Replace SD card with USB Data enabled
Running OH from RPI3+, with all data running on External SSD USB driver.
Something is messed up, and once in a while I don’t have access to openhab web-ui and nothing works.
To do so I need to run reinstall from SSH and I have few weeks of completely working system
(sudo apt install --reinstall openhab2)
I tend to think its the SD card who died on me, even that I have data moved to SD
$ mount | grep sda1
/dev/sda1 on / type ext4 (rw,noatime,data=ordered)
/dev/sda1 on /srv/openhab2-logs type ext4 (rw,noatime,data=ordered)
/dev/sda1 on /srv/openhab2-userdata type ext4 (rw,noatime,data=ordered)
/dev/sda1 on /srv/openhab2-sys type ext4 (rw,noatime,data=ordered)
/dev/sda1 on /srv/openhab2-conf type ext4 (rw,noatime,data=ordered)
/dev/sda1 on /srv/openhab2-addons type ext4 (rw,noatime,data=ordered)
Now, What procedure I should follow for replacing the SD card to new one ?
I used Win32Diskimager to read the SD and write new one the same application.
