Hi All,
I am having issues with setting up my OH3 remote openhab server in my local network.
Both the local and remote OH3 servers are running 3.4.0 M2.
Here is the Remote Openhab Server Thing config on my local server:
I generated my API token on my remote OH Server and copied it over to the config above.
When I try to enable the Remote OH Server Thing on my local OH Server, I get a Comms error as follows:
And with the logs at DEBUG, I get the following:
2022-09-26 12:52:26.776 [INFO ] [openhab.event.ThingStatusInfoEvent ] - Thing 'remoteopenhab:server:451da4d58b' updated: INITIALIZING
2022-09-26 12:52:26.784 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'remoteopenhab:server:451da4d58b' changed from UNINITIALIZED (DISABLED) to INITIALIZING
2022-09-26 12:52:26.788 [DEBUG] [l.handler.RemoteopenhabBridgeHandler] - Initializing remote openHAB handler for bridge remoteopenhab:server:451da4d58b
2022-09-26 12:52:26.790 [DEBUG] [l.handler.RemoteopenhabBridgeHandler] - REST URL = https://192.168.91.235:8443/rest/
2022-09-26 12:52:26.791 [INFO ] [openhab.event.ThingStatusInfoEvent ] - Thing 'remoteopenhab:server:451da4d58b' updated: UNKNOWN
2022-09-26 12:52:26.792 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'remoteopenhab:server:451da4d58b' changed from INITIALIZING to UNKNOWN
2022-09-26 12:52:26.794 [INFO ] [openhab.event.ThingStatusInfoEvent ] - Thing 'remoteopenhab:thing:451da4d58b:rfxcom_bridge_3e75bf8f1c' updated: INITIALIZING
2022-09-26 12:52:26.794 [DEBUG] [l.handler.RemoteopenhabBridgeHandler] - Try the root REST API...
2022-09-26 12:52:26.795 [DEBUG] [nternal.rest.RemoteopenhabRestClient] - Request GET https://192.168.91.235:8443/rest/
2022-09-26 12:52:26.795 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'remoteopenhab:thing:451da4d58b:rfxcom_bridge_3e75bf8f1c' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2022-09-26 12:52:26.800 [INFO ] [openhab.event.ThingStatusInfoEvent ] - Thing 'remoteopenhab:thing:451da4d58b:rfxcom_blinds1_3e75bf8f1c_81fc023221' updated: INITIALIZING
2022-09-26 12:52:26.801 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'remoteopenhab:thing:451da4d58b:rfxcom_blinds1_3e75bf8f1c_81fc023221' changed from UNINITIALIZED (BRIDGE_UNINITIALIZED) to INITIALIZING
2022-09-26 12:52:26.802 [DEBUG] [al.handler.RemoteopenhabThingHandler] - initializing remote openHAB handler for thing remoteopenhab:thing:451da4d58b:rfxcom_blinds1_3e75bf8f1c_81fc023221
2022-09-26 12:52:26.804 [INFO ] [openhab.event.ThingStatusInfoEvent ] - Thing 'remoteopenhab:thing:451da4d58b:rfxcom_blinds1_3e75bf8f1c_81fc023221' updated: **OFFLINE** (BRIDGE_OFFLINE)
2022-09-26 12:52:26.805 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'remoteopenhab:thing:451da4d58b:rfxcom_blinds1_3e75bf8f1c_81fc023221' changed from INITIALIZING to **OFFLINE** (BRIDGE_OFFLINE)
2022-09-26 12:52:26.811 [DEBUG] [al.handler.RemoteopenhabThingHandler] - initializing remote openHAB handler for thing remoteopenhab:thing:451da4d58b:rfxcom_bridge_3e75bf8f1c
2022-09-26 12:52:26.829 [INFO ] [openhab.event.ThingStatusInfoEvent ] - Thing 'remoteopenhab:thing:451da4d58b:rfxcom_bridge_3e75bf8f1c' updated: **OFFLINE** (BRIDGE_OFFLINE)
2022-09-26 12:52:26.829 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'remoteopenhab:thing:451da4d58b:rfxcom_bridge_3e75bf8f1c' changed from INITIALIZING to **OFFLINE** (BRIDGE_OFFLINE)
2022-09-26 12:52:27.061 [DEBUG] [l.handler.RemoteopenhabBridgeHandler] - checkConnection for thing remoteopenhab:server:451da4d58b failed: Failed to execute the root REST API
org.openhab.binding.remoteopenhab.internal.exceptions.RemoteopenhabException: null
at org.openhab.binding.remoteopenhab.internal.rest.RemoteopenhabRestClient.tryApi(RemoteopenhabRestClient.java:179) ~[?:?]
at org.openhab.binding.remoteopenhab.internal.handler.RemoteopenhabBridgeHandler.checkConnection(RemoteopenhabBridgeHandler.java:376) ~[?:?]
at org.openhab.binding.remoteopenhab.internal.handler.RemoteopenhabBridgeHandler.lambda$0(RemoteopenhabBridgeHandler.java:182) ~[?:?]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:304) [?:?]
Caused by: org.openhab.binding.remoteopenhab.internal.exceptions.RemoteopenhabException: java.util.concurrent.ExecutionException: org.eclipse.jetty.client.HttpResponseException: HTTP protocol violation: Authentication challenge without WWW-Authenticate header
at org.openhab.binding.remoteopenhab.internal.rest.RemoteopenhabRestClient.executeUrl(RemoteopenhabRestClient.java:643) ~[?:?]
at org.openhab.binding.remoteopenhab.internal.rest.RemoteopenhabRestClient.executeGetUrl(RemoteopenhabRestClient.java:563) ~[?:?]
at org.openhab.binding.remoteopenhab.internal.rest.RemoteopenhabRestClient.tryApi(RemoteopenhabRestClient.java:162) ~[?:?]
