So far everything setup as suggested (though being in docker environment, managed it somehow).
I was then trying the hello-world.py example
from core.rules import rule
from core.triggers import when
@rule("Jython Hello World (cron decorators)", description="This is an example cron triggered rule using decorators", tags=["Test tag", "Hello World"])# [description and tags are optional]
@when("Time cron 0/10 * * * * ?")
def hellowWorldCronDecorators(event):
hellowWorldCronDecorators.log.info("Hello World!?!?!?")
but I only log entries that the script was execute, no “hello world” at all
==> /openhab/userdata/logs/openhab.log <==
2019-05-15 11:44:30.040 [DEBUG] [omation.core.internal.RuleEngineImpl] - The trigger 'Cron-hellowWorldCronDecorators-32a2678076f511e9839d2d236f51b29d' of rule '50f0c88c-9fcf-416b-b765-578b845303b3' is triggered.
2019-05-15 11:44:30.049 [DEBUG] [omation.core.internal.RuleEngineImpl] - The rule '50f0c88c-9fcf-416b-b765-578b845303b3' is executed.
I haven’t done any JSR223 scripting lately and neither kept track of the changes made so I don’t know why it is not working. However, I’m sure Scott’s first question will be what version of openHAB you are running.
yes! For logging in your rule, the rule decorator adds a log attribute to the function you’ve defined for the action. So, as in the hello_world.py example, you can use…
@rule("Test rule")
@when("Item Test_Item changed")
def testRule(event)
testRule.log("Test is a test")
If you want to log outside of a rule, you can use slf4j, but there is also a module for that. If you do something like this, you can just append to the default logger so that you don’t need to mess with the log levels…
from core.log import logging, LOG_PREFIX
log = logging.getLogger(LOG_PREFIX + ".TEST")
log.info("This is a test")
