I did some hex decoding of the raw message. This give the 95.1 degree as well. So I plugged the RFXTRX into a windows box and let RFXmgr decode the transmissions:
Packettype = TEMP_RAIN
subtype = TR1 - WS1200
Sequence nbr = 11
ID = 61441
Temperature = 7,4 °C
Total rain = 95,1 mm
Signal level = 5 -80dBi
Battery = OK
Exactly, what the binding decodes. So sorry for the noise!
If @flagg 's rfxcom decodes exactly what’s on the display it could be in my rfxcom transceiver itself.
Newer noticed this difference between display and openhab before.
I’m going to check, if there’s a newer rfxtrx firmware than mine…
So @martinvw many thanks for your effort and sorry again!
Flashed now the release 1015. Still the same inconsistent results…
Mmh. But what if the values the sensor is sending are not the values displayed at the indoor unit?
So I pulled out the batteries out of the display and put them in again.
Guess what: The display is showing RainTotal=0,0mm. Obviously the WS1200 shows the difference between the initial counter at batterie change and the current as “rain total” and not the value the outdoor unit is sending.
So you will see the same behaviour as me when you change the batteries of the outdoor unit and the display not at the same time…
Are you helped for now or is merging the branch essential for you? I expect that the other PR could be merged in a few weeks its quite a tough pull-request
I am also very happy with the provided Jar. I can understand that it will take some time to put in into the merged branch… @Curlyel: It is true that I switched the batteries of both the sensor and the indoor unit at the same time. That explains why there is no difference at my site…
