cleaning not found
When I say âAsk roomba to start cleaningâ - the roomba starts.
The documentation for the startRoutine says âWrite Only! Type in what you normally say to Alexa without the preceding âAlexa,ââ
So Iâm guessing the routines are not simply arbitrary Alexa request like âAlexa, what is the weatherâ - is there a command in the API that can do free form commands like âPlay MLBâ (next on my list - to automatically play Cubs gamesâŠ)?
And BTW - this Binding is awesome!
Some feedback with the latest beta.
-Complains about missing bundles seems to be gone
-error in logfile when lauching music throug sitemap (or habpanel)
2018-09-09 15:28:13.097 [ome.event.ItemCommandEvent] - Item 'Echo_Living_Room_Player' received command PLAY
2018-09-09 15:28:13.121 [vent.ItemStateChangedEvent] - Echo_Living_Room_Player changed from PAUSE to PLAY
2018-09-09 15:28:13.436 [ERROR] [nal.common.AbstractInvocationHandler] - An error occurred while calling method 'ThingHandler.handleCommand()' on 'org.openhab.binding.amazonechocontrol.handler.EchoHandler@abd273': POST url 'https://alexa.amazon.fr/api/behaviors/operation/validate' failed: Bad Request
org.openhab.binding.amazonechocontrol.internal.HttpException: POST url 'https://alexa.amazon.fr/api/behaviors/operation/validate' failed: Bad Request
at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequest(Connection.java:446) [216:org.openhab.binding.amazonechocontrol:2.4.0.201808261949]
Letâs wait for one week to see if Iâm logged out
Thank you
Aymeric
