At a minimum openhab should also be a member of the openhab group. If you are using a USB thumb drive it needs to also be a member of dialout. Beyond that I don’t think there are any other groups it needs to be a member of. If you use the GPIO binding it needs to be a member of gpio. If you use a bluetooth binding it should be a member of bluetooth. If you use say or an audio sink on that server it needs to be a member of audio. Finally, it might need to be a member of tty to use the Exec binding or executeCommandLine, though I could be wrong about that.
