I’m trying to use a rfxcom usb device on a synology with OpenHAB. However, I am getting the following error:
2015-10-03 16:49:50.734 [INFO ] [.b.r.internal.RFXComConnection] - Connecting to RFXCOM [serialPort='/dev/ttyUSB0' ].
2015-10-03 16:49:51.666 [ERROR] [.b.r.internal.RFXComConnection] - Connection to RFXCOM controller failed.
at org.openhab.binding.rfxcom.internal.connector.RFXComSerialConnector.connect(RFXComSerialConnector.java:60) ~[na:na]
at org.openhab.binding.rfxcom.internal.RFXComConnection.connect(RFXComConnection.java:118) ~[na:na]
at org.openhab.binding.rfxcom.internal.RFXComConnection.updated(RFXComConnection.java:103) ~[na:na]
However, if I run Domoticz on the same synology, I am able to use the rfxcom device without problem on the same serial port (/dev/ttyUSB0).
Here’s my openhab.cfg section:
rfxcom:serialPort=/dev/ttyUSB0
Any help would be greatly appreciated.
PS: this is the corresponding dmesg entry:
usb 1-1.2: FTDI USB Serial Device converter now attached to ttyUSB0
