Rest api put item state return 202, but the light not update
Dimmer   LR9_ColorTemperature   "Color temperature"   {channel="hue:0220:001788adb5ef:19:color_temperature"}
Dimmer LR9_Brightness “Brightness” {channel=“hue:0220:001788adb5ef:19:brightness”}
String LR9_Alert “Alert” {channel=“hue:0220:001788adb5ef:19:alert”}
Switch LR9_Effect “Color loop” {channel=“hue:0220:001788adb5ef:19:effect”}
I can put item state success , When I get item state , I saw the value is changed, but the light no update.
I try this :
curl -X PUT --header “Content-Type: text/plain” --header “Accept: application/json” -d “70” “http://192.168.50.245:38080/rest/items/LR9_Brightness/state
the I got response code: 202
But the hue light not update
PUT issues an update to the Item. POST issues a command. See https://www.openhab.org/docs/configuration/rules-dsl.html#manipulating-item-states
Updates only changes the state of an Item in openHAB. Commands get forwarded to the binding and therefore the device. You can’t turn on a light using an update, you have to use a command.
thx , I post command to the item and it work 。
