- Platform information: Raspberry Pi 3 B+
- openHAB version: Openhabian / openHAB 2.4.0-1
- Issue of the topic: please be detailed explaining your issue:
I´m a really beginner in Openhab2. I starting with small things like a rule for a roller shutter.
That worked fine. The roller shutter should close 30 min. after sun set and open in the morning at 6:45 from Mo-Fr. So far so good.
Now I want to implement something like a controll switch. Only if the control Switch is activ, the roller shutter should close and open.
After updateing the rule with the “val Rolladen_aktiv” the rule doesn´t work any longer?
I attached the hole rule, relevant items and the log file.
Can anybody help?
** Items configuration related to the issue**
Rollershutter Rolladen_Arbeitszimmer “Rolladen [%d %%]” {channel=“zwave:device:f658f7a4:node2:blinds_control”}
DateTime Sunset_Time “Sonnenuntergang [%1$tH:%1$tM]” { channel=“astro:sun:home:set#start” }
Switch Rolladen_OG_aktiv “Rolladensteuerung aktiv”
** Rules code related to the issue:**
val Rolladen_aktiv = if (Rolladen_OG_aktiv.state == On) 1 else 0
rule “Rolladen runter”
Channel ‘astro:sun:home:set#event’ triggered START
if (Rolladen_aktiv==1){ createTimer(now.plusMinutes(30)) [| Rolladen_Arbeitszimmer.sendCommand(70)]}
rule “Rolladen hoch”
Time cron “0 45 6 ? * MON-FRI *”
if (Rolladen_aktiv==1){Rolladen_Arbeitszimmer.sendCommand(UP)}
** If logs where generated please post these here using code fences**:
2019-04-25 22:18:28.592 [INFO ] [el.core.internal.ModelRepositoryImpl] - Validation issues found in configuration model ‘Rolladen.rules’, using it anyway:
Cannot reference the field ‘Rolladen_OG_aktiv’ before it is defined
2019-04-25 22:18:28.607 [INFO ] [el.core.internal.ModelRepositoryImpl] - Refreshing model ‘Rolladen.rules’
