Busy month at work - not much time to work on home automation but work is laxing up a bit!
I want to reset my HEM so KWH would go back to zero. I’ve read a bunch by @chris and my zwave xml (node2 not that it matters) seems to have TRUE. But when I look at the openhab2 doc (API) I don’t see anywhere to issue a “sensor_reset” like some of the OH1 examples I saw?
I suppose I could just make a new virtual item to store the value for KWH and then would never have to reset it - but reseting it would be ideal. I’m guessing this is stored on the Aeon Labs zwave device and not on the controller right?
When I set the state to 0 it naturally updates in a few minutes back to it’s saved value.
We probably need to add the meter_reset channel to the database - can you provide the link tothe device in the database and I’ll update it in a couple of days (I’m travelling at the moment and will be home tomorrow night).
Iv’e played in the database before - it’s on your site right? I think I can add it if it’s just a matter of adding that meter_reset somewhere specific? I think you need to approve anyway right? I can at least get it started?
I’ve just added it to the root endpoint - I can’t update the database tonight as I can’t access my server backend right now, but will do so tomorrow when I’m home.
You need to update the binding to the latest version, and you probably need to delete the thing and add it again. You don’t need to exclude it or anything - just delete the thing, click on the discovery button and it should be added back to the inbox, and approve it again…
I just had a look in the actual database file on github and this channel doesn’t seem to be present so there might be some sort of database synchronisation issue.
Hey @chris - I know you were busy and traveling. I got busy replacing my entire HVAC components and putting in a new wood stove, so I didn’t get a chance to come check.
Am I good to sort the binding to hopefully get the new reset capability?
hi guys on this issue. how do you use the channel? do you have a rule where you toggle the reset meter switch once a day? as it is on off - do you need to switch on and then off?
is there a delay needed between the two?
