I would want to build a thermostat for my ac unit.
I have one unit in my living room and one in the corridor.
I tried to hack the ac unit with an uart usb, but I failed.
So I imagine 2 ir controller to control the 2 ac unit, and an indoor thermometer (or several, to activate one or another ac unit)
Everything binded together with openhab and rules.
I would want a local system only, or if I need remote access, access it via openhab cloud.
Do you have any idea what I can buy to achieve that ?
I can diy if needed.
All completely local with no cloud/internet connections needed. Both the thermometers through Bluetooth gateway and IR-Wifi gateways interface with openHAB via mqtt, letting you define your cooling rules as desired.
Probably, if you implement the reverse engineered protocol for the thermometers on your Ubuntu system, which OpenMQTTGateway already has included, and/or if you install an alternative firmware onto them
which advertises their data without encryption.
Searching for “LYWSD03MMC” (the thermometers’ model number) on github does come up with several possibilities, e.g.
