Ring Binding [3.2.0;4.9.0)
Yes, that’s right. The intercom was automatically found as “other”. I have added it:
But it only has channels for the battery level and activating polling:
I’m missing a switch for the door opening command.
The good news is that’s about 80% of the battle. I’ll see if I can track down the API command for the button and add it. Hopefully someone has already reverse engineered it so it should just be as simple as a few lines.
Maybe that will help:
I’ll see if I can disect that and add the channel. It looks like the API call is a simple HTTP PUT so in theory it shouldn’t be hard. To be clear (since I neither have one nor have I seen one before), the channel should be a switch that sends to pulse to unlock (when ON is sent as a command) and then should return to OFF once the command is sent?
Yes, correct. :+1:
Awesome. I’ll check it out this weekend if I can find some time. I have a few development things I want to do when I can get a few hours.
Hello, I’m having issues installing on 4.1.1, does the binding support that version? If yes, can someone help me troubleshoot why it’s not working? Thanks!!!
Yes it should work just fine. What error are you getting?
I don’t get an error, it just doesn’t work, the logs say nothing. I’m sorry, i’m a total beginner at all this, but i downloaded the jar file from GitHub into /usr/share/openhab/addons… Do I need to do anything else?
Did you add the account bridge and authenticate?
Is anyone else having issues on the more recent 4.2 releases? Specifically with channels under the devices.
any news? :wink:
Hey, sorry I haven’t had a chance to look. Been tied up the last while on some personal things. I’m hoping I should have some time to look back into this (and some other open items on this binding) soon. My goal is to get through the review cycle and get it merged in in 4.2, maybe 4.3 if that doesn’t pan out otherwise. Then adding features becomes much easier since I’m not maintaining multiple code bases.
Hi, im new to all these bindings, things etc… how can i watch the live video of the videodoorbell? just can get an url with a 10 secs video recorded…
Thanx in advice, and good work man, thank you.
We don’t provide the live stream with the binding currently. That will come in the future with websockets.
I have updated to openHAB 4.2.1. I can find other community marketplace add-ons, but I can’t find this Ring add-on. Is it no longer available for v4.2, @morph166955 ?
Try now
Works… thanks.
Just by the way, I often get an error like this with the binding. But I can’t say exactly when it occurs.
Can I help you somehow with this?
I got a Ring Intercom at my hands and would love to integrate this
@morph166955 : can you please extend availability for 4.2.X and 4.3?
