Can anyone add the Popp thermostat (ZWE Connect), this is the same device as the Danfoss Living Connect thermostat but with actual temperature readback.
Here is a link the device:
This is the information i get from openhab: zwave:device:a954d855:node9
I do not know if this is enough to add it to the database. Please let me know if I can do more.
Please post the xml file from your /userdata/zwave
folder.
You could add it yourself:
https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-database-guide
does it get recognized as https://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/449 and the temp reading doesn’t work?
No it turns up as: Node 9 Unknown Device
And giving me these properties:
zwave_class_basic | ROUTING_SLAVE |
zwave_class_generic | THERMOSTAT |
zwave_neighbours | |
zwave_frequent | false |
zwave_nodeid | 9 |
zwave_version | 0.0 |
zwave_listening | false |
zwave_routing | true |
zwave_beaming | true |
zwave_class_specific | SETPOINT_THERMOSTAT |
And it do not look like the device do a correct Inclusion
post the xml please (and any additional info that you may have like a pdf user manual and a picture)
we can try to add it to the DB (you can also do this yourself)
I assume that you tried to wake it up multiple times… correct ?
You need to wake up the device so that the binding can perform the interrogation to get information required to identify it.
I have tried to wake the device many times. But I do not have Z-wave stick very close to the device. It is in the next room but this I think should not be the problem.
Should it do a correct Inclusion even if the device is not in the database?
The device got crasy after some wakeups and I had to remove the battery. Now get this info:
still unknown device but added wakeuptime
zwave_nodeid | 9 |
zwave_wakeup_time | 2018-11-15T08:28:34Z |
We still need
to find out what device you actually have.
I do not know how to get that information out yet. I will post back when I do!
Go to your /userdata/zwave/
folder, you will find several xml files, one for each of your devices. Pick that one which corresponds to your node in question.
ok file found:
> SENSOR_MULTILEVEL
<commandClass>THERMOSTAT_SETPOINT</commandClass> <commandClass>VERSION</commandClass> <commandClass>WAKE_UP</commandClass> </nodeInformationFrame> <supportedCommandClasses> <entry> <commandClass>CLIMATE_CONTROL_SCHEDULE</commandClass> <climateControlScheduleCommandClass> <version>1</version> <instances>1</instances> <versionSupported>1</versionSupported> </climateControlScheduleCommandClass> </entry> <entry> <commandClass>CLOCK</commandClass> <clockCommandClass> <version>1</version> <instances>1</instances> <versionSupported>1</versionSupported> </clockCommandClass> </entry> <entry> <commandClass>MANUFACTURER_SPECIFIC</commandClass> <manufacturerSpecificCommandClass> <version>1</version> <instances>1</instances> <versionSupported>1</versionSupported> <initSerialNumber>false</initSerialNumber> <deviceManufacturer>2</deviceManufacturer> <deviceType>277</deviceType> <deviceId>40976</deviceId> </manufacturerSpecificCommandClass> </entry> <entry> <commandClass>MULTI_CMD</commandClass> <multiCommandCommandClass> <version>1</version> <instances>1</instances> <versionSupported>1</versionSupported> </multiCommandCommandClass> </entry> <entry> <commandClass>THERMOSTAT_SETPOINT</commandClass> <thermostatSetpointCommandClass> <version>1</version>
After some restarts and some time waiting the device turned up as a Popp device
So far so good! Thanks!
