2 Problems here (which are probably depending from each other)
I am 100% sure about cabling. Output #2 of Aeotec Nano shutter is connected to correct motor’s wire so that blinds are moving up (tested with switch - without openHAB)
Percentage value is ok, at least for Basic UI (0%, blinds are fully up (open), classic icon is matching with the current status).
Problem: command “UP” moves the blinds down
Frustrating that now I have to compensate a correct wiring with an inversion workaround.
After control inversion Homekit App however still shows the inverted percentage compared to openHAB Basic UI.
OK - could be compensated again with percentage inversion.
But then openHAB would display the wrong icons.
Thanks for helping but did you read my question completely?
I already said that I already inverted control (which in fact can only be a workaround as the cabling is correct).
Furthermore I already said that I could invert the percentage for Homekit, but then Basic UI would show wrong values/icons.
Do you understand? Homekit and Basic UI are interpreting the values differently i.e. invertedly.
I wonder if using a profile follow for the item would help? Sorry I don’t have rollershutters so can’t test much.
If that doesn’t work then use a rule to post the correct value to OH.
Here’s an example rule for inverting a dimmer command to Alexa example:
rule "Buero_Colortemp_Alexa Commands"
Item Buero_Colortemp_Alexa received command
Buero_Colortemp_Test.sendCommand(100 - receivedCommand as PercentType)
rule "Buero_Colortemp_Test Changes"
Item Buero_Colortemp_Test changed
Buero_Colortemp_Alexa.postUpdate(100 - Buero_Colortemp_Test.state as PercentType)
You may can tweak the example to do something similar for the info OH is receiving?
One more information which makes me think, that something is not correct with the binding:
Blinds are up, openHAB shows 0% - fine
When sending “Down” command, percentage switches to 100% and then back to a smaller percentage e.g. 3% and continues to count up to 100% until the blinds have reached their final position (100%)
Hi Udo,
many thanks for your explanations - got it. Makes sense now to me.
Do you have an explanation why up and down commands are inverted? Not a big problem anymore, but I’d like to understand.
