Has anyone managed to configure Revogi with OpenHab ?
its a cheap and well rated bulb that uses bluetooth:
I don’t see a Revogi binding and the Bluetooth binding wouldn’t work so I think you are out of luck.
I was just at Home Depot this morning and saw one of these Bluetooth LED bulbs from “HomeBrite”. I should have read this topic before I purchased it. I also recently purchased a Raspberry PI 3 with built in Bluetooth. I knew there was Bluetooth binding and I thought it would work with this bulb. Is there anyway at all to get this working with OpenHAB?
If you can get it working from the command line or through a Python script you can have OH interact with it via the Exec binding.
