Remove additional components from Openhab
Hi Experts,
I have my openhab successfuully running open raspberry. Some time ago, I installed Grafana/InfluxDB and Node Red, but found both not really helfull for me. Which steps to I have to follow, to completely remove all these things? Is tehr any guide available?
Many thanks!
Matthias
If you are using a Linux based distro:
While this is not the right forum for that kind of question and the answer depends on a number of things you would need to mention, the (most likely) one is sudo apt purge grafana influxdb nodered
