Restarting OpenHab stops network devices
ok, its SDDP, as soon as i enable it on Openhab, i see devices are disconnecting
I even see the link going down for a few seconds on my switch for some devices!
How can i trace the culprint? i checked my switch logs and my router logs, but dont see anything there :frowning:
As previously suggested, run a wireshark capture (or just tcpdump in the terminal) on the OH host to see what traffic it sends. It could be some issue with OH and HA both sending discovery packets, but it seems a bit strange to me. But we need traffic logs to know for sure.
ok, best to filter port 1900 only with tcpdump ? i did an tcpdump on port 1900
nothing strange to see, see below, 192.168.0.20 is for example my denon receiver, that gets a drop off when i start the ssdp discovery
HOST: 239.255.255.250:1900
MAN: "ssdp:discover"
ST: upnp:rootdevice
MX: 5
gŠg”C
 a  a         	ÐM]  E Mš@ ,ìÀ¨ ïÿÿú¾jal9:ïNOTIFY * HTTP/1.1
CACHE-CONTROL: max-age=60
LOCATION: http://192.168.0.15:8080/sabnzbd/description.xml
SERVER: SABnzbd
NT: upnp:rootdevice
USN: uuid:ab677cc5-fd4c-3ed1-80bd-00f2d14b5ca1::upnp:rootdevice
NTS: ssdp:alive
OPT: "http://schemas.upnp.org/upnp/1/0/"; ns=01
oŠg$k	 •   •          	ÐM]  E  ¥w@ #CÀ¨ ïÿÿúä‡al mo^M-SEARCH * HTTP/1.1
ST: upnp:rootdevice
MX: 5
uŠg“C	 ¯  ¯          )6yš  E ›×~@ ïÀ¨ ïÿÿú¤²al‡²LNOTIFY * HTTP/1.1
NTS:ssdp:alive
HOST:239.255.255.250:1900
CACHE-CONTROL:max-age=1800
SERVER:async-upnp-client/0.40.0 UPnP/2.0 Server/1.0
BOOTID.UPNP.ORG:1729539158
CONFIGID.UPNP.ORG:1
NT:urn:home-assistant.io:device:HomeAssistant:1
USN:UUID:B436CCF3-22F9-4B78-8B7E-094D302FBDAD::urn:home-assistant.io:device:HomeAssistant:1
uŠgH	 Ì  Ì  †Ý       )6yš  `H¥þ€      MþCo„ð ÿ             ²ëalÁ÷NOTIFY * HTTP/1.1
NTS:ssdp:alive
HOST:[FF02::C]:1900
CONFIGID.UPNP.ORG:1
LOCATION:http://[fe80::4dfe:1543:6f84:f000]:40000/device.xml
vŠg©E
 a  a         	ÐM]  E M«@ eæÀ¨ ïÿÿú¥al9TSNOTIFY * HTTP/1.1
SERVER: SABnzbd
NT: upnp:rootdevice
NTS: ssdp:alive
yŠg/q	 •   •          	ÐM]  E  µŸ@ eÀ¨ ïÿÿúä‡al mo^M-SEARCH * HTTP/1.1
ST: upnp:rootdevice
MX: 5
|ŠgH  ¼   ¼           ÍAE  E  ¨   @ɆÀ¨ ïÿÿú„al ”?ÏM-SEARCH * HTTP/1.1
MX: 5
ST: urn:schemas-dm-holdings-com:service:X_WholeHomeAudio:1
|ŠgŽ. -  -          ÍAE00E
  À¨ ïÿÿú
alÖPNOTIFY * HTTP/1.1
CACHE-CONTROL: max-age=1800
CONTENT-LENGTH: 0
NT: upnp:rootdevice
NTS: ssdp:byebye
USN: uuid:5f9ec1b3-ff59-19bb-8530-0005cd410145::upnp:rootdevice
|Šg¢Ù µ   µ           ÍAEicE  ¡   @ÉŠÀ¨ ïÿÿú„al <M-SEARCH * HTTP/1.1
MX: 5
ST: urn:schemas-upnp-org:service:ContentDirectory:1
|Šg¦À 6  6          ÍAEteE "   	À¨ ïÿÿú
aläNOTIFY * HTTP/1.1
CONTENT-LENGTH: 0
NT: uuid:5f9ec1b3-ff59-19bb-8530-0005cd410145
NTS: ssdp:byebye
|Šg"l ½   ½           ÍAE  E  ©
  @É€À¨ ïÿÿú„al •DM-SEARCH * HTTP/1.1
MX: 5
ST: urn:microsoft.com:service:X_MS_MediaReceiverRegistrar:1
|Šg¸R e  e          ÍAE  E Q   ØÀ¨ ïÿÿú
al=¾ÉNOTIFY * HTTP/1.1
CONTENT-LENGTH: 0
NT: urn:schemas-upnp-org:device:MediaRenderer:1
NTS: ssdp:byebye
USN: uuid:5f9ec1b3-ff59-19bb-8530-0005cd410145::urn:schemas-upnp-org:device:MediaRenderer:1
|Šgþ µ   µ           ÍAE  E  ¡   @ɆÀ¨ ïÿÿú„al ðM-SEARCH * HTTP/1.1
MX: 5
ST: urn:schemas-intel-com:service:PowerManagement:1
|ŠgNæ m  m          ÍAE  E Y   ÎÀ¨ ïÿÿú
alEÓÎNOTIFY * HTTP/1.1
CONTENT-LENGTH: 0
NT: urn:schemas-upnp-org:service:RenderingControl:1
NTS: ssdp:byebye
USN: uuid:5f9ec1b3-ff59-19bb-8530-0005cd410145::urn:schemas-upnp-org:service:RenderingControl:1
|Šg\ ´   ´           ÍAE  E      @É…À¨ ïÿÿú„al Œ†ÇM-SEARCH * HTTP/1.1
MX: 5
ST: urn:schemas-upnp-org:service:WANIPConnection:1
|Šg|wa o  o          ÍAE  E [   ÊÀ¨ ïÿÿú
alGŸfNOTIFY * HTTP/1.1
CONTENT-LENGTH: 0
NT: urn:schemas-upnp-org:service:ConnectionManager:1
NTS: ssdp:byebye
USN: uuid:5f9ec1b3-ff59-19bb-8530-0005cd410145::urn:schemas-upnp-org:service:ConnectionManager:1
|ŠgÏ" ¶   ¶           ÍAE  E  ¢   @ɁÀ¨ ïÿÿú„al ŽÉvM-SEARCH * HTTP/1.1
MX: 5
ST: urn:schemas-digion-com:service:X_AccessControl:1
|Šgß		 c  c          ÍAE  E O   ÔÀ¨ ïÿÿú
al;#ÍNOTIFY * HTTP/1.1
CONTENT-LENGTH: 0
NT: urn:schemas-upnp-org:service:AVTransport:1
NTS: ssdp:byebye
USN: uuid:5f9ec1b3-ff59-19bb-8530-0005cd410145::urn:schemas-upnp-org:service:AVTransport:1
|ŠgJµ	 °   °           ÍAE  E  œ   @É…À¨ ïÿÿú„al ˆœM-SEARCH * HTTP/1.1
MX: 5
ST: urn:schemas-digion-com:service:X_Landisk:1
|ŠgÛG ¯   ¯           ÍAE  E  ›   @É…À¨ ïÿÿú„al ‡GËM-SEARCH * HTTP/1.1
MX: 5
ST: urn:schemas-upnp-org:device:MediaServer:1
|Šgª” <  <          ÍAEONE (   øÀ¨ ïÿÿú
alÀòNOTIFY * HTTP/1.1
NT: upnp:rootdevice
NTS: ssdp:alive
SERVER: KnOS/3.2 UPnP/1.0 DMP/3.5
second, test, i disabled sddp in openhab:
restarted openhab and did a wireshark dump, i still see an ssdp discovery… why is it still doing sddp when i restart? 0.20 is the IP of my denon receiver
I don’t know a whole lot about SDDP. Some searching shows it’s maybe a proprietary protocol owned by Control4. I wouldn’t be surprised if having both HA and OH using it at the same time caused problems.
