I have the following question. I have a rule for xiaomi. How to make the playing of a melody for example 10 times?
rule “Открыта дверь” when
Item mihome_sensor_magnet_158d0002e29d73_isOpen changed from CLOSED
to OPEN then
if (mihome_gateway_7c49eb88f15c_volume.state == 100){
sendTelegram(“bot1”, “Сработала сигнализация”)
mihome_gateway_7c49eb88f15c_enableSound.sendCommand(ON)
mihome_gateway_7c49eb88f15c_sound.sendCommand(2)
executeCommandLine(“bash /home/orange/bot/sms.sh”)}
Is there an item which represents the play status (to get the information if playout is finished)?
mihome_gateway_7c49eb88f15c_enableSound.sendCommand(ON) this command starts playback
mihome_gateway_7c49eb88f15c_sound.sendCommand(2) This command indicates which melody to play.
I think I need to repeat this command. mihome_gateway_7c49eb88f15c_sound.sendCommand(2) with delay 5 sec.
The question was: Is there an item which represents the play status? Maybe mihome_gateway_7c49eb88f15c_enableSound
switches to OFF when playout is finished?
Yes
Then the easy solution is:
var Number nCount = -1 //counter
rule "Открыта дверь"
Item mihome_sensor_magnet_158d0002e29d73_isOpen changed from CLOSED to OPEN or
mihome_gateway_7c49eb88f15c_enableSound changed to OFF // playout ended
if(mihome_gateway_7c49eb88f15c_volume.state == 100 && mihome_sensor_magnet_158d0002e29d73_isOpen.state == OPEN) {
if(nCount == -1) { // start, send Telegram and sms
sendTelegram("bot1", "Сработала сигнализация")
executeCommandLine("bash /home/orange/bot/sms.sh")
if (nCount < 10) { // iteration
nCount += 1 // count up
else {
nCount = -1 // reset counter
Thank you. Tomorrow I will try
