Thanks @apella12.
Yes, I did.
Thanks for the tip on deleting zwave\node.xml. I will give it a shot.
[Solved] Posting here if someone else has the same problem later. Turns out it was a caching problem in Firefox browser. Cleared the cache, and the ghost nodes were gone.
You finally made it home!! Hope you are settling in ok. Welcome back to Aotearoa.
Thanks - jumped from one set of lockdowns, straight into another
Picked the wrong city mate!
Yeah - it wasn’t really my first choice - I got head hunted, so ended up at the wrong end of the country. Still, we’re well out of the city, and it’s quite nice all the same.
I needed to remove 4 ghost nodes using Zensys. 2 of them showed as failed when sending a NOP and deleted no problem. 2 of them refused to show as failed even though I know they are off line. I finally got them to delete by choosing replace failed node, waiting 10 seconds and pressing cancel. After that I noticed the messages node deleted and then node added. The node was moved to the bottom of the list at which time the NOP, Is Failed, Delete Failed worked as expected.