But this is an easy test. What happens if you restart OH with SDDP on but with SDDP off in HA (or HA not running)? If that works what happens when you re-enable/start HA again? If the behavior is the same, that’s strong evidence that having two SDDP controllers(?) on the same network confuses some devices.
Given that SDDP by all appearances is not something super commonly used, maybe you can get by with it disabled in OH. It’s still worth exploring the root cause here but I also want to get you to a point where you can continue your OH explorations despite this problem.
yeah, thats my issue, i use HA as main, and installed OpenHab as an addon on HA
so i cant turn off HA :slight_smile: and run Openhab seperately
gonna change my addon, so i can start openhab in debug mode, seems there is no cli command to show debug, maybe i can see more there
or i can see if i can disable ssdp in HA
tbc
Individual add-ons can be put into debug logging using Settigns → Add-on Settings → Binding
For OH 4 you can edit $OH_USERDATA/etc/log4j2.xml, issue commands from the karaf console, or use the REST API. Logging | openHAB
To use the REST API go to Developer Tools → API Explorer → logging → PUT to modify or add a logger and enter org.openhab for the logger and DEBUG for the level.
Changes to the loggers, no matter how they are made, are persisted across OH restarts so be sure to change them back when you are done.
But surely you can turn it off long enough to run a test to confirm that the cause is that both are using SDDP at the same time and not some other issue with the way OH implements SDDP. I’m not suggesting shutting HA down permamantly.
I think it should be SSDP (Simple Service Discovery Protocol), used by UPnP.
The add-on settings says SDDP.
SSDP I am familiar with and I can’t see any way how that would cause any problems like this, it just sends out a broadcast packet. I’m assuming @Fabio_Pergola is correct when he says “SDDP” and would have expected him to say “UPnP” if that were the cause of the problem since that’s how that is labeled in the settings.
ok, gonna try this later, whats is the default log level to revert after DEBUG? is it WARNING ?
INFO is the default log level.
ok, here is the DEBUG, not sure if you can see anything wrong?
2024-10-22 16:52:04.050 [DEBUG] [core.karaf.internal.FeatureInstaller] - bundle org.openhab.core.karaf:4.2.2 (196)[org.openhab.core.karaf.internal.FeatureInstaller(204)] : ConfigurableComponentHolder configuration updated for pid org.openhab.addons with change count 195
2024-10-22 16:52:04.054 [DEBUG] [core.karaf.internal.FeatureInstaller] - bundle org.openhab.core.karaf:4.2.2 (196)[org.openhab.core.karaf.internal.FeatureInstaller(204)] : Querying state active
2024-10-22 16:52:04.055 [DEBUG] [core.karaf.internal.FeatureInstaller] - bundle org.openhab.core.karaf:4.2.2 (196)[org.openhab.core.karaf.internal.FeatureInstaller(204)] : Querying state active
2024-10-22 16:52:04.056 [DEBUG] [core.karaf.internal.FeatureInstaller] - bundle org.openhab.core.karaf:4.2.2 (196)[org.openhab.core.karaf.internal.FeatureInstaller(204)] : invoking modified: modified: parameters [org.apache.felix.scr.impl.helper.ReadOnlyDictionary]
2024-10-22 16:52:04.061 [DEBUG] [core.karaf.internal.FeatureInstaller] - bundle org.openhab.core.karaf:4.2.2 (196)[org.openhab.core.karaf.internal.FeatureInstaller(204)] : invoked modified: modified
2024-10-22 16:52:04.063 [DEBUG] [core.karaf.internal.FeatureInstaller] - bundle org.openhab.core.karaf:4.2.2 (196)[org.openhab.core.karaf.internal.FeatureInstaller(204)] : No change in target property for dependency $000: currently registered: true
2024-10-22 16:52:04.068 [DEBUG] [core.karaf.internal.FeatureInstaller] - bundle org.openhab.core.karaf:4.2.2 (196)[org.openhab.core.karaf.internal.FeatureInstaller(204)] : No change in target property for dependency $001: currently registered: true
2024-10-22 16:52:04.069 [DEBUG] [core.karaf.internal.FeatureInstaller] - bundle org.openhab.core.karaf:4.2.2 (196)[org.openhab.core.karaf.internal.FeatureInstaller(204)] : No change in target property for dependency $002: currently registered: true
2024-10-22 16:52:04.069 [DEBUG] [core.karaf.internal.FeatureInstaller] - bundle org.openhab.core.karaf:4.2.2 (196)[org.openhab.core.karaf.internal.FeatureInstaller(204)] : No change in target property for dependency $003: currently registered: true
2024-10-22 16:52:04.075 [DEBUG] [core.karaf.internal.FeatureInstaller] - bundle org.openhab.core.karaf:4.2.2 (196)[org.openhab.core.karaf.internal.FeatureInstaller(204)] : No change in target property for dependency osgi.ds.satisfying.condition: currently registered: true
2024-10-22 16:52:04.078 [DEBUG] [core.karaf.internal.FeatureInstaller] - bundle org.openhab.core.karaf:4.2.2 (196)[org.openhab.core.karaf.internal.FeatureInstaller(204)] : Querying state active
