for christmas i want to couple my old Brennenstuhl 433 MHz switches with oH2 and bought a RFXCOM transceiver.
The binding works great and its no problem to detect the actions with the remote as new things.
When i now tried to switch the radio plug via Paper UI i got this entry in the log: [ERROR] [binding.rfxcom.handler.RFXComHandler] - Transmitting error: Invalid device id '1393925'
Is there an easy way to find out the device ID over the system code?
So in your example picture the housecode is 11100 equals 7 decimal (least significant bit first)
The receiver code is 10000 equals 1 decimal (again, least significant bit first).
I don’t use the RFXCOM binding so cannot tell you how to adapt that to the device id config, BUT:
Read this section and you should be able to find the device id by the help of the binding:
From the examples section on page 28 in your linked pdf I would assume for your first switch:
Housecode 1000 goes to “I” and
Receivercode 010000 goes to "5"
so it should be I5
But it’s just a guess, I cannot check it because I use Tinkerforge hardware …
I know this from calculating DMX512-Values But i don’t know the correlation between the 10 DIP-Switches of my Brennenstuhl plug and the device ID for the Lightning4 Code of the RFXCOM-Binding:
