- Platform information:
- Hardware: N/A
- OS: Ubuntu 20.04.2 LTS
- Java Runtime Environment: openjdk 11.0.11 2021-04-20 LTS
- openHAB version: 3.0.2
- Issue of the topic: After upgrading (via apt) from OH 3.0.1 to 3.0.2, OH does not seem to initialize when using systemctl. I have been using OH 3 since soon after its stable release and it has been fine, starts on boot, etc. But after upgrading to 3.0.2 (and openjdk was also upgraded, but not sure what the previous version was), it will show the openhab process running and a systemctl status openhab.service says it is running with no errors, but there are no logs generated in /var/log/openhab and the system is not responsive. However, when I run systemctl stop openhab.service then run the start command manually (sudo su -s /bin/bash -c /usr/share/openhab/start.sh openhab) it starts up fine, I see logs being written to in /var/log/openhab, and the system works.
Were there any changes to the systemctl stuff in 3.0.2? Anything else I can check?