2024-10-22 16:52:04.083 [DEBUG] [raf.internal.KarafAddonFinderService] - bundle org.openhab.core.karaf:4.2.2 (196)[org.openhab.core.karaf.internal.KarafAddonFinderService(205)] : dm $000 tracking 8 SingleStatic modified {org.openhab.core.karaf.internal.FeatureInstaller, org.osgi.service.cm.ConfigurationListener}={service.id=331, suggestionFinderUsb=false, service.bundleid=196, service.scope=bundle, core-config-discovery-addon=,sddp, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), binding=mqtt, transformation=jinja,jsonpath, component.name=org.openhab.addons, service.config.label=Add-on Management, component.id=204, service.config.factory=false, suggestionFinderIp=false, suggestionFinderMdns=false, service.config.category=system, suggestionFinderSddp=true, service.config.description.uri=system:addons, service.pid=org.openhab.addons, suggestionFinderUpnp=false} (enter)
2024-10-22 16:52:04.083 [DEBUG] [core.karaf.internal.FeatureInstaller] - Installing 'openhab-core-config-discovery-addon-sddp'
2024-10-22 16:52:04.087 [DEBUG] [raf.internal.KarafAddonFinderService] - bundle org.openhab.core.karaf:4.2.2 (196)[org.openhab.core.karaf.internal.KarafAddonFinderService(205)] : dm $000 tracking 8 SingleStatic modified {org.openhab.core.karaf.internal.FeatureInstaller, org.osgi.service.cm.ConfigurationListener}={service.id=331, suggestionFinderUsb=false, service.bundleid=196, service.scope=bundle, core-config-discovery-addon=,sddp, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), binding=mqtt, transformation=jinja,jsonpath, component.name=org.openhab.addons, service.config.label=Add-on Management, component.id=204, service.config.factory=false, suggestionFinderIp=false, suggestionFinderMdns=false, service.config.category=system, suggestionFinderSddp=true, service.config.description.uri=system:addons, service.pid=org.openhab.addons, suggestionFinderUpnp=false} (exit)
2024-10-22 16:52:04.088 [DEBUG] [ore.karaf.internal.KarafAddonService] - bundle org.openhab.core.karaf:4.2.2 (196)[org.openhab.core.karaf.internal.KarafAddonService(206)] : dm $000 tracking 9 SingleStatic modified {org.openhab.core.karaf.internal.FeatureInstaller, org.osgi.service.cm.ConfigurationListener}={service.id=331, suggestionFinderUsb=false, service.bundleid=196, service.scope=bundle, core-config-discovery-addon=,sddp, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), binding=mqtt, transformation=jinja,jsonpath, component.name=org.openhab.addons, service.config.label=Add-on Management, component.id=204, service.config.factory=false, suggestionFinderIp=false, suggestionFinderMdns=false, service.config.category=system, suggestionFinderSddp=true, service.config.description.uri=system:addons, service.pid=org.openhab.addons, suggestionFinderUpnp=false} (enter)
2024-10-22 16:52:04.095 [DEBUG] [ore.karaf.internal.KarafAddonService] - bundle org.openhab.core.karaf:4.2.2 (196)[org.openhab.core.karaf.internal.KarafAddonService(206)] : dm $000 tracking 9 SingleStatic modified {org.openhab.core.karaf.internal.FeatureInstaller, org.osgi.service.cm.ConfigurationListener}={service.id=331, suggestionFinderUsb=false, service.bundleid=196, service.scope=bundle, core-config-discovery-addon=,sddp, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), binding=mqtt, transformation=jinja,jsonpath, component.name=org.openhab.addons, service.config.label=Add-on Management, component.id=204, service.config.factory=false, suggestionFinderIp=false, suggestionFinderMdns=false, service.config.category=system, suggestionFinderSddp=true, service.config.description.uri=system:addons, service.pid=org.openhab.addons, suggestionFinderUpnp=false} (exit)
2024-10-22 16:52:04.102 [DEBUG] [core.karaf.internal.FeatureInstaller] - bundle org.openhab.core.karaf:4.2.2 (196)[org.openhab.core.karaf.internal.FeatureInstaller(204)] : ImmediateComponentHolder Finished configuring the dependency managers for component for pid org.openhab.addons
2024-10-22 16:52:04.109 [DEBUG] [core.karaf.internal.FeatureInstaller] - bundle org.openhab.core.karaf:4.2.2 (196)[org.openhab.core.karaf.internal.FeatureInstaller(204)] : ImmediateComponentHolder Will not enable component for pid org.openhab.addons: holder enabled state: true, metadata enabled: true
2024-10-22 16:52:06.212 [DEBUG] [.AutomationResourceBundlesEventQueue] - Process bundle event 32, for automation bundle 'org.openhab.core.config.discovery.addon.sddp'
2024-10-22 16:52:06.214 [DEBUG] [.AutomationResourceBundlesEventQueue] - Process bundle event 32, for automation bundle 'org.openhab.core.config.discovery.addon.sddp'
2024-10-22 16:52:06.221 [DEBUG] [.AutomationResourceBundlesEventQueue] - Process bundle event 32, for automation bundle 'org.openhab.core.config.discovery.addon.sddp'
2024-10-22 16:52:06.227 [DEBUG] [vider.AbstractResourceBundleProvider] - Parse rules from bundle 'org.openhab.core.config.discovery.addon.sddp'
2024-10-22 16:52:06.232 [DEBUG] [.AutomationResourceBundlesEventQueue] - Process bundle event 32, for automation bundle 'org.openhab.core.config.discovery.sddp'
2024-10-22 16:52:06.233 [DEBUG] [.AutomationResourceBundlesEventQueue] - Process bundle event 32, for automation bundle 'org.openhab.core.config.discovery.sddp'
2024-10-22 16:52:06.235 [DEBUG] [.AutomationResourceBundlesEventQueue] - Process bundle event 32, for automation bundle 'org.openhab.core.config.discovery.sddp'
2024-10-22 16:52:06.240 [DEBUG] [vider.AbstractResourceBundleProvider] - Parse rules from bundle 'org.openhab.core.config.discovery.sddp'
2024-10-22 16:52:06.262 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService] : BundleComponentActivator : ComponentHolder created.
