A little update, the event works fine was my fault.
So the only problem is the log (but is just a warn) and the battery report.
The intercom has a battery and 2 days ago the battery was 67 now is 65 so also if item change only when the % change i should have something.
In the week end i will try the jar that you linked
Unfortunately i get several errors:
Everything in online… But battery is still NULL
2026-05-20 10:28:20.380 [ERROR] [ing.ring.internal.RingHandlerFactory] - bundle org.openhab.binding.ring:5.2.0.202605150959 (327)[org.openhab.binding.ring.internal.RingHandlerFactory(469)] : Error during instantiation of the implementation object
java.lang.IllegalArgumentException: argument type mismatch
at java.base/jdk.internal.reflect.DirectConstructorHandleAccessor.newInstance(DirectConstructorHandleAccessor.java:65)
at java.base/java.lang.reflect.Constructor.newInstanceWithCaller(Constructor.java:502)
at java.base/java.lang.reflect.Constructor.newInstance(Constructor.java:486)
at org.apache.felix.scr.impl.inject.internal.ComponentConstructorImpl.newInstance(ComponentConstructorImpl.java:326)
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:286)
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:115)
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:1001)
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:974)
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:919)
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:220)
at java.base/java.security.AccessController.doPrivileged(AccessController.java:319)
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:217)
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:118)
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:48)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:547)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:534)
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:660)
at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:88)
at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:669)
at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2625)
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:2091)
at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:2074)
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:442)
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:337)
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:304)
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1232)
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1152)
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:959)
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:895)
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1184)
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:118)
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:123)
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:961)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:937)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:874)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:141)
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:262)
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:500)
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:931)
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:917)
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:133)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:986)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:754)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enableInternal(AbstractComponentManager.java:676)
at org.apache.felix.scr.impl.manager.AbstractComponentManager.enable(AbstractComponentManager.java:439)
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.enableComponents(ConfigurableComponentHolder.java:671)
at org.apache.felix.scr.impl.BundleComponentActivator.initialEnable(BundleComponentActivator.java:341)
at org.apache.felix.scr.impl.Activator.loadComponents(Activator.java:610)
at org.apache.felix.scr.impl.Activator.access$200(Activator.java:75)
at org.apache.felix.scr.impl.Activator$ScrExtension.start(Activator.java:477)
at org.apache.felix.scr.impl.AbstractExtender.createExtension(AbstractExtender.java:196)
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:169)
at org.apache.felix.scr.impl.AbstractExtender.modifiedBundle(AbstractExtender.java:49)
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:488)
at org.osgi.util.tracker.BundleTracker$Tracked.customizerModified(BundleTracker.java:420)
at org.osgi.util.tracker.AbstractTracked.track(AbstractTracked.java:232)
at org.osgi.util.tracker.BundleTracker$Tracked.bundleChanged(BundleTracker.java:450)
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:949)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEventPrivileged(EquinoxEventPublisher.java:229)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:138)
at org.eclipse.osgi.internal.framework.EquinoxEventPublisher.publishBundleEvent(EquinoxEventPublisher.java:130)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor.publishModuleEvent(EquinoxContainerAdaptor.java:217)
at org.eclipse.osgi.container.Module.publishEvent(Module.java:499)
at org.eclipse.osgi.container.Module.start(Module.java:486)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel$2.run(ModuleContainer.java:1847)
at org.eclipse.osgi.internal.framework.EquinoxContainerAdaptor$1$1.execute(EquinoxContainerAdaptor.java:136)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1840)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1783)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1745)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1667)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:345)
Caused by: java.lang.ClassCastException: Cannot cast org.openhab.binding.ring.internal.RingVideoServlet to org.openhab.binding.ring.internal.RingVideoServlet
at java.base/java.lang.Class.cast(Class.java:4069)
at java.base/jdk.internal.reflect.DirectConstructorHandleAccessor.newInstance(DirectConstructorHandleAccessor.java:62)
... 76 more
2026-05-20 10:28:20.495 [WARN ] [g.discovery.internal.PersistentInbox] - bundle org.openhab.core.config.discovery:5.2.0.M4 (170)[org.openhab.core.config.discovery.internal.PersistentInbox(143)] : Could not get service from ref {org.openhab.core.thing.binding.ThingHandlerFactory, org.openhab.binding.ring.internal.RingHandlerFactory}={service.id=856, service.bundleid=327, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.ring.internal.RingHandlerFactory, component.id=469}
2026-05-20 10:28:20.509 [WARN ] [g.discovery.internal.PersistentInbox] - bundle org.openhab.core.config.discovery:5.2.0.M4 (170)[org.openhab.core.config.discovery.internal.PersistentInbox(143)] : DependencyManager : invokeBindMethod : Service not available from service registry for ServiceReference {org.openhab.core.thing.binding.ThingHandlerFactory, org.openhab.binding.ring.internal.RingHandlerFactory}={service.id=856, service.bundleid=327, service.scope=bundle, osgi.ds.satisfying.condition.target=(osgi.condition.id=true), component.name=org.openhab.binding.ring.internal.RingHandlerFactory, component.id=469} for reference ThingHandlerFactory
2026-05-20 10:28:20.536 [ERROR] [ing.ring.internal.RingHandlerFactory] - bundle org.openhab.binding.ring:5.2.0.202605150959 (327)[org.openhab.binding.ring.internal.RingHandlerFactory(469)] : Error during instantiation of the implementation object
... 76 more
OK I’ll need to look at this when I get a chance. I’m in hospital for the next couple of weeks, and going through some medication changes, so my brain isn’t that functional to look into this right now.
OK the short answer is that you are rate-limited due to a bug introduced with the camera snapshot support in 5.2.0. Due to my illness, I didn’t get a chance to get the fix into 5.2.1; I’ll try to get it ready for 5.2.2. Another solution is to install the 5.3.0 snapshot build from https://smedley.id.au/tmp/org.openhab.binding.ring-5.3.0-SNAPSHOT.jar
