Hello everyone!
Perhaps someone experienced this issue already. My knx binding is getting uninstalled every time I am restarting openhab with ‘service openhab2 restart’.
When I install it back it works just fine for the next restart.
Here is the part of my logfile from the system start:
2017-02-16 21:56:56.917 [DEBUG] [org.openhab.binding.knx ] - BundleEvent STARTING -
2017-02-16 21:56:56.966 [DEBUG] [ab.binding.knx.internal.KNXActivator] - KNX binding has been
started.
2017-02-16 21:56:57.005 [DEBUG] [org.openhab.binding.knx ] - ServiceEvent REGISTERED -
{org.openhab.binding.knx.config.KNXTypeMapper}={component.name=org.openhab.binding.knx.typemapper,
component.id=196, service.id=322, service.bundleid=218, service.scope=bundle} -
2017-02-16 21:56:57.301 [DEBUG] [org.openhab.binding.knx ] - ServiceEvent REGISTERED -
{org.openhab.model.item.binding.BindingConfigReader,
org.openhab.binding.knx.config.KNXBindingProvider,
org.openhab.core.autoupdate.AutoUpdateBindingProvider}=
{component.name=org.openhab.binding.knx.genericbindingprovider, component.id=197, service.id=323,
service.bundleid=218, service.scope=bundle} - org.openhab.binding.knx
2017-02-16 21:57:11.753 [DEBUG] [org.openhab.binding.knx ] - ServiceEvent REGISTERED -
{org.osgi.service.event.EventHandler, tuwien.auto.calimero.process.ProcessListener}=
{event.topics=openhab/*, component.name=org.openhab.binding.knx, component.id=195, service.id=326,
2017-02-16 21:57:11.857 [DEBUG] [.binding.knx.internal.bus.KNXBinding] - Calimero library version
2.3-beta
2017-02-16 21:57:11.877 [DEBUG] [x.internal.bus.KNXBusReaderScheduler] - Starting reader task.
2017-02-16 21:57:11.885 [DEBUG] [x.internal.bus.KNXBusReaderScheduler] - Starting schedule executor.
2017-02-16 21:57:11.885 [DEBUG] [al.bus.KNXBindingDatapointReaderTask] - Autorefresh: Waiting for
new item in reader queue
2017-02-16 21:57:11.889 [DEBUG] [org.openhab.binding.knx ] - ServiceEvent REGISTERED -
{org.osgi.service.cm.ManagedService}={service.pid=org.openhab.knx,
component.name=org.openhab.binding.knx.config, component.id=194, service.id=327,
2017-02-16 21:57:11.893 [DEBUG] [nx.internal.connection.KNXConnection] - KNXBinding configuration
present. Setting up KNX bus connection.
2017-02-16 21:57:11.897 [DEBUG] [nx.internal.connection.KNXConnection] - Not connected yet. Trying
to connect.
2017-02-16 21:57:11.902 [DEBUG] [org.openhab.binding.knx ] - ServiceEvent UNREGISTERING
- {org.osgi.service.cm.ManagedService}={service.pid=org.openhab.knx,
2017-02-16 21:57:11.903 [DEBUG] [org.openhab.binding.knx ] - BundleEvent STARTED -
2017-02-16 21:57:11.915 [DEBUG] [org.openhab.binding.knx ] - ServiceEvent UNREGISTERING
- {org.osgi.service.event.EventHandler, tuwien.auto.calimero.process.ProcessListener}=
2017-02-16 21:57:11.921 [DEBUG] [x.internal.bus.KNXBusReaderScheduler] - Terminating schedule
executor.
2017-02-16 21:57:11.922 [DEBUG] [x.internal.bus.KNXBusReaderScheduler] - Auto refresh scheduler
successfully terminated
2017-02-16 21:57:11.923 [DEBUG] [al.bus.KNXBindingDatapointReaderTask] - Autorefresh:
DatapointReaderTask wait on blockingqueue interrupted: null
2017-02-16 21:57:11.924 [DEBUG] [al.bus.KNXBindingDatapointReaderTask] - Autorefresh:
DatapointReaderTask interrupted.
2017-02-16 21:57:12.086 [INFO ] [nx.internal.connection.KNXConnection] - Established connection to
KNX bus on Knx-Router:3671 in mode TUNNEL.
2017-02-16 21:57:12.087 [DEBUG] [nx.internal.connection.KNXConnection] - Success: connected.
2017-02-16 21:57:12.092 [INFO ] [nx.internal.connection.KNXConnection] - Closing KNX connection
2017-02-16 21:57:12.125 [DEBUG] [org.openhab.binding.knx ] - ServiceEvent UNREGISTERING
- {org.openhab.binding.knx.config.KNXTypeMapper}={component.name=org.openhab.binding.knx.typemapper,
2017-02-16 21:57:12.130 [DEBUG] [org.openhab.binding.knx ] - ServiceEvent UNREGISTERING
- {org.openhab.model.item.binding.BindingConfigReader,
2017-02-16 21:57:12.153 [DEBUG] [org.openhab.binding.knx ] - BundleEvent STOPPING -
2017-02-16 21:57:12.161 [DEBUG] [ab.binding.knx.internal.KNXActivator] - KNX binding has been
stopped.
2017-02-16 21:57:12.164 [DEBUG] [org.openhab.binding.knx ] - BundleEvent STOPPED -
2017-02-16 21:57:12.200 [DEBUG] [org.openhab.binding.knx ] - BundleEvent UNRESOLVED -
2017-02-16 21:57:12.218 [DEBUG] [org.openhab.binding.knx ] - BundleEvent UNINSTALLED -
I’ve read similar post where they pointed to wrong entry in the addons.cfg file. But, I don’t see anything wrong there. knx is defined as 'binding = knx,…
I appreciate your help on that as it gets annoying after some time.
Thanks,
Krzysztof.