2024-10-22 16:52:06.265 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService] : Dependency Manager created $001interface=org.openhab.core.net.NetworkAddressService, filter=null, policy=static, cardinality=1..1, bind=null, unbind=null, updated=null, field=null, field-option=null, collection-type=service, parameter=1
2024-10-22 16:52:06.267 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService] : Dependency Manager created $002interface=org.openhab.core.i18n.TranslationProvider, filter=null, policy=static, cardinality=1..1, bind=null, unbind=null, updated=null, field=null, field-option=null, collection-type=service, parameter=2
2024-10-22 16:52:06.268 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService] : Dependency Manager created $003interface=org.openhab.core.i18n.LocaleProvider, filter=null, policy=static, cardinality=1..1, bind=null, unbind=null, updated=null, field=null, field-option=null, collection-type=service, parameter=3
2024-10-22 16:52:06.268 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService] : Dependency Manager created SddpDeviceParticipantinterface=org.openhab.core.config.discovery.sddp.SddpDeviceParticipant, filter=null, policy=dynamic, cardinality=0..n, bind=addSddpDeviceParticipant, unbind=removeSddpDeviceParticipant, updated=null, field=null, field-option=null, collection-type=null, parameter=null
2024-10-22 16:52:06.270 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService] : Dependency Manager created SddpDiscoveryParticipantinterface=org.openhab.core.config.discovery.sddp.SddpDiscoveryParticipant, filter=null, policy=dynamic, cardinality=0..n, bind=addSddpDiscoveryParticipant, unbind=removeSddpDiscoveryParticipant, updated=null, field=null, field-option=null, collection-type=null, parameter=null
2024-10-22 16:52:06.271 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService] : Dependency Manager created osgi.ds.satisfying.conditioninterface=org.osgi.service.condition.Condition, filter=(osgi.condition.id=true), policy=dynamic, cardinality=1..1, bind=null, unbind=null, updated=null, field=null, field-option=null, collection-type=null, parameter=null
2024-10-22 16:52:06.272 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService] : Component created: DS=DS14, implementation=org.openhab.core.config.discovery.sddp.SddpDiscoveryService, immediate=true, default-enabled=true, factory=null, configuration-policy=optional, activate=activate, deactivate=deactivate, modified=modified configuration-pid=[discovery.sddp]
2024-10-22 16:52:06.273 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService] : Component Services: scope=singleton, services=[org.openhab.core.config.discovery.DiscoveryService]
2024-10-22 16:52:06.274 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService] : Component Properties: {protocol=sddp, osgi.ds.satisfying.condition.target=(osgi.condition.id=true)}
2024-10-22 16:52:06.276 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService] : Querying state disabled
2024-10-22 16:52:06.278 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService] : Querying state disabled
2024-10-22 16:52:06.279 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService] : Component can not be activated since it is in state disabled
2024-10-22 16:52:06.280 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService] : Querying state disabled
2024-10-22 16:52:06.281 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : Updating target filters
2024-10-22 16:52:06.283 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : No change in target property for dependency $001: currently registered: false
2024-10-22 16:52:06.284 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] :  No existing service listener to unregister for dependency $001
2024-10-22 16:52:06.288 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : Setting target property for dependency $001 to null
2024-10-22 16:52:06.289 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : New service tracker for $001, initial active: false, previous references: {}, classFilter: (objectClass=org.openhab.core.net.NetworkAddressService), initialReferenceFilter (objectClass=org.openhab.core.net.NetworkAddressService)
2024-10-22 16:52:06.290 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : dm $001 tracker reset (closed)
2024-10-22 16:52:06.291 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : dm $001 tracking 1 SingleStatic added {org.openhab.core.net.NetworkAddressService}={service.id=201, service.bundleid=156, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.net.NetUtil, service.config.label=Network Settings, component.id=40, useIPv6=false, broadcastAddress=192.168.0.255, service.config.category=system, useOnlyOneAddress=false, service.config.description.uri=system:network, service.pid=[org.openhab.network, org.openhab.network], primaryAddress=192.168.0.17/24} (enter)
2024-10-22 16:52:06.292 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : dm $001 tracking 1 SingleStatic active: false trackerOpened: false optional: false
2024-10-22 16:52:06.296 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : dm $001 tracking 1 SingleStatic added {org.openhab.core.net.NetworkAddressService}={service.id=201, service.bundleid=156, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.net.NetUtil, service.config.label=Network Settings, component.id=40, useIPv6=false, broadcastAddress=192.168.0.255, service.config.category=system, useOnlyOneAddress=false, service.config.description.uri=system:network, service.pid=[org.openhab.network, org.openhab.network], primaryAddress=192.168.0.17/24} (exit)
2024-10-22 16:52:06.297 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : dm $001 tracker opened
2024-10-22 16:52:06.299 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : registering service listener for dependency $001
2024-10-22 16:52:06.300 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : No change in target property for dependency $002: currently registered: false
2024-10-22 16:52:06.301 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] :  No existing service listener to unregister for dependency $002
2024-10-22 16:52:06.303 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : Setting target property for dependency $002 to null
2024-10-22 16:52:06.305 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : New service tracker for $002, initial active: false, previous references: {}, classFilter: (objectClass=org.openhab.core.i18n.TranslationProvider), initialReferenceFilter (objectClass=org.openhab.core.i18n.TranslationProvider)
2024-10-22 16:52:06.308 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : dm $002 tracker reset (closed)
2024-10-22 16:52:06.311 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : dm $002 tracking 2 SingleStatic added {org.openhab.core.i18n.TranslationProvider, org.openhab.core.i18n.LocaleProvider, org.openhab.core.i18n.LocationProvider, org.openhab.core.i18n.TimeZoneProvider, org.openhab.core.i18n.UnitProvider}={service.id=173, service.bundleid=156, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.internal.i18n.I18nProviderImpl, language=en, service.config.label=Regional Settings, component.id=13, timezone=Europe/Brussels, service.config.category=system, region=BE, service.config.description.uri=system:i18n, service.pid=[org.openhab.i18n, org.openhab.i18n]} (enter)
2024-10-22 16:52:06.313 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : dm $002 tracking 2 SingleStatic active: false trackerOpened: false optional: false
2024-10-22 16:52:06.315 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : dm $002 tracking 2 SingleStatic added {org.openhab.core.i18n.TranslationProvider, org.openhab.core.i18n.LocaleProvider, org.openhab.core.i18n.LocationProvider, org.openhab.core.i18n.TimeZoneProvider, org.openhab.core.i18n.UnitProvider}={service.id=173, service.bundleid=156, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.internal.i18n.I18nProviderImpl, language=en, service.config.label=Regional Settings, component.id=13, timezone=Europe/Brussels, service.config.category=system, region=BE, service.config.description.uri=system:i18n, service.pid=[org.openhab.i18n, org.openhab.i18n]} (exit)
2024-10-22 16:52:06.318 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : dm $002 tracker opened
2024-10-22 16:52:06.319 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : registering service listener for dependency $002
2024-10-22 16:52:06.319 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : No change in target property for dependency $003: currently registered: false
2024-10-22 16:52:06.320 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] :  No existing service listener to unregister for dependency $003
2024-10-22 16:52:06.326 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : Setting target property for dependency $003 to null
2024-10-22 16:52:06.328 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : New service tracker for $003, initial active: false, previous references: {}, classFilter: (objectClass=org.openhab.core.i18n.LocaleProvider), initialReferenceFilter (objectClass=org.openhab.core.i18n.LocaleProvider)
2024-10-22 16:52:06.329 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : dm $003 tracker reset (closed)
2024-10-22 16:52:06.332 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : dm $003 tracking 3 SingleStatic added {org.openhab.core.i18n.TranslationProvider, org.openhab.core.i18n.LocaleProvider, org.openhab.core.i18n.LocationProvider, org.openhab.core.i18n.TimeZoneProvider, org.openhab.core.i18n.UnitProvider}={service.id=173, service.bundleid=156, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.internal.i18n.I18nProviderImpl, language=en, service.config.label=Regional Settings, component.id=13, timezone=Europe/Brussels, service.config.category=system, region=BE, service.config.description.uri=system:i18n, service.pid=[org.openhab.i18n, org.openhab.i18n]} (enter)
