aenotiad
(Andreas Enotiadis)
June 16, 2020, 4:29pm
1
Apologies if the answer is obvious - I did search diligently
Had a working Sitemap in 2.5.3 per below
Frame label="Shutters" {
Switch item=Shutters icon="rollershutter"
Frame label="First Floor Shutters" {
Switch item=FirstFloorShutters icon="rollershutter"
Shutters & FirstFloorShutters above are RollerShutter groups.
After upgrade to 2.5.5 the sitemap displays a switch instead of the UP-BUTTON-DOWN icons and, more importantly, the command issued when clicking is a switch ON/OFF.
In 2.5.3 it was displaying the right icons and sending the UP/DOWN/STOP commands to the group.
If I use Default instead of Switch in the sitemap I get the individual members of the group displayed properly and can control them individually but not as a group.
Do I have to use mappings now to create it?
rossko57
(Rossko57)
June 16, 2020, 5:47pm
2
Which UI, please? And could you confirm exact type of your Group(s)?
Instead of Switch have you tried Rollershutter?
Rollershutter item=Shutters icon="rollershutter"
Rollershutter item=FirstFloorShutters icon="rollershutter"
More information on Items can be found in the link
aenotiad
(Andreas Enotiadis)
June 16, 2020, 6:46pm
4
Basic UI & IOS App - exact same behaviour
The Groups are type Group and all members are type Rollershutter
rossko57
(Rossko57)
June 16, 2020, 6:56pm
5
Okay, you should define your Group as type Group:Rollershutter
aenotiad
(Andreas Enotiadis)
June 16, 2020, 7:00pm
6
Just tried it and OpenHAB barfed on Rollershutter
loop did not match anything at input 'Rollershutter'
Unfortunately.
rossko57
(Rossko57)
June 16, 2020, 7:29pm
7
Yes, there is no Rollershutter widget in sitemaps.
The Switch widget should recognize when a Rollershutter type Item is called, and render shutter buttons.
A Group would need characterizing as a Rollershutter type Group.
aenotiad
(Andreas Enotiadis)
June 16, 2020, 7:32pm
8
Ah - I thought Groups inherited their properties from their items. Will test tomorrow and report.
rossko57
(Rossko57)
June 16, 2020, 7:35pm
9
No, you have to be explicit for a Group’s “sub-type” - it may have members of several different types (including more Groups)
aenotiad
(Andreas Enotiadis)
June 17, 2020, 7:29am
10
Ok that works - so now we have to give explicit sub-type to the Group. Wonder why it was working in 2.5.3 w/o it
rossko57
(Rossko57)
June 17, 2020, 10:58am
11
This is not a new requirement, it’s from early openHAB-1. I cannot imagine how it ever worked before.
aenotiad
(Andreas Enotiadis)
June 19, 2020, 10:43am
12
Probably slipped through the cracks - makes sense to be the way it is
system
(system)
Closed
July 31, 2020, 2:43am
13
