No, there exist currently no API for this.
Of course, this could happen if something was changed in the core. In some cases a recompile against the new core source solves the problem. If I create a PR for the next changes, I can provide a version compatible with the lastest beta, but I do not know when I can finish my work for this.
I have not checked it yet, but of course this could happen.
Every version should work with them. But maybe amazon have changed something. I will check this with my next beta.
I have a good and a bad news for you. My next beta version will fix this issues. The bad news is, that it I do not know when I can provide it because I have a lot of open work for this.
Hello All,
I have very good news for all with login problems. I found now a new login-method which is working in a prototype. With this method, the binding will be registered as Mobile-App and this provides the possibility to renewal the session without a new login. The advantage will be:
- The binding must not store and use your amazon credentials in the OH configuration. No more password storing in plain text, yeah!!!
- 2 factor authentication can be supported
- No more login problems for the renewal of the session
- Not sure yet, but maybe you see the Online/Offline state of the binding in the Alexa-App
The bad news is, the method is currently implemented in a prototype and it is a lot of work to implement this in the binding. This is the reason, why I have no timeframe for the next beta version.
Another feature which I have planned for the binding is a new channel where you can control the volume of TTS messages form OH independently of of the standard volume.
Best regards,
Michael
Did you possibly manually edit the bindings in addons.cfg? If so, you will need to add this binding too. I donât have it installed anymore due to login issues, so I donât know what name it would be. Probably amazonechocontrol
This is awesome news! Keep up the good work. Canât wait until this is implemented in a binding that can be tested.
It takes as long as it takes, everyone has other tasks
@michi Can you please take a look at this post?
Alexa discover device issues due to Amazon Echo Control Binding items file
Hi All
Just installed this binding.
I get a tonne of error information in the log when OH2 starts up (and when I created all the items)
Any thoughts?
10:51:28.680 [WARN ] [onEchoDynamicStateDescriptionProvider] - Get playlist failed: {}
org.openhab.binding.amazonechocontrol.internal.HttpException: GET url 'https://alexa.amazon.com/api/cloudplayer/playlists?deviceSerialNumber=XXXX&deviceType=A32DOYMUN6DTXA&mediaOwnerCustomerId=XXXXH' failed: Bad Request
at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequest(Connection.java:404) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequestAndReturnString(Connection.java:286) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.makeRequestAndReturnString(Connection.java:281) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.Connection.getPlaylists(Connection.java:617) ~[?:?]
at org.openhab.binding.amazonechocontrol.internal.statedescription.AmazonEchoDynamicStateDescriptionProvider.getStateDescription(AmazonEchoDynamicStateDescriptionProvider.java:141) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ChannelStateDescriptionProvider.getDynamicStateDescription(ChannelStateDescriptionProvider.java:132) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ChannelStateDescriptionProvider.getStateDescription(ChannelStateDescriptionProvider.java:118) ~[?:?]
at org.eclipse.smarthome.core.thing.internal.ChannelStateDescriptionProvider.getStateDescriptionFragment(ChannelStateDescriptionProvider.java:80) ~[?:?]
at org.eclipse.smarthome.core.internal.service.StateDescriptionServiceImpl.mergeStateDescriptionFragments(StateDescriptionServiceImpl.java:104) ~[?:?]
at org.eclipse.smarthome.core.internal.service.StateDescriptionServiceImpl.getStateDescription(StateDescriptionServiceImpl.java:90) ~[?:?]
at org.eclipse.smarthome.core.items.GenericItem.getStateDescription(GenericItem.java:399) ~[?:?]
at org.eclipse.smarthome.io.rest.core.item.EnrichedItemDTOMapper.considerTransformation(EnrichedItemDTOMapper.java:110) ~[?:?]
at org.eclipse.smarthome.io.rest.core.item.EnrichedItemDTOMapper.map(EnrichedItemDTOMapper.java:62) ~[?:?]
at org.eclipse.smarthome.io.rest.core.item.EnrichedItemDTOMapper.map(EnrichedItemDTOMapper.java:56) ~[?:?]
at org.eclipse.smarthome.io.rest.core.internal.item.ItemResource.lambda$0(ItemResource.java:239) ~[?:?]
at java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:193) ~[?:?]
at java.util.ArrayList$ArrayListSpliterator.tryAdvance(ArrayList.java:1359) ~[?:?]
at java.util.stream.StreamSpliterators$WrappingSpliterator.lambda$initPartialTraversalState$0(StreamSpliterators.java:294) ~[?:?]
at java.util.stream.StreamSpliterators$AbstractWrappingSpliterator.fillBuffer(StreamSpliterators.java:206) [?:?]
at java.util.stream.StreamSpliterators$AbstractWrappingSpliterator.doAdvance(StreamSpliterators.java:169) [?:?]
at java.util.stream.StreamSpliterators$WrappingSpliterator.tryAdvance(StreamSpliterators.java:300) [?:?]
at java.util.Spliterators$1Adapter.hasNext(Spliterators.java:681) [?:?]