2024-10-22 16:52:06.333 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : dm $003 tracking 3 SingleStatic active: false trackerOpened: false optional: false
2024-10-22 16:52:06.336 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : dm $003 tracking 3 SingleStatic added {org.openhab.core.i18n.TranslationProvider, org.openhab.core.i18n.LocaleProvider, org.openhab.core.i18n.LocationProvider, org.openhab.core.i18n.TimeZoneProvider, org.openhab.core.i18n.UnitProvider}={service.id=173, service.bundleid=156, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.internal.i18n.I18nProviderImpl, language=en, service.config.label=Regional Settings, component.id=13, timezone=Europe/Brussels, service.config.category=system, region=BE, service.config.description.uri=system:i18n, service.pid=[org.openhab.i18n, org.openhab.i18n]} (exit)
2024-10-22 16:52:06.340 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : dm $003 tracker opened
2024-10-22 16:52:06.342 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : registering service listener for dependency $003
2024-10-22 16:52:06.342 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : No change in target property for dependency SddpDeviceParticipant: currently registered: false
2024-10-22 16:52:06.344 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] :  No existing service listener to unregister for dependency SddpDeviceParticipant
2024-10-22 16:52:06.348 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : Setting target property for dependency SddpDeviceParticipant to null
2024-10-22 16:52:06.352 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : New service tracker for SddpDeviceParticipant, initial active: false, previous references: {}, classFilter: (objectClass=org.openhab.core.config.discovery.sddp.SddpDeviceParticipant), initialReferenceFilter (objectClass=org.openhab.core.config.discovery.sddp.SddpDeviceParticipant)
2024-10-22 16:52:06.353 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : dm SddpDeviceParticipant tracker reset (closed)
2024-10-22 16:52:06.355 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : dm SddpDeviceParticipant tracker opened
2024-10-22 16:52:06.358 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : registering service listener for dependency SddpDeviceParticipant
2024-10-22 16:52:06.360 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : No change in target property for dependency SddpDiscoveryParticipant: currently registered: false
2024-10-22 16:52:06.363 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] :  No existing service listener to unregister for dependency SddpDiscoveryParticipant
2024-10-22 16:52:06.365 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : Setting target property for dependency SddpDiscoveryParticipant to null
2024-10-22 16:52:06.368 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : New service tracker for SddpDiscoveryParticipant, initial active: false, previous references: {}, classFilter: (objectClass=org.openhab.core.config.discovery.sddp.SddpDiscoveryParticipant), initialReferenceFilter (objectClass=org.openhab.core.config.discovery.sddp.SddpDiscoveryParticipant)
2024-10-22 16:52:06.369 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : dm SddpDiscoveryParticipant tracker reset (closed)
2024-10-22 16:52:06.370 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : dm SddpDiscoveryParticipant tracker opened
2024-10-22 16:52:06.371 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : registering service listener for dependency SddpDiscoveryParticipant
2024-10-22 16:52:06.372 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] :  No existing service listener to unregister for dependency osgi.ds.satisfying.condition
2024-10-22 16:52:06.373 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : Setting target property for dependency osgi.ds.satisfying.condition to (osgi.condition.id=true)
2024-10-22 16:52:06.375 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : New service tracker for osgi.ds.satisfying.condition, initial active: false, previous references: {}, classFilter: (objectClass=org.osgi.service.condition.Condition), initialReferenceFilter (&(objectClass=org.osgi.service.condition.Condition)(osgi.condition.id=true))
2024-10-22 16:52:06.376 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : dm osgi.ds.satisfying.condition tracker reset (closed)
2024-10-22 16:52:06.377 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : dm osgi.ds.satisfying.condition tracking 4 SingleDynamic added {org.osgi.service.condition.Condition}={service.id=6, service.bundleid=0, service.scope=singleton, service.pid=0.org.osgi.service.condition.ConditionImpl, osgi.condition.id=true} (enter)
2024-10-22 16:52:06.381 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : dm osgi.ds.satisfying.condition tracking 4 SingleDynamic added {org.osgi.service.condition.Condition}={service.id=6, service.bundleid=0, service.scope=singleton, service.pid=0.org.osgi.service.condition.ConditionImpl, osgi.condition.id=true} (exit)
2024-10-22 16:52:06.382 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : dm osgi.ds.satisfying.condition tracker opened
2024-10-22 16:52:06.383 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : registering service listener for dependency osgi.ds.satisfying.condition
2024-10-22 16:52:06.385 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : Changed state from disabled to unsatisfiedReference
2024-10-22 16:52:06.387 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : Component enabled
2024-10-22 16:52:06.388 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : ActivateInternal
2024-10-22 16:52:06.389 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : Querying state unsatisfiedReference
2024-10-22 16:52:06.390 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : Activating component from state unsatisfiedReference
2024-10-22 16:52:06.391 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : Querying state unsatisfiedReference
2024-10-22 16:52:06.392 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : Changed state from unsatisfiedReference to satisfied
2024-10-22 16:52:06.393 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : registration change queue [registered]
2024-10-22 16:52:06.395 [DEBUG] [nternal.DiscoveryServiceRegistryImpl] - bundle org.openhab.core.config.discovery:4.2.2 (169)[org.openhab.core.config.discovery.internal.DiscoveryServiceRegistryImpl(130)] : dm DiscoveryService tracking 11 MultipleDynamic added {org.openhab.core.config.discovery.DiscoveryService}={service.id=550, service.bundleid=536, service.scope=bundle, protocol=sddp, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.config.discovery.sddp.SddpDiscoveryService, component.id=375} (enter)
2024-10-22 16:52:06.397 [DEBUG] [nternal.DiscoveryServiceRegistryImpl] - bundle org.openhab.core.config.discovery:4.2.2 (169)[org.openhab.core.config.discovery.internal.DiscoveryServiceRegistryImpl(130)] : dm DiscoveryService tracking 11 MultipleDynamic already active, binding {org.openhab.core.config.discovery.DiscoveryService}={service.id=550, service.bundleid=536, service.scope=bundle, protocol=sddp, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.config.discovery.sddp.SddpDiscoveryService, component.id=375}
2024-10-22 16:52:06.403 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : Checking constructor public org.openhab.core.config.discovery.sddp.SddpDiscoveryService(java.util.Map,org.openhab.core.net.NetworkAddressService,org.openhab.core.i18n.TranslationProvider,org.openhab.core.i18n.LocaleProvider)
2024-10-22 16:52:06.405 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : getClassFromComponentClassLoader: Looking for interface class org.openhab.core.net.NetworkAddressService through loader of org.openhab.core.config.discovery.sddp.SddpDiscoveryService
2024-10-22 16:52:06.406 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : getClassFromComponentClassLoader: Found class org.openhab.core.net.NetworkAddressService
2024-10-22 16:52:06.406 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : getClassFromComponentClassLoader: Looking for interface class org.openhab.core.i18n.TranslationProvider through loader of org.openhab.core.config.discovery.sddp.SddpDiscoveryService
2024-10-22 16:52:06.407 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : getClassFromComponentClassLoader: Found class org.openhab.core.i18n.TranslationProvider
2024-10-22 16:52:06.408 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : getClassFromComponentClassLoader: Looking for interface class org.openhab.core.i18n.LocaleProvider through loader of org.openhab.core.config.discovery.sddp.SddpDiscoveryService
2024-10-22 16:52:06.408 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : getClassFromComponentClassLoader: Found class org.openhab.core.i18n.LocaleProvider
2024-10-22 16:52:06.412 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : Found constructor with 4 arguments : public org.openhab.core.config.discovery.sddp.SddpDiscoveryService(java.util.Map,org.openhab.core.net.NetworkAddressService,org.openhab.core.i18n.TranslationProvider,org.openhab.core.i18n.LocaleProvider)
2024-10-22 16:52:06.413 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : This thread collected dependencies
2024-10-22 16:52:06.414 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : getService (single component manager) dependencies collected.
