Hi there,
i just wanted to ask if it’s possible to install the newest nightly without always replacing/resetting my openhab2.service.
I literally sat here for 2 hours, asking myself why my CUL sticks and BT presence detection was blown, just to see that my systemd service was once again set back to defaults.
I’d really appreciate any tips that could help me out…apart from the obvious “Made an update? Checked your services?”-PostIT.
That part about the CUL made me curious. I wasn’t able to get my CUL-stick running on user openhab so far, but since @ThomDietrich said so, I didn’t trust my setup anymore.
I started with a borrowed spare RaspPi 1, installed Openhabian with my setup files and it did work under user openhab. Great!
So I made the move with my RaspPi 2, installed Openhabian with my setup files and it DID NOT work??? What makes it evern worse it doesn’t work under user root either. The CUL-stick is working, checking via send the commands via “screen” which did work!
The log (using log:set DEBUG org.openhab.io.transport) after starting OH2 looks like:
14:55:10.324 [DEBUG] [org.openhab.io.transport.cul ] - BundleEvent [unknown:512] - org.openhab.io.transport.cul
14:55:10.328 [DEBUG] [org.openhab.io.transport.cul ] - BundleEvent STARTING - org.openhab.io.transport.cul
14:55:10.348 [DEBUG] [penhab.io.transport.cul.CULActivator] - CUL transport has been started.
14:55:10.424 [DEBUG] [io.transport.cul.internal.CULManager] - Registering class org.openhab.io.transport.cul.internal.serial.CULSerialHandlerImpl for device type serial
14:55:10.432 [DEBUG] [io.transport.cul.internal.CULManager] - Registering class org.openhab.io.transport.cul.internal.network.CULNetworkHandlerImpl for device type network
14:55:10.444 [DEBUG] [org.openhab.io.transport.cul ] - BundleEvent STARTED - org.openhab.io.transport.cul
14:55:10.557 [DEBUG] [io.transport.cul.internal.CULManager] - Trying to open device serial:/dev/ttyACM0 in mode SLOW_RF
14:55:10.559 [DEBUG] [io.transport.cul.internal.CULManager] - Searching class for device type serial
14:55:10.680 [DEBUG] [internal.serial.CULSerialHandlerImpl] - Opening serial CUL connection for /dev/ttyACM0
14:55:10.932 [DEBUG] [org.openhab.io.transport.serial ] - BundleEvent STARTING - org.openhab.io.transport.serial
14:55:10.936 [DEBUG] [org.openhab.io.transport.serial ] - BundleEvent STARTED - org.openhab.io.transport.serial
14:55:11.198 [ERROR] [io.transport.cul.CULLifecycleManager] - Can't open CUL
org.openhab.io.transport.cul.CULDeviceException: gnu.io.NoSuchPortException
at org.openhab.io.transport.cul.internal.serial.CULSerialHandlerImpl.openHardware(CULSerialHandlerImpl.java:100)[181:org.openhab.io.transport.cul:1.9.0.201612250211]
at org.openhab.io.transport.cul.internal.AbstractCULHandler.open(AbstractCULHandler.java:139)[181:org.openhab.io.transport.cul:1.9.0.201612250211]
Hey, thanks for your involvment during the XMas-days.
“My Setup-Files” All sub-directories under openhab2-Conf and the directory openhab2-userdata-persistence(in order to keep my DBs).
I’m using the Intertechno Binding.
I would have expected that it would work with user “root” again, as before, however it isn’t. I don’t think that the user “root” is any different to the standard Raspbian setup? (I’m just fishing in the dark).
I did the change on the my system today getting #674, the tests on the RaspPi1 have been made yesterday. Would that make any difference regarding this nrjavaserial change? If yes, the “observed” difference between the RaspPI versions was a false observation!
I saw the change was rolled back, did an update today and it seems to be running now. I need to confirm that when back home since I can’t verify that the CUL stick is sending while being away from home.
I’m back home now (“nearly on time” or “Thank you for travelling with Deutsche Bahn”).
Yes, the CUL-stick is working on the rolled back version (build #677). I’ve read all the hassle about the later changed nrjavaserial and will change to that next year:wink:
Thanks everybody for the work in between/during/instead of family times!
