Every time I modify my sitemap everything appears to forget it’s state - anything that uses a background process to update itself is obviously quickly corrected (plex /hue/nest for example), but things that use contact sensors are only corrected when the door is opened/closed.
I’m using persistence so I sort of expected this to happen automatically, but I guess it doesn’t so is there a script I can use that will pull the last value and update everything not updated? I think an item has a .previousState() I could use.
you have to configure a “restoreonstartup” in your persistance.
Example:
Items {
// persist all items once a day and on every change and restore them from the db at startup
* : strategy = everyChange, everyDay, restoreOnStartup
I had a similar persist file and noticed it wasn’t doing the restoreOnStartup like I expected. When I ran it through the designer it underlined the default in the Items section in red. Once I changed that to everyChange it worked again.
