- Platform information: RPi 3b
- OS: Debian 9.6
- Java Runtime Environment: Zulu Embedded 8.25.0.76
- openHAB version: 2.3.0
- Issue of the topic:
I have a Wifi-LED Controller (MagicHome) which supports RGB. I integrated it with the Wifi-Led binding. In the Sitemap and with voice commands I can change the color of the LED without any issues. Also I can create routines in the alexa app and select a color for the LED strip there.
But my problem is, that I want to go to the smart devices and pick the color there from a list. But there are only buttons to dim the LEDs. Is there any way to get this working?
Here is a screenshot from my problem:
How it is:
How I want it to be:
- Please post configurations (if applicable):
- Items configuration related to the issue
wifiled.items
Color MyWiFiLight_color "LED-Color" (gLight) ["Lighting"] {channel="wifiled:wifiled:XYZ:color"}
- Sitemap configuration related to the issue
default.sitemap
sitemap default
Frame label="LED Strip"{
Switch item=MyWiFiLight_power label="TV-Bank"
Colorpicker item=MyWiFiLight_color label="Color and Brightness"
Sorry for my bad english and thank you in advance for your help.
