Request to update Z-Wave binding database for Inovelli Z-Wave Dimming Plug w/Built-in Repeater
I bought this one from Amazon, which is a Z-Wave Dimming Plug w/Built-in Repeater
After adding that as Thing, it says it unknown device with label: zwave:device:39ca3c65:node4 and status is online.
By looking at the doc, it looks like “The device is not in the database” and I need to do something like “the database must be updated and you should raise an issue to get this addressed.”
What does it mean? I need to update some file? Or some software update is required?
I clicked the “Show Properties” button and it shows:
zwave_class_basic ROUTING_SLAVE
zwave_class_generic MULTILEVEL_SWITCH
zwave_frequent false
zwave_neighbours 1
zwave_version 1.1
zwave_listening true
zwave_plus_devicetype LIGHT_DIMMER_SWITCH
zwave_deviceid 9984
zwave_nodeid 4
zwave_routing true
zwave_beaming true
zwave_class_specific POWER_SWITCH_MULTILEVEL
zwave_manufacturer 349
zwave_devicetype 9984
Could somebody help?
Thanks,
It’s already in the database:
http://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-list/devicesummary/662
Make sure the device is not to far away from the controller until it is fully initialized (the “unknown device label” should then disappear), then relocate it to the final destination.
If you need to know more about the database update read:
http://www.cd-jackson.com/index.php/zwave/zwave-device-database/zwave-device-database-guide
