Hi all.
I’m using a new RFXCOM on a Synology RS212 NAS running OpenHAB 1.8.1
As far as I can tell the setup is correct, no errors are logged w.r.t. RFXCOM, I know supported sensors are transmitting, yet OpenHAB is not logging any RFXCOM messages.
I’ve set up the USB drivers, permissions of /dev/ttyUSB0 are correct (read/write by all, including the openhab user)
/volume1/homes/openhab $ ls -l /dev/ttyUSB0
crw-rw-rw- 1 root root 188, 0 Mar 1 12:36 /dev/ttyUSB0
And when running as the openhab user, the python rfxcmd tool properly logs my temperature+humidity sensors.
/volume1/homes/openhab $ ./rfxcmd.py -d /dev/ttyUSB0 -lv
RFXCMD Version 0.3 (739)Received = 0D 01 00 00 02 53 FB 00 04 04 00 01 03 1C
Date/Time = 2016-03-01 12:36:35
Packet Length = 0D
Packettype = Interface Message
Subtype = Interface response
Sequence nbr = 00
Response on cmnd = Get Status, return firmware versions and configuration of the interface.
Transceiver type = 433.92MHz (Transceiver)
Firmware version = 251
Protocols:
Undecoded Disabled
RFU Disabled
Byron SX Disabled
RSL Disabled
Lightning4 Disabled
FineOffset / Viking Disabled
Rubicson Disabled
AE Blyss Disabled
Blinds T1/T2/T3/T4 Disabled
Blinds T0 Disabled
ProGuard Disabled
FS20 Disabled
La Crosse Disabled
Hideki / UPM Enabled
AD Lightwave RF Disabled
Mertik Disabled
Visonic Disabled
ATI Disabled
Oregon Scientific Disabled
Meiantech Disabled
HomeEasy EU Disabled
AC Enabled
ARC Disabled
X10 DisabledReceived = 0A 52 07 00 3C 0E 00 CC 1D 02 89
Date/Time = 2016-03-01 12:37:00
Packet Length = 0A
Packettype = Temperature and humidity sensors
Subtype = TFA TS34C, Cresta
Seqnbr = 00
Id = 3C0E
Temperature = 20.4 C
Humidity = 29%
Humidity Status = Normal
Battery = 9
Signal level = 8Received = 0A 52 07 01 7B 0E 00 BC 21 02 69
Date/Time = 2016-03-01 12:37:03
Packet Length = 0A
Seqnbr = 01
Id = 7B0E
Temperature = 18.8 C
Humidity = 33%
Battery = 9
Signal level = 6Received = 0A 52 07 07 7B 0E 00 BC 21 02 79
Date/Time = 2016-03-01 12:39:24
Packet Length = 0A
Seqnbr = 07
Id = 7B0E
Humidity = 33%
Battery = 9
Signal level = 7
An exerpt from my logback.xml:
< logger name=“org.openhab.binding.rfxcom” level=“DEBUG” />
Yet no RFXCOM logs with received messages.
RackStation> ./openhab_logs.sh
2016-03-01 15:35:18.404 [INFO ] [.o.core.internal.CoreActivator] - openHAB runtime has been started (v1.8.1).
2016-03-01 15:35:30.201 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - mDNS service has been started
2016-03-01 15:35:30.590 [INFO ] [o.o.i.s.i.DiscoveryServiceImpl] - Service Discovery initialization completed.
2016-03-01 15:35:35.040 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'rrd4j.persist’
2016-03-01 15:35:38.608 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'mysql.persist’
2016-03-01 15:35:38.883 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'huis.items’
2016-03-01 15:35:51.056 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'default.sitemap’
2016-03-01 15:35:53.408 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'alarm.script’
2016-03-01 15:35:59.800 [INFO ] [penhab.io.rest.RESTApplication] - Started REST API at /rest
2016-03-01 15:36:06.496 [INFO ] [.o.u.w.i.servlet.WebAppServlet] - Started Classic UI at /classicui/openhab.app
2016-03-01 15:36:14.606 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'allesuit.rules’
2016-03-01 15:36:16.020 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'notifications.rules’
2016-03-01 15:36:16.294 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'sonos.rules’
2016-03-01 15:36:16.762 [INFO ] [c.internal.ModelRepositoryImpl] - Loading model 'voicecommand.rules’
2016-03-01 15:36:17.230 [DEBUG] [o.b.r.internal.RFXComActivator] - RFXCOM binding has been started.