2024-10-22 16:52:06.416 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : Querying state satisfied
2024-10-22 16:52:06.418 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : Querying state satisfied
2024-10-22 16:52:06.419 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : For dependency $001, optional: false; to bind: [[RefPair: ref: [{org.openhab.core.net.NetworkAddressService}={service.id=201, service.bundleid=156, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.net.NetUtil, service.config.label=Network Settings, component.id=40, useIPv6=false, broadcastAddress=192.168.0.255, service.config.category=system, useOnlyOneAddress=false, service.config.description.uri=system:network, service.pid=[org.openhab.network, org.openhab.network], primaryAddress=192.168.0.17/24}] service: [null]]]
2024-10-22 16:52:06.420 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : For dependency $002, optional: false; to bind: [[RefPair: ref: [{org.openhab.core.i18n.TranslationProvider, org.openhab.core.i18n.LocaleProvider, org.openhab.core.i18n.LocationProvider, org.openhab.core.i18n.TimeZoneProvider, org.openhab.core.i18n.UnitProvider}={service.id=173, service.bundleid=156, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.internal.i18n.I18nProviderImpl, language=en, service.config.label=Regional Settings, component.id=13, timezone=Europe/Brussels, service.config.category=system, region=BE, service.config.description.uri=system:i18n, service.pid=[org.openhab.i18n, org.openhab.i18n]}] service: [null]]]
2024-10-22 16:52:06.420 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : For dependency $003, optional: false; to bind: [[RefPair: ref: [{org.openhab.core.i18n.TranslationProvider, org.openhab.core.i18n.LocaleProvider, org.openhab.core.i18n.LocationProvider, org.openhab.core.i18n.TimeZoneProvider, org.openhab.core.i18n.UnitProvider}={service.id=173, service.bundleid=156, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.internal.i18n.I18nProviderImpl, language=en, service.config.label=Regional Settings, component.id=13, timezone=Europe/Brussels, service.config.category=system, region=BE, service.config.description.uri=system:i18n, service.pid=[org.openhab.i18n, org.openhab.i18n]}] service: [null]]]
2024-10-22 16:52:06.421 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : For dependency SddpDeviceParticipant, optional: true; to bind: []
2024-10-22 16:52:06.424 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : For dependency SddpDiscoveryParticipant, optional: true; to bind: []
2024-10-22 16:52:06.427 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : For dependency osgi.ds.satisfying.condition, optional: false; to bind: [[RefPair: ref: [{org.osgi.service.condition.Condition}={service.id=6, service.bundleid=0, service.scope=singleton, service.pid=0.org.osgi.service.condition.ConditionImpl, osgi.condition.id=true}] service: [null]]]
2024-10-22 16:52:06.431 [DEBUG] [g.discovery.AbstractDiscoveryService] - Background discovery for discovery service 'org.openhab.core.config.discovery.sddp.SddpDiscoveryService' enabled.
2024-10-22 16:52:06.434 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : getting activate: activate
2024-10-22 16:52:06.435 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : Locating method activate in class org.openhab.core.config.discovery.sddp.SddpDiscoveryService
2024-10-22 16:52:06.436 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - listenBackGroundMulticast() starting on interface 'enp0s3'
2024-10-22 16:52:06.441 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : Declared Method org.openhab.core.config.discovery.sddp.SddpDiscoveryService.activate([interface org.osgi.service.component.ComponentContext]) not found
2024-10-22 16:52:06.443 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : Locating method activate in class org.openhab.core.config.discovery.AbstractDiscoveryService
2024-10-22 16:52:06.444 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : Declared Method org.openhab.core.config.discovery.AbstractDiscoveryService.activate([interface org.osgi.service.component.ComponentContext]) not found
2024-10-22 16:52:06.445 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : Found activate method: protected void org.openhab.core.config.discovery.AbstractDiscoveryService.activate(java.util.Map)
2024-10-22 16:52:06.447 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : invoking activate: activate: parameters [org.apache.felix.scr.impl.helper.ReadOnlyDictionary]
2024-10-22 16:52:06.448 [DEBUG] [g.discovery.AbstractDiscoveryService] - Background discovery for discovery service 'org.openhab.core.config.discovery.sddp.SddpDiscoveryService' enabled.
2024-10-22 16:52:06.449 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : invoked activate: activate
2024-10-22 16:52:06.450 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : Set implementation object for component
2024-10-22 16:52:06.451 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - bundle org.openhab.core.config.discovery.sddp:4.2.2 (536)[org.openhab.core.config.discovery.sddp.SddpDiscoveryService(375)] : Changed state from satisfied to active
2024-10-22 16:52:06.452 [DEBUG] [nternal.DiscoveryServiceRegistryImpl] - bundle org.openhab.core.config.discovery:4.2.2 (169)[org.openhab.core.config.discovery.internal.DiscoveryServiceRegistryImpl(130)] : invoking bind: addDiscoveryService: parameters [org.openhab.core.config.discovery.sddp.SddpDiscoveryService]
2024-10-22 16:52:06.453 [DEBUG] [nternal.DiscoveryServiceRegistryImpl] - bundle org.openhab.core.config.discovery:4.2.2 (169)[org.openhab.core.config.discovery.internal.DiscoveryServiceRegistryImpl(130)] : invoked bind: addDiscoveryService
2024-10-22 16:52:06.454 [DEBUG] [nternal.DiscoveryServiceRegistryImpl] - bundle org.openhab.core.config.discovery:4.2.2 (169)[org.openhab.core.config.discovery.internal.DiscoveryServiceRegistryImpl(130)] : dm DiscoveryService tracking 11 MultipleDynamic added {org.openhab.core.config.discovery.DiscoveryService}={service.id=550, service.bundleid=536, service.scope=bundle, protocol=sddp, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.config.discovery.sddp.SddpDiscoveryService, component.id=375} (exit)
2024-10-22 16:52:06.465 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder] : BundleComponentActivator : ComponentHolder created.
