I reopen this issue though it was discussed in because i don’t get the right answer.
As recommneded, i already tried the following steps:
- Server nginx to include keepalive_timeout=65 in nginx.conf
- I already configured everything according to nginx configuration
See below. But i am still getting a lot of timeout on openhabcloud client side.
location / {
proxy_pass http://localhost:3000;
proxy_redirect off;
proxy_http_version 1.1;
proxy_set_header Host $host;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
proxy_set_header X-Real-IP $remote_addr ;
proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for ;
proxy_set_header X-Forwarded-Proto http;
ERROR:
13:12:13.962 [EventThread] ERROR o.o.i.o.internal.CloudClient:205 - Error connecting to the openHAB Cloud instance: {}
io.socket.engineio.client.EngineIOException: xhr poll error
at io.socket.engineio.client.Transport.onError(Transport.java:63)
at io.socket.engineio.client.transports.PollingXHR.access$100(PollingXHR.java:26)
at io.socket.engineio.client.transports.PollingXHR$6$1.run(PollingXHR.java:140)
at io.socket.thread.EventThread$2.run(EventThread.java:80)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.net.SocketTimeoutException: timeout
at okio.Okio$4.newTimeoutException(Okio.java:230)
at okio.AsyncTimeout.exit(AsyncTimeout.java:285)
at okio.AsyncTimeout$2.read(AsyncTimeout.java:241)
at okio.RealBufferedSource.indexOf(RealBufferedSource.java:345)
at okio.RealBufferedSource.readUtf8LineStrict(RealBufferedSource.java:217)
at okio.RealBufferedSource.readUtf8LineStrict(RealBufferedSource.java:211)
at okhttp3.internal.http1.Http1Codec.readResponseHeaders(Http1Codec.java:189)
at okhttp3.internal.http.CallServerInterceptor.intercept(CallServerInterceptor.java:75)
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:92)
at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:45)
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:67)
at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.java:93)
at okhttp3.internal.http.BridgeInterceptor.intercept(BridgeInterceptor.java:93)
at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:120)
at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:185)
at okhttp3.RealCall$AsyncCall.execute(RealCall.java:135)
at okhttp3.internal.NamedRunnable.run(NamedRunnable.java:32)
… 3 common frames omitted
