0x2a
(Christian)
1
From time to time setting a value for my MAX! or homematic components fails.
21927 2021-11-17 21:10:29.108 [ERROR] [ternal.handler.HomematicThingHandler]
--100 No answer from device. (sending setValue()
21928 NEQ0933794:1
21929 SET_TEMPERATURE
21930 10.0
21931 )
21932 java.io.IOException: -100 No answer from device. (sending setValue()
21933 NEQ0933794:1
21934 SET_TEMPERATURE
21935 10.0
21936 )
Is there any way to catch this kind of exceptions or errors and repeat the last set value command?
Regards
Christian
rossko57
(Rossko57)
2
If the binding/protocol does not implement a retry strategy, you can construct your own. Some ideas here -
system
(system)
Closed
3
