I’m still looking for a reliable working z-wave-switch for openHAB.
ZME_WALLC-S is a pain to pair and does not work for me.
POPP Wall Plug is working a little bit - but don’t try to touch the configuration…
Is there a well supported model, that will be found and recognized?
It’s not neccessary to dim - simple ON/OFF would be perfect for my needs…
Any Fibaro FGS switch or FGD dimmer can be configured to work as a scene controller, and if it’s just ON/OFF, you could use Qubinos (they have additional inputs) or use rules with ANY switch actuator that you don’t have directly attached any light to. You just have to attach a physical switch.
Both are companys I have already strugled with.
I have a Qubino Dim Dimmer (perfectly replaces any Eltako) but I did not get it to report a key press.
It reports the new dim level after on though and this is enough, too.
I switched to enocean-switches as wireless-solution.
Didn’t liked the Z-Wave-Pairing with battery enabled devices.
Enocean-Switches are energy harvesting - i.e. without battery. I don’t like their click-feeling - but it’s the most reliable solution so far for me…
