Maybe a real beginner question but i have updated my openhab from 2.3.x to 2.4 based on a problem with Tradfri, 10 min later i found out the problem is related to the problem with the tradrfi update. Well… On 2.4 there are new setup for enocean with the binding and i don’t have time to read all about and resetup my enocean stuff…
Can someone explane me how i can downgrade ? I use Openhab on a Raspy …
If you installed openHAB using apt-get you can downgrade with apt-get install openhab2=2.3.0 or whatever version you want.
Always make a backup before any bigger change!
Hey, based on the troubles related to the enocean binding for 2.4 i have installed the older binding 1.12.0 and now my stuff is working again … I will now buy first a second pi to check out before my girlfrind go crazy
