I have those:
How do I know, which LED Type I have and if I have those protocol issues?
I often tried to set the color through a HSB value but nothing works.
I have those:
What protocol this controller has to control the led?
Mqtt, http,other?
Probably MQTT, theres a ESP8266 in it.
But Iām not sure what the Magic home wifi app or OpenHAB uses in the background to communicate with the controller.
You will need to flash a new firware on it
Tasmota will probably work
Tasmota is great.
I use it on my Basics but there gotta be another way to send a HSB Value.
atm I controll them via a program and set the program speed to > 96, so the Script stops, everything works but that shouldānt be the the right way.
Reflashing them would be a bit to much to do with my 4 Controllers atm since Iāve so much other things to implement and do.
You wonāt be able to control them without reflashing
Hmm, thatās really sad.
My Solution for now works and I will reflash them when I have the Time.
A 3D printer is rolling in, so I need to save every minute I can. ;d
Same for me? (Different model)
Which one do you have?
What binding are you currently using?
wifiled
I have this one
I think you should put them in capital letters since they are in small . Maybe that could help. Also thisrouterlogin.mobi guide might help you in resloving router issues if any.
