There is a presistence functionality if OH starts to reload the state of items from presistence, very good.
But, if I change an item file at runtime with z-wave items in it, all states of the items are lost until the device sends an update of the state.
Is there a way to prevent this or to restore the current state from the presistence file after items file is changes?
My problem is, that all door/window sensors states are lost and I have to go to every window/door and open/close it one time to get the current status back
It doesnât when you edit an Items file without restarting OpenHAB.
The only way I can think to detect file reload is to have a rule firing on some Item change and test to see if it changed to UNDEF. Choose something like a virtual Item (controlled by your rules) rather than something bound to a real device, just to avoid UNDEF appearing due to say a communication failure. Choose something normally persisted to avoid triggering at system reload.
In my experience it does indeed work for both restarts of OH and edits to .items files. If this is no longer the case I would call that a regression.
restoreOnStartup has always initialized my Items from persistence for file edits as well. But I admit it has been awhile since Iâve done a lot of editing.
rule for saving presitence
gRestoreState.members.forEach[item | item.persist(âmapdbâ) ]
This looks like it is working, I checked the stored values with rest api and they are all correct and all does exist
gRestoreState.members.forEach[item | item.sendCommand(item.previousState(false,âmapdbâ).state.toString) ]
This looks like it is not working. The values are not set correctly on at all not set.
If i use the item itselve, it is working
DoorSensor01_Battery.persist(âmapdbâ)
DoorSensor02_Battery.persist(âmapdbâ)
It looks like some values cannot be set correctly
2017-05-12 09:18:29.327 [ERROR] [.script.engine.ScriptExecutionThread] - Rule âPresistenceWiederherstellenâ: The argument âcommandâ must not be null or empty.
This works well:
logInfo(âLoggerâ,"Itemname speichern: "+item.name)
logInfo(âLoggerâ,"Itemname speichern: "+item.state.toString)
Thread::sleep(2000)
This crashed on some of the items with the above error message
logInfo(âLoggerâ,"Itemname laden: "+item.name)
logInfo(âLoggerâ,"Itemname laden: "+item.state.toString)
Thread::sleep(2000)
DoorSensor01.sendCommand(DoorSensor01.previousState(false,âmapdbâ).state.toString)
==> same error as above:
Rest API tells me, that the value is correct stored in mapdb.
It makes little sense to sendCommand to a Contact type usually, the real device is passive and cannot do anything with a command, though I donât see why you cannot.
It does make sense to use postUpdate for restoring, after all you probably do not want the target item to actually do anything, you just want to restore the state.
I do think you should set up your persistence properly for automatic onChange, and not rely on a rule to save it.
I am intrigued by the suggestion that restoreOnStartup should work with an items file reload, but I cannot test this (not OH2 user) - would someone with working system try it? Checked it out in OH1 and it works fine. I really thought it did not.
Iâve tested it. my zwave devices stayed undefinied after reload of items file. And this causes alarm because of my door/window sensors or heating or status of siren
This is why I look for a solution to reload current state after reload of item file. And now it is working.
But there is another strange thing. gRestoreState membership does not work. If I add now items to this group they will not be stored in the presistence file. looks like it is a problem with OH2. Only restart of OH2 fixed this problem.
after change from sendCommand to postUpdate everything is working well. With sendcommand the rules runs into an error and does not go to the end of the rule.
But after some playing now it is perfect. And postUpdate does what I want, just update the value to do not any action on a zwave-device
motion items edited at 20:54:
2017-05-12 20:54:12.389 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model âmotion.itemsâ
events.log
2017-05-12 20:54:13.613 [ItemStateChangedEvent ] - FibFGS223_2_Sw_2 changed from NULL to OFF
No indication that the two items from the motion.items file (FibUniSens1_1,FibEye1_Motion_S) got restored through MapDB. But an item from lights.items file (FibFGS223_2_Sw_2) got restored correctly.
b) Second Test:
lights.items edited at 21:18:
2017-05-12 21:18:38.921 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model 'lights.items'
Again no indication that the two items from the motion.items file (FibUniSens1_1,FibEye1_Motion_S) got restored through MapDB. The item from lights.items (FibFGS223_2_Sw_2) again got restored correctly.
events.log:
2017-05-12 21:18:39.902 [ItemStateChangedEvent ] - FibFGS223_2_Sw_2 changed from NULL to OFF
I cannot make any sense out of that. The only difference I can see at the moment is that FibFGS223_2_Sw_2 is a mains powered device and FibUniSens1_1 and FibEye1_Motion_S are battery operated devices.
That is probably correct, by design. Restore should just happen invisibly and not trigger update events.
Seems possible that real updates from real (mains) devices could beat the restore mechanism to it (or rapidly overturn a restored state). As I understand battery zwave devices, updates are very infrequent.
Please try to restart OH2 before testing. Sometimes group mebership is not working correctly. Maybe this is the problem why not all are restored.
In my case, this was the problem.
You can verify group membership with this little rule
item:
Switch groupmembership
rule "List groupmembership"
Item groupmembership changed to ON
groupmembership.postUpdate(OFF)
