Bit of a weird request but is there a way with a rule to set a default image for when an item eg Sonos artwork is null or undeff. When music stops my habpanel shows the broken image icon and I’d rather be able to specify and image to use itstead
Have a look at this thread. You may write a rule that detects if currentalbumart and/or currentalbumarturl is null. Then try to update the entry. Not sure if that works.