2024-10-22 16:52:06.467 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder] : Dependency Manager created $000interface=org.openhab.core.config.discovery.DiscoveryService, filter=(protocol=sddp), policy=static, cardinality=1..1, bind=null, unbind=null, updated=null, field=null, field-option=null, collection-type=service, parameter=0
2024-10-22 16:52:06.468 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder] : Dependency Manager created osgi.ds.satisfying.conditioninterface=org.osgi.service.condition.Condition, filter=(osgi.condition.id=true), policy=dynamic, cardinality=1..1, bind=null, unbind=null, updated=null, field=null, field-option=null, collection-type=null, parameter=null
2024-10-22 16:52:06.469 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder] : Component created: DS=DS14, implementation=org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder, immediate=false, default-enabled=true, factory=null, configuration-policy=optional, activate=activate, deactivate=deactivate, modified=null configuration-pid=[sddp-addon-suggestion-finder]
2024-10-22 16:52:06.470 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder] : Component Services: scope=singleton, services=[org.openhab.core.config.discovery.addon.AddonFinder]
2024-10-22 16:52:06.472 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder] : Component Properties: {osgi.ds.satisfying.condition.target=(osgi.condition.id=true), $000.target=(protocol=sddp)}
2024-10-22 16:52:06.474 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder] : Querying state disabled
2024-10-22 16:52:06.475 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder] : Querying state disabled
2024-10-22 16:52:06.477 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder] : Component can not be activated since it is in state disabled
2024-10-22 16:52:06.478 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder] : Querying state disabled
2024-10-22 16:52:06.478 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : Updating target filters
2024-10-22 16:52:06.479 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] :  No existing service listener to unregister for dependency $000
2024-10-22 16:52:06.479 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : Setting target property for dependency $000 to (protocol=sddp)
2024-10-22 16:52:06.480 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : New service tracker for $000, initial active: false, previous references: {}, classFilter: (objectClass=org.openhab.core.config.discovery.DiscoveryService), initialReferenceFilter (&(objectClass=org.openhab.core.config.discovery.DiscoveryService)(protocol=sddp))
2024-10-22 16:52:06.480 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : dm $000 tracker reset (closed)
2024-10-22 16:52:06.481 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : dm $000 tracking 1 SingleStatic added {org.openhab.core.config.discovery.DiscoveryService}={service.id=550, service.bundleid=536, service.scope=bundle, protocol=sddp, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.config.discovery.sddp.SddpDiscoveryService, component.id=375} (enter)
2024-10-22 16:52:06.482 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : dm $000 tracking 1 SingleStatic active: false trackerOpened: false optional: false
2024-10-22 16:52:06.483 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : dm $000 tracking 1 SingleStatic added {org.openhab.core.config.discovery.DiscoveryService}={service.id=550, service.bundleid=536, service.scope=bundle, protocol=sddp, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.config.discovery.sddp.SddpDiscoveryService, component.id=375} (exit)
2024-10-22 16:52:06.483 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : dm $000 tracker opened
2024-10-22 16:52:06.484 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : registering service listener for dependency $000
2024-10-22 16:52:06.484 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] :  No existing service listener to unregister for dependency osgi.ds.satisfying.condition
2024-10-22 16:52:06.485 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : Setting target property for dependency osgi.ds.satisfying.condition to (osgi.condition.id=true)
2024-10-22 16:52:06.485 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : New service tracker for osgi.ds.satisfying.condition, initial active: false, previous references: {}, classFilter: (objectClass=org.osgi.service.condition.Condition), initialReferenceFilter (&(objectClass=org.osgi.service.condition.Condition)(osgi.condition.id=true))
2024-10-22 16:52:06.485 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : dm osgi.ds.satisfying.condition tracker reset (closed)
2024-10-22 16:52:06.486 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : dm osgi.ds.satisfying.condition tracking 2 SingleDynamic added {org.osgi.service.condition.Condition}={service.id=6, service.bundleid=0, service.scope=singleton, service.pid=0.org.osgi.service.condition.ConditionImpl, osgi.condition.id=true} (enter)
2024-10-22 16:52:06.490 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : dm osgi.ds.satisfying.condition tracking 2 SingleDynamic added {org.osgi.service.condition.Condition}={service.id=6, service.bundleid=0, service.scope=singleton, service.pid=0.org.osgi.service.condition.ConditionImpl, osgi.condition.id=true} (exit)
2024-10-22 16:52:06.491 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : dm osgi.ds.satisfying.condition tracker opened
2024-10-22 16:52:06.492 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : registering service listener for dependency osgi.ds.satisfying.condition
2024-10-22 16:52:06.492 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : Changed state from disabled to unsatisfiedReference
2024-10-22 16:52:06.492 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : Component enabled
2024-10-22 16:52:06.494 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : ActivateInternal
2024-10-22 16:52:06.495 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : Querying state unsatisfiedReference
2024-10-22 16:52:06.496 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : Querying state unsatisfiedReference
2024-10-22 16:52:06.497 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : Activating component from state unsatisfiedReference
2024-10-22 16:52:06.499 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : Querying state unsatisfiedReference
2024-10-22 16:52:06.500 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : Querying state unsatisfiedReference
2024-10-22 16:52:06.503 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : Changed state from unsatisfiedReference to satisfied
2024-10-22 16:52:06.504 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : registration change queue [registered]
2024-10-22 16:52:06.509 [DEBUG] [scovery.addon.AddonSuggestionService] - bundle org.openhab.core.config.discovery.addon:4.2.2 (170)[org.openhab.core.config.discovery.addon.AddonSuggestionService(134)] : dm AddonFinder tracking 18 MultipleDynamic added {org.openhab.core.config.discovery.addon.AddonFinder}={service.id=551, service.bundleid=535, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), $000.target=(protocol=sddp), component.name=sddp-addon-suggestion-finder, component.id=376} (enter)
2024-10-22 16:52:06.511 [DEBUG] [scovery.addon.AddonSuggestionService] - bundle org.openhab.core.config.discovery.addon:4.2.2 (170)[org.openhab.core.config.discovery.addon.AddonSuggestionService(134)] : dm AddonFinder tracking 18 MultipleDynamic already active, binding {org.openhab.core.config.discovery.addon.AddonFinder}={service.id=551, service.bundleid=535, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), $000.target=(protocol=sddp), component.name=sddp-addon-suggestion-finder, component.id=376}
2024-10-22 16:52:06.514 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : Checking constructor public org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(org.openhab.core.config.discovery.DiscoveryService)
2024-10-22 16:52:06.515 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : getClassFromComponentClassLoader: Looking for interface class org.openhab.core.config.discovery.DiscoveryService through loader of org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder
2024-10-22 16:52:06.516 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : getClassFromComponentClassLoader: Found class org.openhab.core.config.discovery.DiscoveryService
2024-10-22 16:52:06.517 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : Found constructor with 1 arguments : public org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(org.openhab.core.config.discovery.DiscoveryService)
2024-10-22 16:52:06.518 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : This thread collected dependencies
2024-10-22 16:52:06.519 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : getService (single component manager) dependencies collected.