... 8 more
Caused by: java.util.concurrent.ExecutionException: org.eclipse.jetty.client.HttpResponseException: HTTP protocol violation: Authentication challenge without WWW-Authenticate header
at org.eclipse.jetty.client.util.FutureResponseListener.getResult(FutureResponseListener.java:118) ~[?:?]
at org.eclipse.jetty.client.util.FutureResponseListener.get(FutureResponseListener.java:101) ~[?:?]
at org.eclipse.jetty.client.HttpRequest.send(HttpRequest.java:730) ~[?:?]
at org.openhab.binding.remoteopenhab.internal.rest.RemoteopenhabRestClient.executeUrl(RemoteopenhabRestClient.java:612) ~[?:?]
... 8 more
Caused by: org.eclipse.jetty.client.HttpResponseException: HTTP protocol violation: Authentication challenge without WWW-Authenticate header
at org.eclipse.jetty.client.AuthenticationProtocolHandler$AuthenticationListener.onComplete(AuthenticationProtocolHandler.java:164) ~[?:?]
at org.eclipse.jetty.client.ResponseNotifier.notifyComplete(ResponseNotifier.java:218) ~[?:?]
at org.eclipse.jetty.client.ResponseNotifier.notifyComplete(ResponseNotifier.java:210) ~[?:?]
at org.eclipse.jetty.client.HttpReceiver.terminateResponse(HttpReceiver.java:481) ~[?:?]
at org.eclipse.jetty.client.HttpReceiver.terminateResponse(HttpReceiver.java:461) ~[?:?]
at org.eclipse.jetty.client.HttpReceiver.responseSuccess(HttpReceiver.java:424) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.messageComplete(HttpReceiverOverHTTP.java:374) ~[?:?]
at org.eclipse.jetty.http.HttpParser.parseFields(HttpParser.java:1186) ~[?:?]
at org.eclipse.jetty.http.HttpParser.parseNext(HttpParser.java:1559) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.parse(HttpReceiverOverHTTP.java:208) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.process(HttpReceiverOverHTTP.java:148) ~[?:?]
at org.eclipse.jetty.client.http.HttpReceiverOverHTTP.receive(HttpReceiverOverHTTP.java:80) ~[?:?]
at org.eclipse.jetty.client.http.HttpChannelOverHTTP.receive(HttpChannelOverHTTP.java:131) ~[?:?]
at org.eclipse.jetty.client.http.HttpConnectionOverHTTP.onFillable(HttpConnectionOverHTTP.java:172) ~[?:?]
at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:311) ~[?:?]
at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:105) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$DecryptedEndPoint.onFillable(SslConnection.java:555) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection.onFillable(SslConnection.java:410) ~[?:?]
at org.eclipse.jetty.io.ssl.SslConnection$2.succeeded(SslConnection.java:164) ~[?:?]
at org.eclipse.jetty.io.ChannelEndPoint$1.run(ChannelEndPoint.java:104) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.runTask(EatWhatYouKill.java:338) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.doProduce(EatWhatYouKill.java:315) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.tryProduce(EatWhatYouKill.java:173) ~[?:?]
at org.eclipse.jetty.util.thread.strategy.EatWhatYouKill.run(EatWhatYouKill.java:131) ~[?:?]
at org.eclipse.jetty.util.thread.ReservedThreadExecutor$ReservedThread.run(ReservedThreadExecutor.java:409) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:883) ~[?:?]
at org.eclipse.jetty.util.thread.QueuedThreadPool$Runner.run(QueuedThreadPool.java:1034) ~[?:?]
... 1 more
2022-09-26 12:52:27.083 [DEBUG] [nternal.rest.RemoteopenhabRestClient] - Closing EventSource
2022-09-26 12:52:27.083 [DEBUG] [al.handler.RemoteopenhabThingHandler] - bridgeStatusChanged **OFFLINE** (COMMUNICATION_ERROR): @text/exception.root-rest-api-failed for thing remoteopenhab:thing:451da4d58b:rfxcom_bridge_3e75bf8f1c
2022-09-26 12:52:27.084 [INFO ] [openhab.event.ThingStatusInfoEvent ] - Thing 'remoteopenhab:server:451da4d58b' updated: **OFFLINE** (COMMUNICATION_ERROR): Failed to **execute** the root REST API
2022-09-26 12:52:27.084 [DEBUG] [al.handler.RemoteopenhabThingHandler] - bridgeStatusChanged **OFFLINE** (COMMUNICATION_ERROR): @text/exception.root-rest-api-failed for thing remoteopenhab:thing:451da4d58b:rfxcom_blinds1_3e75bf8f1c_81fc023221
2022-09-26 12:52:27.084 [DEBUG] [nternal.rest.RemoteopenhabRestClient] - EventSource stopped
2022-09-26 12:52:27.084 [INFO ] [ab.event.ThingStatusInfoChangedEvent] - Thing 'remoteopenhab:server:451da4d58b' changed from **UNKNOWN** to **OFFLINE** (COMMUNICATION_ERROR): Failed to **execute** the root REST API
Any ideas as to why this issue is happening?
Thanks!