at org.eclipse.smarthome.io.rest.Stream2JSONInputStream.fillBuffer(Stream2JSONInputStream.java:94) [110:org.eclipse.smarthome.io.rest:0.10.0.201808242044]
at org.eclipse.smarthome.io.rest.Stream2JSONInputStream.read(Stream2JSONInputStream.java:70) [110:org.eclipse.smarthome.io.rest:0.10.0.201808242044]
at java.io.InputStream.read(InputStream.java:179) [?:?]
at java.io.InputStream.read(InputStream.java:101) [?:?]
at org.glassfish.jersey.message.internal.ReaderWriter.writeTo(ReaderWriter.java:115) [162:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.message.internal.AbstractMessageReaderWriterProvider.writeTo(AbstractMessageReaderWriterProvider.java:79) [162:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.message.internal.InputStreamProvider.writeTo(InputStreamProvider.java:105) [162:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.message.internal.InputStreamProvider.writeTo(InputStreamProvider.java:60) [162:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.invokeWriteTo(WriterInterceptorExecutor.java:265) [162:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.aroundWriteTo(WriterInterceptorExecutor.java:250) [162:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.message.internal.WriterInterceptorExecutor.proceed(WriterInterceptorExecutor.java:162) [162:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.server.internal.JsonWithPaddingInterceptor.aroundWriteTo(JsonWithPaddingInterceptor.java:106) [163:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:86) [163:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.message.internal.MessageBodyFactory.writeTo(MessageBodyFactory.java:1130) [162:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$Responder.writeResponse(ServerRuntime.java:711) [163:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$Responder.processResponse(ServerRuntime.java:444) [163:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:434) [163:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:329) [163:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [162:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [162:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [162:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [162:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [162:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [162:org.glassfish.jersey.core.jersey-common:2.22.2]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [163:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [163:org.glassfish.jersey.core.jersey-server:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.serviceImpl(WebComponent.java:473) [160:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.WebComponent.service(WebComponent.java:427) [160:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:388) [160:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:341) [160:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at org.glassfish.jersey.servlet.ServletContainer.service(ServletContainer.java:228) [160:org.glassfish.jersey.containers.jersey-container-servlet-core:2.22.2]
at com.eclipsesource.jaxrs.publisher.internal.ServletContainerBridge.service(ServletContainerBridge.java:76) [15:com.eclipsesource.jaxrs.publisher:5.3.1.201602281253]
at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:848) [78:org.eclipse.jetty.servlet:9.3.21.v20170918]
at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:584) [78:org.eclipse.jetty.servlet:9.3.21.v20170918]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceServletHandler.doHandle(HttpServiceServletHandler.java:71) [175:org.ops4j.pax.web.pax-web-jetty:6.0.9]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [77:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [75:org.eclipse.jetty.security:9.3.21.v20170918]
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) [77:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) [77:org.eclipse.jetty.server:9.3.21.v20170918]
at org.ops4j.pax.web.service.jetty.internal.HttpServiceContext.doHandle(HttpServiceContext.java:284) [175:org.ops4j.pax.web.pax-web-jetty:6.0.9]
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:512) [78:org.eclipse.jetty.servlet:9.3.21.v20170918]
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [77:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) [77:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [77:org.eclipse.jetty.server:9.3.21.v20170918]
at org.ops4j.pax.web.service.jetty.internal.JettyServerHandlerCollection.handle(JettyServerHandlerCollection.java:80) [175:org.ops4j.pax.web.pax-web-jetty:6.0.9]
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [77:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.Server.handle(Server.java:534) [77:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:333) [77:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:251) [77:org.eclipse.jetty.server:9.3.21.v20170918]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:283) [69:org.eclipse.jetty.io:9.3.21.v20170918]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:108) [69:org.eclipse.jetty.io:9.3.21.v20170918]
at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [69:org.eclipse.jetty.io:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [80:org.eclipse.jetty.util:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [80:org.eclipse.jetty.util:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [80:org.eclipse.jetty.util:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [80:org.eclipse.jetty.util:9.3.21.v20170918]
at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [80:org.eclipse.jetty.util:9.3.21.v20170918]
10:51:29.614 [WARN ] [onEchoDynamicStateDescriptionProvider] - Get playlist failed: {}
org.openhab.binding.amazonechocontrol.internal.HttpException: GET url 'https://alexa.amazon.com/api/cloudplayer/playlists?deviceSerialNumber=G090U50783942AMU&deviceType=A32DOYMUN6DTXA&mediaOwnerCustomerId=A1YQ3XDS7B4R5H' failed: Bad Request
at org.eclipse.smarthome.io.rest.core.item.EnrichedItemDTOMapper.map(EnrichedItemDTOMapper.java:66) ~[?:?]
I had the same errors when installing, I canât recall every change but I started by commenting out everything and working from there.
Thank you!
I got my devices to go online at last.
Build 1390 (as you stated).
Using the jar file quoted above above wouldnât even allow me to log into Amazon (login fail screen) so I went back to Beta 2.4 (3) Version and it allowed me to log in and my devides went online - although I had tried this before a few times.