2024-10-22 16:52:06.519 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : Querying state satisfied
2024-10-22 16:52:06.521 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : Querying state satisfied
2024-10-22 16:52:06.523 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : For dependency $000, optional: false; to bind: [[RefPair: ref: [{org.openhab.core.config.discovery.DiscoveryService}={service.id=550, service.bundleid=536, service.scope=bundle, protocol=sddp, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.core.config.discovery.sddp.SddpDiscoveryService, component.id=375}] service: [null]]]
2024-10-22 16:52:06.525 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : For dependency osgi.ds.satisfying.condition, optional: false; to bind: [[RefPair: ref: [{org.osgi.service.condition.Condition}={service.id=6, service.bundleid=0, service.scope=singleton, service.pid=0.org.osgi.service.condition.ConditionImpl, osgi.condition.id=true}] service: [null]]]
2024-10-22 16:52:06.532 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : getting activate: activate
2024-10-22 16:52:06.533 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : Locating method activate in class org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder
2024-10-22 16:52:06.538 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : Declared Method org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder.activate([interface org.osgi.service.component.ComponentContext]) not found
2024-10-22 16:52:06.539 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - listenActiveScanUnicast() starting on '192.168.0.17:44715' on interface 'enp0s3'
2024-10-22 16:52:06.540 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : Locating method activate in class org.openhab.core.config.discovery.addon.BaseAddonFinder
2024-10-22 16:52:06.542 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : Declared Method org.openhab.core.config.discovery.addon.BaseAddonFinder.activate([interface org.osgi.service.component.ComponentContext]) not found
2024-10-22 16:52:06.543 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : Locating method activate in class java.lang.Object
2024-10-22 16:52:06.544 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : Declared Method java.lang.Object.activate([interface org.osgi.service.component.ComponentContext]) not found
2024-10-22 16:52:06.545 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : activate method [activate] not found, ignoring
2024-10-22 16:52:06.546 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : Set implementation object for component
2024-10-22 16:52:06.546 [DEBUG] [discovery.addon.sddp.SddpAddonFinder] - bundle org.openhab.core.config.discovery.addon.sddp:4.2.2 (535)[org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder(376)] : Changed state from satisfied to active
2024-10-22 16:52:06.547 [DEBUG] [scovery.addon.AddonSuggestionService] - bundle org.openhab.core.config.discovery.addon:4.2.2 (170)[org.openhab.core.config.discovery.addon.AddonSuggestionService(134)] : invoking bind: addAddonFinder: parameters [org.openhab.core.config.discovery.addon.sddp.SddpAddonFinder]
2024-10-22 16:52:06.548 [DEBUG] [scovery.addon.AddonSuggestionService] - bundle org.openhab.core.config.discovery.addon:4.2.2 (170)[org.openhab.core.config.discovery.addon.AddonSuggestionService(134)] : invoked bind: addAddonFinder
2024-10-22 16:52:06.549 [DEBUG] [scovery.addon.AddonSuggestionService] - bundle org.openhab.core.config.discovery.addon:4.2.2 (170)[org.openhab.core.config.discovery.addon.AddonSuggestionService(134)] : dm AddonFinder tracking 18 MultipleDynamic added {org.openhab.core.config.discovery.addon.AddonFinder}={service.id=551, service.bundleid=535, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), $000.target=(protocol=sddp), component.name=sddp-addon-suggestion-finder, component.id=376} (exit)
2024-10-22 16:52:06.558 [DEBUG] [core.karaf.internal.FeatureInstaller] - Installed 'openhab-core-config-discovery-addon-sddp'
2024-10-22 16:52:07.647 [DEBUG] [openhab.core.io.rest.sse.SseResource] - Sending alive event to SSE connections
2024-10-22 16:52:13.909 [DEBUG] [core.karaf.internal.FeatureInstaller] - Running scheduled sync job
2024-10-22 16:52:17.649 [DEBUG] [openhab.core.io.rest.sse.SseResource] - Sending alive event to SSE connections
2024-10-22 16:52:21.286 [DEBUG] [est.sitemap.internal.SitemapResource] - Run clean SSE subscriptions job
2024-10-22 16:52:27.650 [DEBUG] [openhab.core.io.rest.sse.SseResource] - Sending alive event to SSE connections
2024-10-22 16:52:37.652 [DEBUG] [openhab.core.io.rest.sse.SseResource] - Sending alive event to SSE connections
2024-10-22 16:52:47.654 [DEBUG] [openhab.core.io.rest.sse.SseResource] - Sending alive event to SSE connections
2024-10-22 16:52:54.769 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - processPacket() foundDevices=0, deviceParticipants=1, discoveryParticipants=0
2024-10-22 16:52:54.771 [DEBUG] [.discovery.sddp.SddpDiscoveryService] - processPacket() foundDevices=0, deviceParticipants=1, discoveryParticipants=0
2024-10-22 16:52:57.655 [DEBUG] [openhab.core.io.rest.sse.SseResource] - Sending alive event to SSE connections
2024-10-22 16:53:07.657 [DEBUG] [openhab.core.io.rest.sse.SseResource] - Sending alive event to SSE connections
2024-10-22 16:53:13.910 [DEBUG] [core.karaf.internal.FeatureInstaller] - Running scheduled sync job
You are correct, there seems to be a SDDP discovery service, the protocol seems to be used by the JVC binding. From looking at the code for SddpDiscoveryService it seems very similar to SSDP, but uses port 1902. @Fabio_Pergola could you try capturing traffic on that port instead?
Ok will do that this evening
I have a full tcpdump when I restart Openhab on all ports, I can share on private maybe?
Sure!
Ok, will share later, driving ATM :slight_smile:
Hey, here are the tcpdumps:
this one, i just restarted the ssdp service on openhab …
this one when i restarted Openhab, even with ssdp disabled
Both same behaviour
on second dump , i see a little bit traffic indeed on 1902 , that sends to 192.168.0.20 , making the device unavailable for a while
if i look at the discovered devices for SSDP in Home Assistant, the denon receiver is indeed using SSDP:
But i dont have any issues with HA when i restart it, but seems SSDP with Openhab is flooding the device or something?
But i also see some other drops on the network wirth wifi devices, there must be somekind of flood or something like that :frowning:
