Did you ever think of using the ARILUX controller for Openhab?
Didnt find documentation about it yet, but its basically a modded ESP8266 board.
costs about 5$ and I have 5 of them.
Would be cool to use them in Openhab.
Please check sonoff-tasmota, it’s supporting lot of things beside sonoff devices, details in
I was using this firmware together with MagicHome and on bare esp12 modules. Works great!
Please be warned seems to be missing configuration files to work.
I have gotten this to flash to an Arduino Nano using an ENC28J60.
Arduino Code Modified
#include <UIPEthernet.h>
#include <utility/logging.h>
#include <PubSubClient.h>
// Set the MAC address
byte mac[] = { 0x90, 0xA2, 0xDA, 0x0F, 0x5E, 0x69 };
// Set fallback IP address if DHCP fails
IPAddress ip(192,168,3,20);
// Set the broker server IP
byte server[] = { 192,168,3,3 };
EthernetClient ethClient;
// Callback function header
void callback(char* topic, byte* payload, unsigned int length);
PubSubClient client(server, 1883, callback, ethClient);
int SoffitR;
int SoffitG;
int SoffitB;
int BLUE = 5;
int GREEN = 7;
int RED = 3;
void setup()
// Open serial communications
Serial.begin(9600);
// Start with a hard-coded address:
Serial.println("Assigning Static IP address:");
Ethernet.begin(mac, ip);
Serial.print("My address:");
Serial.println(Ethernet.localIP());
// Connect to Broker, give it arduino as the name
if (client.connect("arduino_LED2")) {
// Publish a message to the status topic
client.publish("status/arduino_LED2","Arduino LED2 is now online");
// Listen for messages on the control topic
client.subscribe("control/arduino_LED2/#");
void loop()
client.loop();
void callback(char* topic, byte* payload, unsigned int length) {
// check for messages on subscribed topics
payload[length] = '\0';
Serial.print("Topic: ");
Serial.println(String(topic));
// check topic to identify type of content
if(String(topic) == "control/arduino_LED/livingroom/color") {
// convert payload to String
String value = String((char*)payload);
//value.trim();
Serial.print (value);
//Serial.flush();
// split string at every "," and store in proper variable
// convert final result to integer
SoffitR = value.substring(0,value.indexOf(',')).toInt();
SoffitG = value.substring(value.indexOf(',')+1,value.lastIndexOf(',')).toInt();
SoffitB = value.substring(value.lastIndexOf(',')+1).toInt();
// print obtained values for debugging
Serial.print("RED: ");
Serial.println(SoffitR);
//client.publish("status/arduino_LED2", SoffitR);
Serial.print("GREEN: ");
Serial.println(SoffitG);
//client.publish("status/arduino_LED2", SoffitG);
Serial.print("BLUE: ");
Serial.println(SoffitB);
//client.publish("status/arduino_LED2/soffit/color/blue", int SoffitB);
//Serial.flush();
analogWrite(GREEN, SoffitG);
analogWrite(RED, SoffitR);
analogWrite(BLUE, SoffitB);
while(Serial.available())
Serial.read();
.Items Code
/* LED STRIPS */
Color LivSoffitLight "Living Room Soffit Color" (Lights_LivingRoom)
String LivSoffitLightColor (Lights_LivingRoom) {mqtt=">[mosquitto:control/arduino_LED/livingroom/color:command:*:default]"}
Number LivSoffitAnimation "Living Room Soffit Animation" (Lights_LivingRoom) {mqtt=">[mosquitto:control/arduino_LED/livingroom/animation:command:*:default]"}
Sitemap Code:
sitemap demo label="MC Smart Home Automation" {
Frame label="Date" {
Text item=Date
Frame label="Accent-Lighting" {
Colorpicker item=LivSoffitLight
I have not gotten this to acutally light the LED’s on the Arduino I think this is missing rules. I will post rules if I figure them out. If anyone has knowledge about the rules I need I could use them.
Otherwise this will connect to mosquitto MQTT broker.
Hello All ,
I do have a problem with the last Arduino cod from this topic.
i am using binding-mqtt - 2.4.0
The cod is running but is not receiving the value from server , check the next picture , i try to check step by step but something is not right and i ca’t figure this out .
in the serial monitor from Arduino , you can see that is not stuck after providing the IP
sry for my English
