i have build a sensor to detected the one liter signal of our house water counter. The sensor sends a “1” every liter via MQTT. Count works perfect, because I adapted this rules: Rule to count rain tipping bucket
My problem is the use the variable for increment “WaterIncr”. On every system startup or reload of the .rules file it’s restored to “0”. So my “WaterTotal” value ist also restored after counting the next liter. With my little brain I thought: “Ok let’s make a rule that’s restores the value of “WaterIncr” from the value of the Item “WaterTotal” after this is restored from mapdb” (mapdb > Item WaterTotal > Var WaterIncr), but the stuff doesn’t work.
Is there a better solution to save the “WaterTotal” Value persistently?
What are is wrong in my rules?
thank you for reading.
Ahoi Christian
My rules:
// Variables
var WaterIncr = 0
var WaterTempIncr = 0
//restore the incrementation Values
rule "restore Value"
System started
Thread::sleep(50000)
logInfo("FILE", "Systemstarted rule after Delay")
WaterIncr = WaterTotal.value as Number
logInfo(Rules, "WaterIncr is: ", WaterIncr)
// WaterCount is in the house
rule "Increment Water Count"
Item WaterCount received update 1
WaterIncr = WaterIncr + 1
WaterTempIncr = WaterTempIncr +1
WaterTotal.postUpdate(WaterIncr.toString)
WaterTemp.postUpdate(WaterTempIncr.toString)
// Temp Water Counter Rest
rule "Reset Wasserverbrauch"
Item WaterTempReset received command ON
WaterTemp.postUpdate(0)
WaterTempIncr = 0
