I’ve just downloaded and installed OpenHABian onto a RPi3, all default settings.
I then plugged in my RFXTrx into the USB, and dmesg gives the following output:
[ 2458.316663] usb 1-1.5: new full-speed USB device number 5 using dwc_otg
[ 2458.444158] usb 1-1.5: New USB device found, idVendor=0403, idProduct=6001
[ 2458.444180] usb 1-1.5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2458.444194] usb 1-1.5: Product: FT232R USB UART
[ 2458.444206] usb 1-1.5: Manufacturer: FTDI
[ 2458.444218] usb 1-1.5: SerialNumber: A603PE9S
[ 2459.490460] usbcore: registered new interface driver usbserial
[ 2459.490556] usbcore: registered new interface driver usbserial_generic
[ 2459.490643] usbserial: USB Serial support registered for generic
[ 2459.500076] usbcore: registered new interface driver ftdi_sio
[ 2459.500709] usbserial: USB Serial support registered for FTDI USB Serial Device
[ 2459.501685] ftdi_sio 1-1.5:1.0: FTDI USB Serial Device converter detected
[ 2459.501892] usb 1-1.5: Detected FT232RL
[ 2459.502778] usb 1-1.5: FTDI USB Serial Device converter now attached to ttyUSB0
So the hardware seems to be in place. I then proceeded to add the RFXCOM binding via Paper UI. When I then tried to scan for devices, I get a notification in the lower right corner saying “ERROR: undefined - undefined”. So I go have a look in the logs and find this:
Caused by: java.lang.NoClassDefFoundError: Could not initialize class jd2xx.JD2XX
at org.openhab.binding.rfxcom.internal.discovery.RFXComBridgeDiscovery.discoverRfxcom(RFXComBridgeDiscovery.java:88)
at org.openhab.binding.rfxcom.internal.discovery.RFXComBridgeDiscovery.startScan(RFXComBridgeDiscovery.java:67)
at org.eclipse.smarthome.config.discovery.AbstractDiscoveryService.startScan(AbstractDiscoveryService.java:199)
at org.eclipse.smarthome.config.discovery.internal.DiscoveryServiceRegistryImpl.startScan(DiscoveryServiceRegistryImpl.java:382)
at org.eclipse.smarthome.config.discovery.internal.DiscoveryServiceRegistryImpl.startScans(DiscoveryServiceRegistryImpl.java:367)
at org.eclipse.smarthome.config.discovery.internal.DiscoveryServiceRegistryImpl.startScan(DiscoveryServiceRegistryImpl.java:216)
at org.eclipse.smarthome.io.rest.core.discovery.DiscoveryResource.scan(DiscoveryResource.java:84)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)[:1.8.0_112]
I found JD2XX on Github but do I really need to install this manually to make this work? If not, what do I need to do?
