I have my RFXCOM Transceiver connected in OPENHABIAN running on a RP2. In the Devices I have the transceiver setup and apparently working. I have some inexpensive motion sesnors form china that I am trying to add to Openhab. These will be my first non-network devices in OH2.
In the log file tail output in Openhab, I see the RFXCOM433trx capturing the motion sensor output form my two devices (id’s 853500, 323212)
2019-04-06 15:18:19.584 [INFO ] [rnal.messages.RFXComLighting4Message] - A not completely supported command with value 6 was received, we can send it but please report it as an issue including what the command means, this helps to extend the binding with better support.
2019-04-06 15:18:19.589 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Message received: Raw data = 0913008FD05FC6019580, Packet type = LIGHTING4, Seq number = 143, Sub type = PT2262, Device Id = 853500, Command = UNKNOWN(6), Pulse = 405
2019-04-06 15:18:20.623 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Message received: Raw data = 090301902720BF8C0660, Packet type = UNDECODED_RF_MESSAGE, Seq number = 144, Sub type = ARC
2019-04-06 15:18:20.671 [INFO ] [rnal.messages.RFXComLighting4Message] - A not completely supported command with value 6 was received, we can send it but please report it as an issue including what the command means, this helps to extend the binding with better support.
2019-04-06 15:18:20.676 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Message received: Raw data = 09130091D05FC6019870, Packet type = LIGHTING4, Seq number = 145, Sub type = PT2262, Device Id = 853500, Command = UNKNOWN(6), Pulse = 408
2019-04-06 15:18:20.991 [INFO ] [rnal.messages.RFXComLighting4Message] - A not completely supported command with value 6 was received, we can send it but please report it as an issue including what the command means, this helps to extend the binding with better support.
2019-04-06 15:18:20.996 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Message received: Raw data = 09130092505FC6019580, Packet type = LIGHTING4, Seq number = 146, Sub type = PT2262, Device Id = 329212, Command = UNKNOWN(6), Pulse = 405
2019-04-06 15:18:24.202 [INFO ] [rnal.messages.RFXComLighting4Message] - A not completely supported command with value 6 was received, we can send it but please report it as an issue including what the command means, this helps to extend the binding with better support.
2019-04-06 15:18:24.206 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Message received: Raw data = 09130093D05FC6019360, Packet type = LIGHTING4, Seq number = 147, Sub type = PT2262, Device Id = 853500, Command = UNKNOWN(6), Pulse = 403
2019-04-06 15:18:24.410 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Message received: Raw data = 0903019427A0BF8C0660, Packet type = UNDECODED_RF_MESSAGE, Seq number = 148, Sub type = ARC
2019-04-06 15:18:24.570 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Message received: Raw data = 080301951BF8C00669, Packet type = UNDECODED_RF_MESSAGE, Seq number = 149, Sub type = ARC
2019-04-06 15:18:24.666 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Message received: Raw data = 0903019627A0BF8C064D, Packet type = UNDECODED_RF_MESSAGE, Seq number = 150, Sub type = ARC
2019-04-06 15:18:24.721 [INFO ] [rnal.messages.RFXComLighting4Message] - A not completely supported command with value 6 was received, we can send it but please report it as an issue including what the command means, this helps to extend the binding with better support.
2019-04-06 15:18:24.726 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Message received: Raw data = 09130097D05FC6018E60, Packet type = LIGHTING4, Seq number = 151, Sub type = PT2262, Device Id = 853500, Command = UNKNOWN(6), Pulse = 398
2019-04-06 15:18:32.816 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Message received: Raw data = 0903019827A0BF8C0660, Packet type = UNDECODED_RF_MESSAGE, Seq number = 152, Sub type = ARC
2019-04-06 15:18:32.912 [INFO ] [rnal.messages.RFXComLighting4Message] - A not completely supported command with value 6 was received, we can send it but please report it as an issue including what the command means, this helps to extend the binding with better support.
2019-04-06 15:18:32.916 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Message received: Raw data = 09130099D05FC6019370, Packet type = LIGHTING4, Seq number = 153, Sub type = PT2262, Device Id = 853500, Command = UNKNOWN(6), Pulse = 403
2019-04-06 15:18:34.190 [INFO ] [rnal.messages.RFXComLighting4Message] - A not completely supported command with value 6 was received, we can send it but please report it as an issue including what the command means, this helps to extend the binding with better support.
2019-04-06 15:18:34.194 [DEBUG] [g.rfxcom.handler.RFXComBridgeHandler] - Message received: Raw data = 0913009A505FC6019580, Packet type = LIGHTING4, Seq number = 154, Sub type = PT2262, Device Id = 329212, Command = UNKNOWN(6), Pulse = 405
Blockquote
These are simple motion sensor devices that the Openhab plugin is detecting as Lighting controls. How can I submit this to be fixed in the Binding and also how do I set these up to work as motion sensing devices?
There is NO documentation with these devices nor a recommended gateway or protocol available.
