Running OH2 build #464 on win10. Can not get the Rfxcom binding/thing to work. I have added the rfxcom extension from Paper UI and then run scan from inbox menu, thing not found. After that i try to run “Search for Thing” or “Add Manually”, nothing found…
I then run Configuration-Thing and add COM3 as Serial number parameter, it is still offline.
Normally I run OH1.8.3 with this hardware, configured as COM3 and it work just fine.
openhab.log
2016-09-04 19:33:25.172 [INFO ] [ernal.connector.RFXComJD2XXConnector] - Connecting to RFXCOM device ‘COM3’.
2016-09-04 19:33:25.247 [INFO ] [ui.habmin.internal.servlet.HABminApp] - Started HABmin servlet at /habmin
2016-09-04 19:33:25.279 [ERROR] [g.rfxcom.handler.RFXComBridgeHandler] - Error occured when trying to load native library for OS ‘Windows 10’ version ‘10.0’, processor 'x86’
java.lang.UnsatisfiedLinkError: C:\OpenHab2\userdata\tmp\jd2xx7591307408906303518.dll: The specified procedure could not be found
at java.lang.ClassLoader$NativeLibrary.load(Native Method)[:1.8.0_101]
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1941)[:1.8.0_101]
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1824)[:1.8.0_101]
at java.lang.Runtime.load0(Runtime.java:809)[:1.8.0_101]
at java.lang.System.load(System.java:1086)[:1.8.0_101]
at cz.adamh.utils.NativeUtils.loadLibraryFromJar(NativeUtils.java:91)[199:org.openhab.binding.rfxcom:2.0.0.201608301455]
at jd2xx.JD2XX.(JD2XX.java:768)[199:org.openhab.binding.rfxcom:2.0.0.201608301455]
at org.openhab.binding.rfxcom.internal.connector.RFXComJD2XXConnector.connect(RFXComJD2XXConnector.java:54)[199:org.openhab.binding.rfxcom:2.0.0.201608301455]
at org.openhab.binding.rfxcom.handler.RFXComBridgeHandler.connect(RFXComBridgeHandler.java:161)[199:org.openhab.binding.rfxcom:2.0.0.201608301455]
at org.openhab.binding.rfxcom.handler.RFXComBridgeHandler.access$8(RFXComBridgeHandler.java:141)[199:org.openhab.binding.rfxcom:2.0.0.201608301455]
at org.openhab.binding.rfxcom.handler.RFXComBridgeHandler$1.run(RFXComBridgeHandler.java:114)[199:org.openhab.binding.rfxcom:2.0.0.201608301455]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_101]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308)[:1.8.0_101]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180)[:1.8.0_101]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294)[:1.8.0_101]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_101]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_101]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_101]
2016-09-04 19:33:26.728 [INFO ] [ding.astro.handler.AstroThingHandler] - Scheduled astro DailyJob at midnight for thing astro:moon:home
2016-09-04 19:33:26.731 [INFO ] [ding.astro.handler.AstroThingHandler] - Scheduled astro PositionalJob with interval of 60 seconds for thing astro:moon:home
2016-09-04 19:33:26.747 [INFO ] [ding.astro.handler.AstroThingHandler] - Scheduled astro DailyJob at midnight for thing astro:sun:home
2016-09-04 19:33:26.747 [INFO ] [ding.astro.handler.AstroThingHandler] - Scheduled astro PositionalJob with interval of 60 seconds for thing astro:sun:home
2016-09-04 19:34:25.180 [INFO ] [ernal.connector.RFXComJD2XXConnector] - Connecting to RFXCOM device ‘COM3’.
