How can I debug persistence data? All data sent by the weight sensor is automatically deleted after 24 hours and I do not understand why.
The data is sent by the post method with REST API: https://home.myopenhab.org/rest/items/my_sensor
After that I have this method to display the data in a table: https://home.myopenhab.org/rest/persistence/items/my_sensor
I added the .sensor in items like this: Number my_sensor "Weight Sensor"
The .persist is like this: my_sensor: strategy = everyUpdate, everyHour
I have exactly the same configuration for a temperature sensor … but the data it’s ok…doesn’t reset it.
The thig is that the data is displayed in the .sitemap and not through the REST API.
I don’t understand what’s the problem, for 2 days I’ve been trying to look in the log and 0 erros
I am an idiot…sorry for all the trouble but I will leave this here…if someone has the problem.
So…if you make a simple REST API - GET: https://home.myopenhab.org/rest/persistence/items/my_sensor
it will return all the data from THAT DAY (24hours)…
To get the date from the older days…you need to set the GET like this: https://home.myopenhab.org/rest/persistence/items/my_sensor?starttime=2021-03-01
The number of people having found out about that default setting of a REST call only by asking here in the forum and not by reading that statement on the API Explorer is somewhat uncountable.
I really missed that part of the API explorer …
Usually I’m used to reading the documentation before I work, but this time I kind of fucked up…that’s why I said I’m an idiot