2016-03-01 15:36:17.878 [DEBUG] [.rfxcom.internal.RFXComBinding] - Activate
2016-03-01 15:36:17.921 [DEBUG] [.rfxcom.internal.RFXComBinding] - Activate
2016-03-01 15:36:18.417 [DEBUG] [.rfxcom.internal.RFXComBinding] - Activate
2016-03-01 15:36:18.597 [INFO ] [.service.AbstractActiveService] - Sonos Refresh Service has been started
2016-03-01 15:36:18.824 [DEBUG] [.rfxcom.internal.RFXComBinding] - Activate
2016-03-01 15:36:21.193 [INFO ] [.b.sonos.internal.SonosBinding] - Querying the network for a predefined Sonos device with UDN uuid:RINCON_000E5873AD0E01400
2016-03-01 15:36:21.293 [INFO ] [.b.sonos.internal.SonosBinding] - Querying the network for a predefined Sonos device with UDN uuid:RINCON_000E583D4D5801400
2016-03-01 15:36:21.316 [INFO ] [.b.sonos.internal.SonosBinding] - Querying the network for any other Sonos device
2016-03-01 15:36:26.836 [INFO ] [.b.sonos.internal.SonosBinding] - Found a Sonos device (S3) with UDN uuid:RINCON_000E5873AD0E01400
2016-03-01 15:36:26.899 [INFO ] [.b.sonos.internal.SonosBinding] - Found a Sonos device (ZP120) with UDN uuid:RINCON_000E583D4D5801400
2016-03-01 15:36:27.861 [WARN ] [.b.sonos.internal.SonosBinding] - Cannot cast class org.openhab.core.library.types.PercentType to an accepted state type for item Sonos_Keuken_volume
2016-03-01 15:36:27.925 [WARN ] [.b.sonos.internal.SonosBinding] - Cannot cast class org.openhab.core.library.types.PercentType to an accepted state type for item Sonos_Slaapkamer_volume
2016-03-01 15:36:30.211 [DEBUG] [.rfxcom.internal.RFXComBinding] - Activate
2016-03-01 15:36:30.310 [INFO ] [runtime.busevents ] - Sonos_Keuken_zone state updated to Keuken
2016-03-01 15:36:30.376 [INFO ] [runtime.busevents ] - Sonos_Slaapkamer_zone state updated to Slaapkamer
2016-03-01 15:36:30.383 [INFO ] [runtime.busevents ] - Sonos_Keuken_status state updated to PLAYING
2016-03-01 15:36:30.519 [DEBUG] [.rfxcom.internal.RFXComBinding] - Activate
2016-03-01 15:36:30.644 [INFO ] [.p.rrd4j.internal.RRD4jService] - Removing invalid defintion component = null heartbeat = 0 min/max = 0.0/0.0 step = 0 0 archives(s) = [] 0 items(s) = []
2016-03-01 15:36:30.648 [INFO ] [runtime.busevents ] - Sonos_Slaapkamer_status state updated to STOPPED
2016-03-01 15:36:30.740 [DEBUG] [.rfxcom.internal.RFXComBinding] - Activate
2016-03-01 15:36:30.873 [DEBUG] [.rfxcom.internal.RFXComBinding] - Activate
2016-03-01 15:36:31.368 [DEBUG] [.rfxcom.internal.RFXComBinding] - Activate
2016-03-01 15:36:37.981 [INFO ] [runtime.busevents ] - Sonos_Keuken_currenttrack state updated to VRT Radio 1 94.2 - Volume 1 - content - 23m remaining
2016-03-01 15:36:38.212 [INFO ] [runtime.busevents ] - Sonos_Slaapkamer_currenttrack state updated to VRT Radio 1 94.2 - Volume 1 - content - 23m remaining
2016-03-01 15:36:39.948 [DEBUG] [.rfxcom.internal.RFXComBinding] - Activate
2016-03-01 15:36:40.093 [DEBUG] [.rfxcom.internal.RFXComBinding] - Activate
2016-03-01 15:36:40.168 [DEBUG] [.rfxcom.internal.RFXComBinding] - Activate
2016-03-01 15:36:40.308 [DEBUG] [org.openhab.model.script.sonos] - Slaapkamer updated
2016-03-01 15:36:40.594 [DEBUG] [.rfxcom.internal.RFXComBinding] - Activate
2016-03-01 15:36:40.628 [DEBUG] [.rfxcom.internal.RFXComBinding] - Activate
2016-03-01 15:36:42.912 [DEBUG] [.rfxcom.internal.RFXComBinding] - Activate
2016-03-01 15:36:43.060 [DEBUG] [.rfxcom.internal.RFXComBinding] - Activate
2016-03-01 15:36:43.174 [DEBUG] [.rfxcom.internal.RFXComBinding] - Activate
What could be wrong?