So, it works but Iâm none-the-wiser.
Quick question: Is it possible to trigger an Alexa Routine with an OpenHAB thing/device? Although Iâm able to control things/devices through Alexa, these devices do not show-up as available triggers within Alexaâs Routine functionality. Do these type of devices require a special Amazon api/certification?
Thereâs a Start a routine channel for an Echo.
Details in the first post in this thread (although it states Switch there, itâs actually triggered by a string).
[EDIT]
Ah, minutes later the lastVoiceCommand changed to the old spoken commands, I think that is not normal, I will give it a try tomorrow again.
[/EDIT]
I want to use the new lastVoiceCommand feature, their for I build a small demo, just to see what is in the string, see below.
The light is turned on, but the error Log I used for debugging shows that the string is empty.
Sending a command to the same channel, e.g. âTestâ is spoken by Alexa, so configuration seem to be fine.
The next âLight onâ call shows âTestâ for lastVoiceCommand in the logs also.
So I think Iâm getting something wrong here, can someone explain or give an example how it is meant to be used? I thought I can check which echo had the last âLight onâ call or something like that, but the String/Item is always empty until I send a command to it.
Thanks for any help.
Greets Udo
rule "Light on"
Item Voice_Switch_Ambient received command ON
Light_Xiaomi_Bulb_V2_1_Command.send(new StringType("set_scene[\"ct\", 2800, 100]"))
logError("Amazon Alex said >", Speaker_Amazon_Echo_Show_Last_Voice_Command.state.toString)
String Speaker_Amazon_Echo_Show_Last_Voice_Command "Last voice command" {channel="amazonechocontrol:echoshow:account1:echoshow1:lastVoiceCommand"}
I since few days, i have some problems with the binding. The Amazon Account lost the connection every few seconds. The log is full of messages like this:
Wichtige Mitteilung! Zum besseren Schutz Ihres Kontos geben Sie bitte nochmals Ihr Passwort ein, und geben Sie dann die Zeichen ein, die in der Abbildung unten gezeigt werden.
2018-10-21 12:29:26.659 [hingStatusInfoChangedEvent] - 'amazonechocontrol:wha:XXXX' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-10-21 12:29:26.663 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echo:XXXX' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-10-21 12:29:26.668 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echo:XXXX' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-10-21 12:29:31.084 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echo:XXXX' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-10-21 12:29:31.922 [hingStatusInfoChangedEvent] - 'amazonechocontrol:wha:XXXX' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-10-21 12:29:33.393 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echo:XXXXX' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-10-21 12:29:36.463 [hingStatusInfoChangedEvent] - 'amazonechocontrol:account:XXXX' changed from OFFLINE (CONFIGURATION_ERROR): Login fails. Check your credentials and try to login with your webbrowser to http(s)://<youropenhab:yourport>/amazonechocontrol/48b4a4dc
Wichtige Mitteilung! Zum besseren Schutz Ihres Kontos geben Sie bitte nochmals Ihr Passwort ein, und geben Sie dann die Zeichen ein, die in der Abbildung unten gezeigt werden. to ONLINE
2018-10-21 12:30:28.558 [INFO ] [mazonechocontrol.internal.Connection] - Login failed: Login fails. Check your credentials and try to login with your webbrowser to http(s)://<youropenhab:yourport>/amazonechocontrol/XXXX
2018-10-21 12:30:31.571 [INFO ] [mazonechocontrol.internal.Connection] - Login failed: Login fails. Check your credentials and try to login with your webbrowser to http(s)://<youropenhab:yourport>/amazonechocontrol/XXXX
2018-10-21 12:30:31.577 [hingStatusInfoChangedEvent] - 'amazonechocontrol:account:XXXX' changed from ONLINE to OFFLINE (CONFIGURATION_ERROR): Login fails. Check your credentials and try to login with your webbrowser to http(s)://<youropenhab:yourport>/amazonechocontrol/48b4a4dc
2018-10-21 12:30:31.585 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echo:XXXX' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-10-21 12:30:31.589 [hingStatusInfoChangedEvent] - 'amazonechocontrol:wha:XXXX' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-10-21 12:30:31.593 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echo:XXXX' changed from ONLINE to OFFLINE (BRIDGE_OFFLINE)
2018-10-21 12:30:46.707 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echo:XXXX' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-10-21 12:30:47.674 [hingStatusInfoChangedEvent] - 'amazonechocontrol:wha:XXXX' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-10-21 12:30:49.251 [hingStatusInfoChangedEvent] - 'amazonechocontrol:echo:XXXX' changed from OFFLINE (BRIDGE_OFFLINE) to ONLINE
2018-10-21 12:30:52.198 [hingStatusInfoChangedEvent] - 'amazonechocontrol:account:XXXX' changed from OFFLINE (CONFIGURATION_ERROR): Login fails. Check your credentials and try to login with your webbrowser to http(s)://<youropenhab:yourport>/amazonechocontrol/48b4a4dc
