hi,
for testing i ordered an revolt nx-4911-675 thermostat
https://www.pearl.de/a-NX4911-3103.shtml
but i think the channels of the binding are not complete or depending on device.
some are available in binding some not, some in deconz some not
this is the json from deconz rest api
"config": {
"heatsetpoint": 1400,
"locked": false,
"offset": 0,
"on": true,
"preset": null,
"reachable": true,
"schedule": {},
"schedule_on": false,
"setvalve": false,
"windowopen_set": false
"ep": 1,
"etag": "3543db5c3273ea6541fea96a317e5f6d",
"lastseen": "2021-02-26T21:30Z",
"manufacturername": "_TZE200_kfvq6avy",
"modelid": "TS0601",
"name": "Thermostat",
"state": {
"lastupdated": "none",
"on": null,
"temperature": 2000
"type": "ZHAThermostat",
"uniqueid": "5c:02:72:ff:fe:db:15:1c-01-0201"
this from openhab rest api
"statusInfo": {
"status": "ONLINE",
"statusDetail": "NONE"
"editable": true,
"label": "Thermostat Schlafzimmer",
"bridgeUID": "deconz:deconz:00212E04876D",
"configuration": {
"lastSeenPolling": 1440,
"id": "34"
"properties": {
"uid": "5c:02:72:ff:fe:db:15:1c-01-0201",
"firmwareVersion": "",
"modelId": "TS0601",
"vendor": "_TZE200_kfvq6avy"
"UID": "deconz:thermostat:00212E04876D:5c0272fffedb151c010201",
"thingTypeUID": "deconz:thermostat",
"channels": [
"linkedItems": [
"Bedroom_Heating"
"uid": "deconz:thermostat:00212E04876D:5c0272fffedb151c010201:temperature",
"id": "temperature",
"channelTypeUID": "deconz:temperature",
"itemType": "Number:Temperature",
"kind": "STATE",
"label": "Temperature",
"description": "Current temperature",
"defaultTags": [],
"properties": {},
"configuration": {}
"linkedItems": [
"Bedroom_Heating_Set"
"uid": "deconz:thermostat:00212E04876D:5c0272fffedb151c010201:heatsetpoint",
"id": "heatsetpoint",
"channelTypeUID": "deconz:heatsetpoint",
"kind": "STATE",
"label": "Target temperature",
"description": "Target temperature",
"defaultTags": [],
"properties": {},
"configuration": {}
"linkedItems": [
"Bedroom_Heating_Mode"
"uid": "deconz:thermostat:00212E04876D:5c0272fffedb151c010201:mode",
"id": "mode",
"channelTypeUID": "deconz:mode",
"itemType": "String",
"kind": "STATE",
"label": "Mode",
"description": "Current mode",
"defaultTags": [],
"properties": {},
"configuration": {}
"linkedItems": [
"Bedroom_Heating_Offset"
"uid": "deconz:thermostat:00212E04876D:5c0272fffedb151c010201:offset",
"id": "offset",
"channelTypeUID": "deconz:offset",
"kind": "STATE",
"label": "Offset",
"description": "Temperature offset",
"defaultTags": [],
"properties": {},
"configuration": {}
"linkedItems": [
"Bedroom_Heating_Valve"
"uid": "deconz:thermostat:00212E04876D:5c0272fffedb151c010201:valve",
"id": "valve",
"channelTypeUID": "deconz:valve",
"itemType": "Number:Dimensionless",
"kind": "STATE",
"label": "Valve position",
"description": "Current valve position",
"defaultTags": [],
"properties": {},
"configuration": {}
"linkedItems": [
"Bedroom_Heating_Update"
"uid": "deconz:thermostat:00212E04876D:5c0272fffedb151c010201:last_updated",
"id": "last_updated",
"channelTypeUID": "deconz:last_updated",
"itemType": "DateTime",
"kind": "STATE",
"label": "Letzte Aktualisierung",
"description": "Zeit, zu der sich dieser Wert geändert hat.",
"defaultTags": [],
"properties": {},
"configuration": {}
"linkedItems": [
"Bedroom_Heating_Battery"
"uid": "deconz:thermostat:00212E04876D:5c0272fffedb151c010201:battery_level",
"id": "battery_level",
"channelTypeUID": "system:battery-level",
"itemType": "Number",
"kind": "STATE",
"label": "Batterieladung",
"defaultTags": [],
"properties": {},
"configuration": {}
"linkedItems": [
"Bedroom_Heating_BatteryLow"
"uid": "deconz:thermostat:00212E04876D:5c0272fffedb151c010201:battery_low",
"id": "battery_low",
"channelTypeUID": "system:low-battery",
"itemType": "Switch",
"kind": "STATE",
"label": "Niedriger Batteriestatus",
"defaultTags": [],
"properties": {},
"configuration": {}
"linkedItems": [
"Bedroom_Heating_LastSeen"
"uid": "deconz:thermostat:00212E04876D:5c0272fffedb151c010201:last_seen",
"id": "last_seen",
"channelTypeUID": "deconz:last_seen",
"kind": "STATE",
"label": "Zuletzt Gesehen",
"defaultTags": [],
"properties": {},
"configuration": {}
some error from setting mode
2021-02-26 21:49:44.048 [WARN ] [ing.deconz.internal.handler.DeconzBaseThingHandler] - Sending command OFF to channel deconz:thermostat:00212E04876D:5c0272fffedb151c010201:mode failed: 400 - [{"error":{"address":"/sensors/34/config/mode","description":"parameter, mode, not available","type":6}}]
2021-02-26 21:49:47.397 [WARN ] [ing.deconz.internal.handler.DeconzBaseThingHandler] - Sending command AUTO to channel deconz:thermostat:00212E04876D:5c0272fffedb151c010201:mode failed: 400 - [{"error":{"address":"/sensors/34/config/mode","description":"parameter, mode, not available","type":6}}]
2021-02-26 21:49:50.748 [WARN ] [ing.deconz.internal.handler.DeconzBaseThingHandler] - Sending command HEAT to channel deconz:thermostat:00212E04876D:5c0272fffedb151c010201:mode failed: 400 - [{"error":{"address":"/sensors/34/config/mode","description":"parameter, mode, not available","type":6}}]
2021-02-26 21:49:59.770 [WARN ] [conz.internal.handler.SensorThermostatThingHandler] - Invalid thermostat mode: MANUAL. Valid values: [AUTO, HEAT, OFF, UNKNOWN]
